Can C7 Z51 rotors be turned due to wear ???
Does anyone know if C7 Z51 brake rotors can be turned if/when they need it due to wear or change in pads?
If so, how much can they be turned, legally, in California?
You turn a rotor due to uneven wear, not just wear. That said, it's unlikely that after a pad wears out that you'll have a perfectly worn rotor.
There's no reason they can't be turned, it depends on how much they've been worn and how much correction needs to be made.
The rotor will typically have a minimum width stamped onto it. IE if you have a 1.250" min width, the current width is 1.260 and there's 0.012" runout, correcting the runout would go beyond the minimum width of the rotor and it would have to be replaced.
If the car is seeing track use, it may make sense to stay well over the min width as a thinner rotor will be more prone to cracking.
thanks for your help, Shark, but I have always turned rotors when replacing worn pads if only to provide a fresh surface for the new pads to bite on. I appreciate that a thicker rotor will be less prone to cracking, but 10-20 thou(if that) should not create big cracking problems.
I like a vibration-free brake pedal and am very sensitive about rotors that are wavy.
