Pumping gas pedal when starting car w/ fuel injection - CorvetteForum - Chevrolet Corvette Forum Discussion
Register FAQ Search Today's Posts Mark Forums Read Vendor Directory
Off Topic
Off Topic | Non-Corvette
View Poll Results: Pumping; is it bad?
Won't hurt the car 13 43.33%
DON'T DO IT! 17 56.67%
Voters: 30. You may not vote on this poll
Old 05-12-2007, 01:00 AM   #1
Lord Odin
CF Senior Member
Lord Odin's Avatar
Default Pumping gas pedal when starting car w/ fuel injection
I have heard that pumping the gas pedal when a car that has fuel injection and is having trouble starting is bad for the car. No explanation as to why but only that it is bad and fuel injection should handle the problem by itself, unlike vehicles with carburetors. What is so bad about pumping the gas?
If the injectors are getting clogged, wouldn't pumping the pedal actually help it in that circumstance?
Lord Odin is offline   Reply With Quote
Old 05-12-2007, 01:08 AM   #2
CGGorman
CF Senior Member
CGGorman's Avatar
In some case, the ECU will shut down the injectors if you WOT during cranking. This is a routine inserted to help clear a flooded engine.
Oherwise, I don't know a reason why pumping would help OR hurt.
CGGorman is offline   Reply With Quote
Old 05-12-2007, 01:16 AM   #3
CGGorman
CF Senior Member
CGGorman's Avatar
Injectors are basically just electric switches. They either spray or not, depending on te presence of electrical current. The only real variable with a given injector is how long the "switch" is allowed to remain off or on. The throttle in most EFI car until very recently was electromechanical. Mech. in that it opened and closed the throttle blades just like on a carb. Electrical in that there is a sensor mounted on the throttle butterfly shaft that tells the computer how far open the throttle is. The computer uses that info, plus more info from various other sensors (air flow, air temp, crank position+RPM, etc.) to determine how to switch the injectors.
Pumping the throttle is useless in a EFI engine. If it won't start, there is a real problem somewhere.
On a carbureted engine, your foot controls a helluva lot more, such as the choke position and enrichment (squirt of raw fuel for each press of the pedal). The fuel delivery is "dumb". It relies completely upon engine vacuum or your foot (or both) to get fuel out of the fuel bowl.
A cold engine needs a richer mixture to start and run smoothly. On EFI cars, that is handled by the computers. On Carb'd engines, it's the choke. Most people don't have a freakin' clue how to tune a carb to run when the engine is warm, let alone when it's cold or during the transition between the two. Often, that means not enough fuel during cold start, so pumping the throttle will squort a bunch extra in there. It will just lay in the intake for a bit, but it;s enough to get the car running.
Old 05-12-2007, 01:20 AM   #4
vttedrm
CF Senior Member
vttedrm's Avatar
My answer is Both. It won't really hurt the car (may flood) but I don't do it.
vttedrm is offline   Reply With Quote
Old 05-12-2007, 01:20 AM   #5
Fastbird
Former Sponsor
C5 of Month Finalist 2016
C5 of Month Finalist 2015
I Believe In The Beer Fairy
Fastbird's Avatar
Exactly. There's no point to pump the pedal on a fuel injected car UNLESS you know the engine is flooded and you need to clear out the cylinders. Even in that case you simply hold the pedal to the floor until the car starts.
Fastbird is offline   Reply With Quote
Old 05-12-2007, 01:31 AM   #6
gpracer1
CF Senior Member
gpracer1's Avatar
Quote:
Most injected cars have a "clear flood mode". If you hold the pedal down all the way and then crank the car, the injectors do not squirt fuel.
gpracer1 is offline   Reply With Quote
Old 05-12-2007, 01:32 AM   #7
scorp508
CF Senior Member
scorp508's Avatar
C4s put you into a flood clear mode and don't fire the injectors with the pedal at WOT during cranking.
scorp508 is offline   Reply With Quote
Old 05-12-2007, 01:36 AM   #8
comp
CF Senior Member
comp's Avatar
best to try to start 3 times (short cranks) No start smell for fuel,,,turn key on press one time then crank
comp is offline   Reply With Quote
Old 05-12-2007, 02:56 AM   #9
Buffalo Dude
CF Senior Member
St. Jude Donor '07
Buffalo Dude's Avatar
What he said.
Buffalo Dude is offline   Reply With Quote
Old 05-12-2007, 08:46 AM   #10
Lord Odin
CF Senior Member
Lord Odin's Avatar
So there is no possible way of pumping the gas pedal to hurt the car with EFI?
Old 05-12-2007, 08:56 AM   #11
Torqaholic
CF Senior Member
St. Jude Donor '09
Torqaholic's Avatar
If you're wanting to pump the pedal due to problems starting a cold vehicle try turning the key to the on position and waiting a few seconds for the fuel pump to pressurize the system before cranking it over.
Torqaholic is offline   Reply With Quote
Old 05-12-2007, 09:34 AM   #12
Tom/99
CF Senior Member
Tom/99's Avatar
You don't need to touch the gas pedal when starting a fuel injected car.
Tom/99 is offline   Reply With Quote
Old 05-12-2007, 10:27 AM   #13
Muffin
CF Senior Member
Muffin's Avatar
What CGGorman said with one small addition:On a MAF car the ECM, through the TPS, reads not only how far the throttle plates are open but also the rate at which the opening is changing. If you pump the gas pedal while the car is starting the ECM can, in a sense,become confused.
Muffin is offline   Reply With Quote
Go Back   CorvetteForum - Chevrolet Corvette Forum Discussion >
Reload this Page
  • Pumping gas pedal when starting car w/ fuel injection
    Related Topics
    Thread Thread Starter Forum Replies Last Post
    1985 Corvette hard to start HughG C4 Tech/Performance 32 04-20-2014 01:03 PM
    car wont start bad fuel pump ? takovr C4 General Discussion 8 04-20-2013 10:29 AM
    Hard to start C4 rsovine C4 Tech/Performance 11 10-08-2009 11:19 AM
    62 Fuel Injection Help redhot62 C1 & C2 Corvettes 5 10-15-2008 02:52 PM
    I need a new gas tank! 69 Vette C3 Tech/Performance 7 06-16-2007 10:29 AM
    Tags
    bad, car, efi, fuel, gas, injected, injection, pedal, press, problems, pump, pumping, start, starting, touch
    Search this Thread:
    Click for Advanced Search
    Posting Rules
    You may not post new threads
    You may not post replies
    You may not post attachments
    You may not edit your posts
    BB code is On
    Smilies are On
    [IMG] code is On
    HTML code is Off
    Trackbacks are Off
    Pingbacks are Off
    Refbacks are Off
    Forum Jump
