C6Z06 Big Brake Upgrade for C5 & C6-FREE SHIPPING!
Supporting Vendor
St. Jude Donor '11
C6 Z06 Big Brake Kit-from $2099 Free Shipping
Choose from Yellow, Red, Silver or Charcoal.
0% Financing available for up to 12 months!
Now you can have the awesome brakes big brakes of the C6 Z06 for your C5 or C6 @ a smoking price!
This great kit has everything you'll need to bolt them on your C5 or C6! This kit features large 6 piston front calipers with 355mm x 32mm (14" x 1.3") rotors and 4 piston rear calipers with 340mm x 26mm (13.4" x 1") rotors. Calipers are NEW factory GM parts and TPS Zinc Coated Rotors, OEM Brake Pads, Motul Brake Fluid and TPS DOT approved stainless steel brake lines. This is a direct bolt on system and comes complete with all needed parts to complete your installation. Our TPS Zinc Coated rotors prevent rusting on the hats and veins of the rotors
Please Note: If you are installing these on a C5 you will have to run at least 18x10.5 C5 Z06 Wheels in the front to have proper wheel to brake clearance.
If you have aftermarket wheels and are unsure if they will fit these brakes please contact me at Mikem@TPSMotorsports.com and I will email you a wheel template so you can confirm the brakes will fit your wheels.
Kit includes:
* (2) 6 Piston Front Calipers
* (2) 4 Piston Rear Calipers
* (2) TPS Zinc Coated 14 inch Front Cross Drilled Rotors
* (2) TPS Zinc Coated 13.4 inch Rear Cross Drilled Rotors
* (1) Front and Rear Brake Pads
* (4) TPS DOT Steel Braided Brake Lines.
* (3) Pints Motul Racing Brake Fluid.
Brake Pad Options
* Centric Ceramic Pads
* Hawk HPS Brake Pads (1 Piece Design)
* Hawk HP Plus Brake Pads (1 Piece Design)
Kit includes:
Brake Pad Options
__________________
TPSMotorsports.com
Mike Mak
2705 Lafayette Street
Santa Clara, CA 95050
Phone #: 408/898-4632
Email #: MikeM@TPSMotorsports.com
Authorized dealer of Corbeau Seats, ECS Superchargers, Edelbrock SuperChargers, A&A Superchargers, Kooks, Whipple, Magnalow, Corsa, Borla. LG Motorsports, Procharger, Billy Boat Exhaust, AWE Exhaust, American Racing, TPS Brake Rotors/ Kits, Stainless Steel Brake Lines & much more...Mike Mak
Supporting Vendor
St. Jude Donor '11
Best C6 Z06 Big Brake kit on the market. Our kits come with either slotted or cross drilled rotors which are coated to prevent rusting on the center hats and veins.
$2199.99 delivered to your door!
Supporting Vendor
St. Jude Donor '11
Are you looking for a set of C6 Z06 Brakes to upgrade your Vette? Check out our C6 Z06 Big Brake Kit for your C5 & C6! Choose from Red, Yellow, Charcoal, or Silver Calipers!
0% Financing is available for up to 1 year
If you don't like the colors we have we can customize the color to ANYTHING you like an extra $599.
Supporting Vendor
St. Jude Donor '11
Thanks for all the orders! In stock and ready to ship!
BEST BIG BRAKE KIT DEAL FOR AVAILABLE!
-Everything is included in your kit for a complete install!
0% Financing for up to 1 Year Available!
