FS Alpine F450 V12 5 channels that will run a FULL system in Stereo $200
I bought this amp new for about $450 1.5 years ago. It was in my commuter before I decided to run 2 amps. I used it to run a 6.5" componant set, 6X9's and 1 10" sub. The amp has 3 separate crossovers for each stage. It is one of the best 5 channel amps out there and would be perfect for a complete corvette install. Here are details below on it.
Let Alpine's 5-channel MRV-F450 V12 series amplifier deliver the juice to your entire speaker system. It provides 4-channel amplification to your main speakers, while a fifth channel drives your subwoofers.
The unstoppable power of this Alpine V12 Series amp comes from the massive transformers and fast MOSFET power supplies. Extra-large capacitors deliver additional current when needed to fuel musical peaks. The amps are built using Alpine's STAR Topology design to greatly reduce internal noise, keeping the signal clean so that your speakers can perform better.
Read More
The internal Bass Engine® provides built-in crossovers for adjusting the amplified frequencies. The subwoofer channel also has a subsonic filter and Bass EQ, which lets you tune the low frequencies for optimum effect in your vehicle. The top-mounted controls are conveniently hidden and protected by a flip-up top cover. Likewise, your cables are concealed under the front cover, which can be removed to save space.
Details:
50 watts RMS x 4 + 200 watts RMS x 1 at 4 ohms
60 watts RMS x 4 at 2 ohms + 200 watts RMS x 1 at 4 ohms
120 watts RMS x 2 + 200 watts RMS x 1 in bridged mode
2-, 3-, 4-, or 5-channel output
Tri-way capable (Tri-Way crossover required)
requires 8-gauge power and ground leads — wiring and hardware not included with amplifier
Bass Engine® features:
front and rear channels have variable 50-200 Hz high-pass/low-pass crossovers, 12 dB/octave
sub channel has a 30-200 Hz low-pass crossover, 12 dB/octave
selectable (15 Hz or 30 Hz) subsonic filter on the sub channel
tuned Bass EQ (6 dB bass boost at 50 Hz with adjustable Q factor, while frequencies below 30 Hz are cut by 6 dB) on the sub channel
MOSFET power supply
STAR Topology (minimizes internal noise and prevents ground interference)
oversized power and ground connections
gold-plated screw terminals
top-mounted controls with cover
detachable front cover
blue power LED
16-9/16"W x 2-1/2"H x 11-1/4"D (depth is 10" with front cover removed)
1-year warranty
Details:
5-channel car amplifier
requires 8-gauge power and ground leads - wiring and hardware not included with amplifier
MOSFET power supply
blue power LED
Read More
Details:
MOSFET power supply
blue power LED
1-year warranty
Details:
MOSFET power supply
blue power LED
It truly is a nice amp with a ton of features. I had it connected to my stock Nissan deck and it sounded great. Buy it and I will cut you a good deal on the install of everything. Daddy wants a set of Drag Radials so the Spoiler and Amp need to go. HAHA
