NJ state inspection at a state run facility
Location: North/Central NJ - a.k.a. Gotti in the CFNE section
Received 1,528 Likes
St. Jude Donor '05
Hello,
Will my car with no front plate and tinted windows pass inspection? I know they changed what they inspect now, and basically just check for codes I think.
Car is a 2013, so its not old or anything.
St. Jude Donor '10
as long as they can plug into your under dash port you should be just fine. But watch for the police that may be working at the station, you see them there from time to time, as they could easily issue a ticket to you for the windows or lack of front plate. My cammed Z06 passed with headers and all, no front plate and tinted windows as well. Pull in with the windows down.
My C4 passed NJ state inspection with tinted windows, no front plate and reverse lights that don't work. No problem.
I wouldn't go back to the state run inspection, though... the guys couldn't figure out how to close my car's hood, so they decided brute force was the answer and they damaged my clutch. Idiots.
St. Jude Donor '05
Go to a private inspection station.
That's what i did on my other car. I had a front plate but tinted windows. When i pulled up the guy told me, "ohhhhh man tinted windows.......".
And i was like dude, "i'll roll them down, pretend you just never saw them", and laughed about it lol. And he was like, yeah that's true lol. And he proceeded. I paid 60 bucks and i was on my way.
I know state is free but if you have tinted windows and what not, sometimes it pays to go to a private inspection place.
I haven't ever had a problem at a state run inspection station, no front plate, headers, cammed, drilled out cats, emissions were fine. Good luck
NJ only tests for emissions now. As long as your CEL isn't on and there are no other codes activated, you can roll in there with bald tires, tinted windows, no front plate, no lights, squeaking brakes, cracked windshield, etc. and you'll still pass. I have a cam and headers w/cats and this past time they popped my hood then looked underneath for cats. They saw they were there and rolled me through. I also have no front plate and tinted windows/lights. I believe that is the 3rd inspection I've had with my current build (although this was the 1st time they looked for cats) and no issues either time.
I understand being nervous but I can't see going to a private garage and paying for a free service, that technically as a tax payer you've already paid for. I'm no more than 20' away when they're inspecting my car so I can offer guidance if they're having issues with anything. So far I haven't had any trouble taking my Vette or my truck through state inspection facilities. They both have tint, no front plate, and headers w/cats.
Retired & lovin' it!
I've been thru the state inspection station off Rt. 70 in Lakewood with headers, hi-flow cats & no front plate.....no problem! As others has noted, as long as the CEL is not lit & you pass the tail pipe sniffer test, you're good to go.
Yeah I have had tints on like 10 cars and it passes. They might frown at it but I also frown at their inability to smoothly operate a stick shift. Basically the only way you can fail is with a CEL
Also what is a "front plate"?
