Curb alert ??
The installation is super easy. Did mine on my C6 in under 30 minutes. The only difference I did was hook the power to the seat heater fuse so it turns off instantly when the car is off. If you were closer, I would help you install it. I know in the video is says to place the box around 20 inches from the sensor, but I found that this would cause false positives. I get more accurate warnings when I was between 12-15 inches.
On a side note, I found the voice in the video so boring…haha
