383 Fired up!
383 Fired up!
Fitting to have my project come to fruition on the 4th of July...
Posted on the C2 section, but thought you'd all enjoy this too....
pretty proud at the moment.
Is2scooby (07-10-2016)
Sounds good. Flat tappet or roller lifters?
Full roller.
Forged Manley crank, Forged rods and pistons, 11:1 CR, AFR 195 Eliminator heads, Howards hyd roller cam. (.590/237*) gussied up to look like a stock factory 327 (except the obvious aluminum head facings)
Yes....when done it will have all of the factory ignition shielding...only the air cleaner will be from a 65....cant fit the 63/4 air cleaner on the Holley. Still...it will look factory for the non NCRS types...
