Northern California Northern California
Windshield washer fluid..
Old 12-10-2009, 12:02 PM
FastGhost
FastGhost's Avatar
Default Windshield washer fluid..
For anyone out there using a 50/50 water/methanol mixture, Walgreen has a sale on -20*Peak windshield washer/deicer fluid. Price is 2/$3.00 limited to 4 bottles.
Old 12-10-2009, 07:05 PM
BOTTOMS UP
BOTTOMS UP's Avatar
It's fine
Old 12-10-2009, 07:12 PM
Exotica
Support Corvetteforum!
Exotica's Avatar
Personally, I wouldn't use wiper fluid. Just buy methanol and mix it with 50 percent distilled water. Keep all the other crap out of your engine. It will be a little more expensive, but not much unless you are always in boost - in which case you are spending a fortune on fuel anyway so the small incremental cost won't be much of a difference.
Only reason I would buy wiper fluid would be as a backup in case you run out of meth and you need it as a safety net.
Just my 2 cents
Old 12-10-2009, 08:15 PM
BOTTOMS UP
BOTTOMS UP's Avatar
huh ?
is it for the wipers or water injection ?
Old 12-10-2009, 09:27 PM
FastGhost
FastGhost's Avatar
Originally Posted by BOTTOMS UP
huh ?
the 50/50 is in the wiper tank.
Old 12-10-2009, 09:30 PM
FastGhost
FastGhost's Avatar
Just my 2 cents
Correct, I'm not in boost often. I thought if this was comparable to the 50% mix It would save me the trouble of mixing the stuff. Keeping a bottle of the washer fluid as back up would be a good idea.
Thanks,
Old 12-21-2009, 03:42 PM
powderski13
powderski13's Avatar
I thought -20 windshield washer fluid was 40% methanol. I run 75% methanol in my tank for injection.
Old 12-22-2009, 12:03 PM
Kenny94945
Kenny94945's Avatar
For what it's worth.....
Personnally, over the years I have had issues (mostly clogging) with store bought premixed windshield washer fluids.
Since the C4 years I've used GM's Optikleen and mix it myself w/ distilled water in all makes and models of vehicles w/ no issues.
Old 12-22-2009, 05:04 PM
FastGhost
FastGhost's Avatar
Just my 2 cents
When does your methanol spray come on?
Old 12-22-2009, 08:42 PM
Exotica
Exotica's Avatar
Mine doesn't since I never ended up going boost and it won't work naturally aspirated (despite spending nearly $900 in parts and labor trying - based on the manufacturer's receommendations).
You should be able to get a progressive controller for it. That's what I bought for mine. Too bad I can't use it and they won't take it back!
Depending on what brand you have, I'll gladly give you a good deal on mine. It's brand new!
Old 12-23-2009, 10:59 AM
jpandes
jpandes's Avatar
Man, I thought you guys were raking about keeping the windshield clean
To Windshield washer fluid..
Quick Reply: Windshield washer fluid..
