oil filter question
oil filter question
I went to Wal-Mart the other day to purchase an oil filter. I wanted to buy a PF-48, I couldn't locate one. Instead, I stumbled across a (AC DELCO) PF-48E. Does the PF-48E replace the 48? If so, what does the "E" stand for? BTW, they are just under $4.00 if anyone's interested. Thanks for your help clarifying this.
The "E" designates an E-core filter... It has to do with the internal tube/cage that is inside the filter that supports the filter media. It is a plastic material with large openings. Some people say they are fine, some avoid them like the plague. Myself, I avoid them and use the original PF48 with the metal tube..
Location: Freedom is never more than one generation away from extinction.
St. Jude '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-‘19-'20-'21-'22-'23-'24
Buy one of each and cut them open to see for yourself.
Then share some pics of what you find.
