New product for your C5 Corvette!
Supporting Vendor
Hi Everyone,
Here is SacCityCorvette’s latest version of the Cool It v2 and v3 Remote High Speed Fan Controller for your 1997-2004 C5 and C5 Zo6.
Now you can control your C5 Corvette's radiator high speed cooling fan with the simple push of a button on your wireless FOB, allowing you to control your radiator coolant temps. No need to pay for a expensive tune to change your fans on/off temperatures or running you’re A/C to cool the engine, along with all the unnecessary wear and tear and fuel mileage loss that goes along with running the A/C.
The Cool It v2 and v3 now run on their own circuit and will not interfere with the normal computer controlled operation of your cooling fans.
Installing the Cool It v2 and v3 is a very simple five minute plug and play installation. (See our installation video) After you install the Cool It v2 or v3, you will be able to turn on the right side cooling fan on in high speed mode using a wireless FOB making it perfect for when you are at the track and you want to cool down between runs, in traffic and idling in parades. It will even help keep your Automatic Transmission running cooler too!
Preseason Price Only $99.95
Here is a link with more information!
http://www.saccitycorvette.com/COOLITv2.html
__________________
Don't forget to check out our products at www.saccitycorvette.com
If you like our products, tell others! If not, tell us!
Supporting Vendor
Keep your C5 running cooler in traffic, it will love you for it!
Supporting Vendor
The Cool It also helps keep your automatic trans cool as well as the engine.
Supporting Vendor
With a Cool It v2/v3 there is no need to run your A/C to cool the engine, along with all the unnecessary wear and tear and fuel mileage loss that goes along with running the A/C.
Supporting Vendor
Hi inoyourtrippn
You should try one, they work really good. Here in California during the summer when its 100* plus when I'm in traffic I have tested the cool It by not turning the a/c on so the fans don't activate and instead of waiting for the fans to come on at 226* I turn on the Cool It and my temps stay between 196* and 205*. Its a good feeling. It works great when its not so hot out that you need the a/c but hot enough when your in traffic the you wish your Vette wasn't running at 226* or more.
Hi inoyourtrippn
Supporting Vendor
PM sent.
