What is the best way to cut a pad lock? - CorvetteForum - Chevrolet Corvette Forum Discussion
Off Topic
Off Topic | Non-Corvette
Old 04-02-2007, 06:07 PM   #1
1K SPORT
CF Senior Member
1K SPORT's Avatar
Default What is the best way to cut a pad lock?
I need to cut a master lock off and was wondering if bolt cutters or a cutting wheel would be better? I will need to buy whatever one will work better.
It's a Master combo pad lock. The Shackle is 9/32".
This is a serious issue, I can't get to my beer!
Thanks.
1K SPORT is offline   Reply With Quote
Old 04-02-2007, 06:10 PM   #2
00Nassau
CF Senior Member
St. Jude Donor '11
00Nassau's Avatar
You might try just taking a hammer to it if what it is connected to will take the force. I have opened a couple of locks in the past that way.
00Nassau is offline   Reply With Quote
Old 04-02-2007, 06:11 PM   #3
Rapid Roger
CF Senior Member
Rapid Roger's Avatar
if you are going to buy something....Go with an angle grinder...You will find many other uses where bolt cutters aren't used that often......
Rapid Roger is offline   Reply With Quote
Old 04-02-2007, 06:11 PM   #4
Aflac
CF Senior Member
Cruise-In 5, 6 & 10 Veteran
St. Jude Donor '09
Aflac's Avatar
either bolt cutters or cut the hasp...
Aflac is offline   Reply With Quote
Old 04-02-2007, 06:16 PM   #5
Gipper
CF Senior Member
St. Jude Donor '12
Gipper's Avatar
bolt cutters. Wear safety glasses and snap em like buttah!
Gipper is offline   Reply With Quote
Old 04-02-2007, 06:20 PM   #6
fatboytc88
CF Senior Member
roto zip tool. use a grinding wheel per application. - metal cutting wheel.
fatboytc88 is offline   Reply With Quote
Old 04-02-2007, 06:20 PM   #7
TPFKATK
CF Senior Member
Support Corvetteforum!
TPFKATK's Avatar
I gotta go with the angle grinder.
Or .308 Win.
TPFKATK is online now   Reply With Quote
Old 04-02-2007, 06:20 PM   #8
Diego M
CF Senior Member
Diego M's Avatar
Grinder, acetylene torch, or bolt cutters. whichever one you can get to first
Diego M is offline   Reply With Quote
Old 04-02-2007, 06:26 PM   #9
tumbleweed
CF Senior Member
tumbleweed's Avatar
Location: "There's a he11 of a lot of things they didn't tell me when I signed on this outfit....... i'm practicing to be a grouchy old man, and getting good at it....
I would go with the grinder if you need to cutthe lock.....but as someone else said, sometimes it's easier to cut the hasp.....
tumbleweed is offline   Reply With Quote
Old 04-02-2007, 06:32 PM   #10
grapeknutz
CF Senior Member
St. Jude Donor '06
A pound of thermite will do!
grapeknutz is offline   Reply With Quote
Old 04-02-2007, 06:33 PM   #11
383_Proof
CF Senior Member
383_Proof's Avatar
Quote:
+10000
I used a dremel to do the exact same thing this past weekend....took about 2 minutes to cut through...
383_Proof is offline   Reply With Quote
Old 04-02-2007, 06:34 PM   #12
boracayjohnny
CF Senior Member
boracayjohnny's Avatar
Location: You should have told him it would not hit 185 if you dropped it out of the back of a C130 with 4 heffalumps inside trying to get to the Golden Corral.
Quote:
Originally Posted by TPFKATK View Post
Or .308 Win.
I like the way you're thankin'.
Also, you could go with a D-9 Caterpillar or 10 sticks of dynamite.
boracayjohnny is offline   Reply With Quote
Old 04-02-2007, 06:36 PM   #13
jfb
CF Senior Member
Small bolt cutters may not do the job (too much effort), but a bolt cutter will go through a Master lock! I've done it.
jfb is offline   Reply With Quote
Old 04-02-2007, 06:36 PM   #14
1K SPORT
CF Senior Member
1K SPORT's Avatar
There is no hasp.
The lock has a long shackle. It is on a side by side refrigerator around the door handles.
Thanks for the suggestions. A grinder looks like it could be fun...
Old 04-02-2007, 06:37 PM   #15
scorp508
CF Senior Member
scorp508's Avatar
Or .308 Win.
Not according to Mythbusters!
scorp508 is offline   Reply With Quote
Old 04-02-2007, 06:38 PM   #16
1K SPORT
CF Senior Member
1K SPORT's Avatar
Are the biggest bolt cutters 24"?
Old 04-02-2007, 06:38 PM   #17
PRNDL
CF Senile Member
PRNDL's Avatar
Why don't you just ask Mommy nicely for the key?
PRNDL is offline   Reply With Quote
Old 04-02-2007, 06:40 PM   #18
SteveR.
CF Senior Member
SteveR.'s Avatar
A Dremel or hammer will work.
SteveR. is offline   Reply With Quote
Old 04-02-2007, 06:40 PM   #19
Torqaholic
CF Senior Member
St. Jude Donor '09
Torqaholic's Avatar
44mag with 300gr XTP works and is fun too. Wasn't a combination lock though, it was keyed and had a short shank. Bullet placement on the top pushed it apart on the first try.
Torqaholic is offline   Reply With Quote
Old 04-02-2007, 06:41 PM   #20
Gipper
CF Senior Member
St. Jude Donor '12
Gipper's Avatar
Quote:
biggest I've seen at Home Depot anyway. They'll cut it no problem.
Go Back   CorvetteForum - Chevrolet Corvette Forum Discussion >
Reload this Page
  • What is the best way to cut a pad lock?
    Related Topics
    Thread Thread Starter Forum Replies Last Post
    99 C5 Brake is spongy after Pad replacement aerovette99 C5 Tech 6 08-22-2015 08:45 PM
    Improving brakes vipervetteguy C1 & C2 Corvettes 19 09-23-2014 10:46 PM
    Brake pedal not returning all the way up for a while Rocket22 C4 General Discussion 0 07-26-2010 01:20 PM
    My polish review: 1)The Compounds TH0001@properautocare.com Car Care Discussion 12 03-19-2008 10:39 PM
    What's wrong with our brakes??? norvalwilhelm C3 Tech/Performance 89 08-23-2004 12:13 AM
    Tags
    avoid, bolt, buy, combination, cut, cutters, cutting, hasp, lock, master, masterlock, pad, paddle, padlock, rotozip
    Search this Thread:
    Click for Advanced Search
    Posting Rules
    You may not post new threads
    You may not post replies
    You may not post attachments
    You may not edit your posts
    BB code is On
    Smilies are On
    [IMG] code is On
    HTML code is Off
    Trackbacks are Off
    Pingbacks are Off
    Refbacks are Off
    Forum Jump
    • Ask a Question
    What's your question?
    Send
