TPS Slotted, Dimpled, or Cross Drilled Brake Rotors-w-Corr. Cooling Vanes-FREE SHIP!"
Supporting Vendor
St. Jude Donor '11
TPS Motorsports Brake Rotors
-Available in Slotted, Slotted/ Dimpled, & Slotted/ Cross Drilled
*Each rotor is made by Centric (Makers of Stoptech & Powerslot)
*Black, Gold OR Silver Zinc Coated
*1997-2004 Corvette-from $219.99
*2005-2012 Corvette (Z51)-from $359.99
*2006-2012 Corvette (Z06)-$399.99
PRICE INCLUDES 4 ROTORS SHIPPED TO YOUR DOOR!
Click here to place an order!
http://www.tpsmotorsports.com
Directional Cooling Vanes
Each base C5 C6 rotor is side and wheel specific which means the cooling vanes are venting the correct direction for maximum rotor cooling. Unlike other rotors these rotors are side specific with directional cooling vanes! Rotors with directional cooling vanes maximize the heat extraction from the rotors. Directional cooling vanes help reduce brake fading and extend rotor life.
TPS Motorsports from day one has always been about bringing the best value and service to our customers as possible. We are now proud to roll out our line of slotted/ cross drilled, slotted and slotted/dimpled rotors. These rotors are made by Centric, which is the parent company of Stoptech and are a very high quality rotor. Our rotors are FAR superior than lower priced “eBay” rotors. We have tested our rotors on customers street and open track vehicles.
Which Rotor is right for me?
One question which is always asked of me is which type of brake rotor is better.. slotted or cross drilled? Before answering this question we need to ask.. what type of driving do you do? If it is mostly a street car, then cross drilled rotors will be fine. Cross Drilled rotors main benefit is they look great and do offer some heat dissipation and a wiping effect of the pads when wet. The main disadvantages for cross-drilled rotors is they have a history of playing connect the dots.. cracking. If you are very hard on your brakes or take your car to the track I would suggest slotted rotors. Slotted Rotors on the other hand offer great heat dissipation. Better braking than cross-drilled because of increase braking surface over a cross drilled unit. Generally a solid rotor is 100% material touching the pad, slotted is about 92% and drilled is 85%. More braking surface means better braking power. SLOTTED ROTORS IS WHAT WE RECOMMEND FOR MOST CARS ESPECIALLY FOR OPEN TRACKING AND AUTO-X
Why don’t you recommend Cross Drilled Rotors?
Because they tend to crack over time when subject to heavy use. Most companies including Baer, Stoptech, AP Racing DO NOT recommend CROSS DRILLED ROTORS for track use. We offer it as an option BUT ONLY recommend it to customers who’s cars do not see much track duty. They also offer less braking surface than slotted rotors which means less braking power.
Why do you have Slotted/ Dimpled Rotors?
The main reason we offer Slotted/dimpled rotors is because they offer the desired look of cross drilled rotors for many customers without having the issues of cracking. This is a “compromise” option to have for those who like the cross drilled look without having to go with cross drilled rotors.
Do the rotors stay black or gold?
The black and gold coating is a special zinc coating to prevent the rotors from rusting. The colored zinc where the brake pad meets the rotor will be gone after driving about 50 miles while the rest of the rotor remains protected with zinc.
Here is the picture of the rotor AFTER about 50 miles of braking. The Black zinc coating will wear out on the surface where the pads meet.
__________________
TPSMotorsports.com
Mike Mak
2705 Lafayette Street
Santa Clara, CA 95050
Phone #: 408/898-4632
Email #: MikeM@TPSMotorsports.com
Authorized dealer of Corbeau Seats, ECS Superchargers, Edelbrock SuperChargers, A&A Superchargers, Kooks, Whipple, Magnalow, Corsa, Borla. LG Motorsports, Procharger, Billy Boat Exhaust, AWE Exhaust, American Racing, TPS Brake Rotors/ Kits, Stainless Steel Brake Lines & much more...Mike Mak
Supporting Vendor
St. Jude Donor '11
Click here to place your order for the rotors...
https://www.tpsmotorsports.com/catal...=271&mode=list
Click here to place you order on some great deals on pads...
Front & Rear Ceramic Pads-$99 Delivered to your door!
Hawk HPS Front & Rear Pads-$179.99 delivered to your door!
http://www.tpsmotorsports.com/corvet...akes/pads.html
Don't forget about your Stainless Steel Brake Lines for only $89.99 shipped to your door!
http://www.tpsmotorsports.com/catalo...anufacturer=40
ALL ORDERS SHIPPED FROM TPS HAVE FREE SHIPPING!
Supporting Vendor
St. Jude Donor '11
I'm glad your very happy with the transmission we rebuilt for you several months ago
BTW, I'm still pretty amazed how clean your car was. The undercarriage was clean enough to each off of AND that is NO EXAGGERATION!
Supporting Vendor
St. Jude Donor '11
So who needs some new rotors? We just upgraded ALL our rotors for the C5 and Base C6 (non-z51 and Z06) so now they will ALL have directional cooling vanes! Directional cooling vanes help with the extraction of heat for the rotors and help reduce brake fade and extend rotor life
Supporting Vendor
St. Jude Donor '11
So who needs some new rotors? These are the best rotors you can get for your money. Better than eBay rotors as these units have the correct cooling veins for maximum cooling on your rotors.
