Northern California Northern California
Slicks
Old 07-16-2015, 09:53 PM
C5 LS7
C5 LS7's Avatar
Default Slicks
Going to start open tracking a bunch. What slicks should I go with?
Old 07-17-2015, 04:36 AM
Brandonkirk1994
Brandonkirk1994's Avatar
I have two kuhmo 710s for sale 265 for a 17 inch rim.
Old 07-17-2015, 11:42 AM
C5 LS7
C5 LS7's Avatar
I need 18's
Old 07-17-2015, 12:16 PM
RichieRichZ06
Supporting Vendor
Support Corvetteforum!
RichieRichZ06's Avatar
Location: Supporting the Corvette Community at Abel Chevrolet in Rio Vista, CA 707-374-6317 Ext.123
Received 1,425 Likes on 597 Posts
St. Jude Donor '08
I need 18's
I was very impressed with the new Hoosier R7. They seemed to grip better and wear looks slightly better compared to the R6. If you can run 315's all around, that is a good option because you can not only flip them inside out but also side to side but also front to back to increase life.
Old 07-17-2015, 05:02 PM
BoostedEBZ06
BoostedEBZ06's Avatar
How much experience do you have?
Old 07-17-2015, 07:22 PM
C5 LS7
C5 LS7's Avatar
Another friend of mine liked the R7's too. I run 315's all the way around now for AX. I found some PZero world challenge qualifying scrubs in 305 for $165 ea shipped, I think I might start with those then work my way up to new stuff.
Old 07-20-2015, 11:02 AM
RichieRichZ06
Supporting Vendor
St. Jude Donor '08
You have to be careful with running a full slick. You need a very aggressive alignment to make them work and they can be downright scary for the first couple laps. I would not recommend jumping from a street tire to those for your first few track days.
If you do get the Pirelli scrubs then make sure the diameter is correct for what you want. Some of those slicks have a very tall sidewall that will require raising the car up to clear.
Old 07-20-2015, 10:39 PM
C5 LS7
C5 LS7's Avatar
Thanks Rich, I'm going to run them at the AAS test track at Crows for a day in Aug. to see what they are like. They measure 25.75 in height, about the same as the Falkens I'm running. I am running 2 degrees neg front and 1 degree neg at rear, 0 toe front 1/8" toe in rear and max caster. Do you think that will work well?
Old 07-21-2015, 10:35 AM
RichieRichZ06
Supporting Vendor
St. Jude Donor '08
You will hate them on an auto x course. They will never get warm unless you get a chance to do 5-6 back to back laps. Most of those types of tires want -2.5 or -3.0 camber to wear evenly. Give them a try and see what you think though.
Old 07-21-2015, 12:22 PM
C5 LS7
C5 LS7's Avatar
Im going to run the practice course at Crows on 8/22. No one has been using it. On the last event (7/5) I got in 20 plus runs in an hour. Im hoping I can get to do that again in Aug. Thanks for the camber info, I bought the scrubs cheap, so if I kill them fast it won't break my heart, thats why I'm not buying new atm.
To Slicks
Quick Reply: Slicks
