Anybody Near Philadelphia to Help Diagnose Engine Problem?
So I have an 08 LS3 with ECS 2200, blower cam, ARH catted long tubes, and Meth. It started out with the "sputtering" or choppy sound when accelerating periodically. It would come and go for about a week. Now, it's always there and the car feels very sluggish. There is no CEL and I've even checked for codes, but there are none. I've cleaned the MAF and throttle body, made sure the intake filter was secure, and changes the engine oil. What's going on?
Also, I just removed each plug wire (AC Delco) and measured with a multimeter. They all measured right around 800 ohms.
AMP Racing
2023 C5 of the Year Finalist - Modified
2017 C5 of Year Finalist
St. Jude Donor '09-'10-'11-'12
Don't bang them out, just remove them. Sure it'll be loud, but you're only taking it for a test drive.
ECS tuned it. I think it was an injector not completely clipped in, because it's running normal again, for the most part. I'm getting high negative low term fuel trims at idle only and white smoke with a gassy smell from the exhaust
