FS: c6 oem rear tires, 1 front/rear rim, license plate frame
free: c6 oem rear tires, 1 front/rear rim
I have a couple items from my 2011 base c6. I went to get new tires (put 4 non-runflats on) installed because one of my front tires was balding on one side, and found out two of my rims were bent. I tossed the bent rims, and front tires (the other front didn’t have a ton of tread left). What I’m left with (hopefully to help someone else who runs into this problem) is one front rim 18x8.5, and one rear rim 19x10.0 (the rims have “speedline” stamped on the inside but I’m not sure what the right name for them is), plus two of the rear stock OEM Eagle Goodyear F1 Eagle EMT 285/35-19 run-flats. The rear tires were taken off around 15K miles, and still have a lot of tread left (probably 7 to 8 32nds). The tires are evenly worn and haven’t ever been repaired, the rims are perfect too minus one small pit (pencil head sized) on the rear rim (no curb rash).
Free to anyone who needs them. Also have a set of stock mufflers (not npp) free.
Thanks!
Thanks!
This would be a lifesaver - I could really use the tires... since I spent my savings to get the car itself!
Would you please send me a text or call at (408) 785-7031?
I've been trying to find a way for the past hour, but it seems corvetteforum won't let me send/receive PM's because I'm a new owner.
ingochris (08-10-2016)
