BendPak Lift Installer
C2 of Year Finalist (stock) 2019
Jerry (720) 244-4144
Jim Beck (303) 923-3542
I'm curious why you are going with Bend Pak rather than Direct Lift which is about $1,000 cheaper? I'm trying to decide on a lift and keep going back and forth...
4th Gear
Thanks much for the reply. In between my posting and your reply, I had talked to BendPak Tech Support, and they gave me both these guy's names.
As far as the choice of BendPak, it was mainly on feedback I received from some of my brother's buddies that have BendPak lifts (they were happy). Also, the price difference was quite a bit less than your reply (but still more).
Now, for the install in my garage with shims to compensate for the slope of floor....
I don't have experience with Bend Pak but do own a Direct Lift. I've had it for 4-1/2 years and it has performed flawlessly in that time. I don't know how much my floor slopes but the adjusters are right near the limit to level the lift. I installed the lift myself with help from friends to lift the heavy parts. Very easy to assemble and setup.
The $1000 includes some accessories that are extra with Bendpak and included with Direct that I would want. Also speaking of floor slope I have 2 inches in slope for the length of the lift. I was thinking I wouldn't need shims for that 2 inch slope. Do you have more slope? Almost all garages have some but I was hoping I wouldn't need shims because I was told with shims you need to bolt to the floor. Any thoughts?
4th Gear
Go Fast
I second using Jim Beck, Becks Automotive Lift Service (303) 923-3542. He installed my Bendpak HD 9 XW back in Jan. He and his team was quick and efficent. Very pleased with the work
New install by Bendpak today
I purchased a BendPak HD 9ST. I ordered direct from Santa Paula and paid for them to install. It all went great! I am glad I paid for install. Three guys took 3 hours to set up and test. It is heavy stuff and you will need special tool to cut tubing for hydraulic and air systems. I strongly recommend you hire it done. Also you will need a fork lift to unload from motor freight most likely.
Good luck with your install. Hope you get a good crew.
4th Gear
Got my lift installed with no issues. Jerry Hampton did the install; he constructed the shims on-site. Install time was about 6 hours with Jerry working alone. Thanks for everyone's input.
Go Fast
Maybe you should contact Bendpak to inquire about exchanging parts to make it an extra wide lift, if you have the room. I would hate a $3k lift dictate my car choice.
