G2 Caliper Paint
G2 Caliper Paint
Has anyone used G2 to paint calipers? Thoughts? I want to leave the calipers on the car..... Also, I'd like to paint the raised CORVETTE letters black. I don't want to buy another kit just for the letters. Any thoughts....
I did them while on the car. no worries there as long as you are careful. For the raised letters, I simply wiped off the paint there and left them with the raw brushed aluminum look. Much better contrast against the red if thats what you are going for.
If you want the raised letters to be painted, I'd do those first, let it dry, and then paint the calipers using a pull-stroke up the sides of the raised letters to avoid splatter. If you do, you can just wipe off the excess while its still wet.
