Graphite lubricant in car's ignition cylinder? - CorvetteForum - Chevrolet Corvette Forum Discussion
Off Topic
Off Topic | Non-Corvette
Old 09-05-2007, 01:15 AM   #1
SteveR.
CF Senior Member
SteveR.'s Avatar
Default Graphite lubricant in car's ignition cylinder?
Is it OK to use graphite lubricant in a car's ignition cylinder? This is on my wife's '06 Vue. The key is a little stiff in the ignition cylinder. I know some of these have electronics inside, and it wouldn't be good to get graphite on the electronics. This key doesn't have a chip (that I can see, no contacts, etc.). So is it normal to lube a car's ignition cylinder with graphite? Am I going to cause more problems than I solve?
SteveR. is offline   Reply With Quote
Old 09-05-2007, 01:18 AM   #2
jabez
CF Senior Member
jabez's Avatar
Do both keys stick?
jabez is offline   Reply With Quote
Old 09-05-2007, 01:19 AM   #3
SteveR.
CF Senior Member
SteveR.'s Avatar
Quote:
Originally Posted by jabez View Post
Do both keys stick?
All keys are "rough" going into the cylinder. I don't believe it is a worn key.
Old 09-05-2007, 01:21 AM   #4
e3pres
CF Senior Member
St. Jude Donor '08-'09
e3pres's Avatar
I've used it on a couple of old cars (i.e. 60's-70's) with no problems. I would think that as long as is doesn't have VATS or something similar that it would be okay.
e3pres is offline   Reply With Quote
Old 09-05-2007, 01:25 AM   #5
vetteweiser
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'13- '14
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Cruise-In VIII Veteran
Support Corvetteforum!
vetteweiser's Avatar
06, should be under warranty. I wouldnt put any graphite in it I'd just bring it back to the dealer. Or Costco...
vetteweiser is offline   Reply With Quote
Old 09-05-2007, 01:28 AM   #6
Demonic85
CF Senior Member
Demonic85's Avatar
My key does that sometimes on my '07 Focus, I just give it a little wiggle and it pops right out. I think its just cause its newish.
Demonic85 is offline   Reply With Quote
Old 09-05-2007, 02:59 AM   #7
indy99
CF Senior Member
indy99's Avatar
Location: the land of a never ending frame-off resto-mod. May Visa have mercy on my soul.
Quote:
Just so you know.....the Focus is notorious for ignition key problems, it requires an ignition key cylinder switch replacement. Newish is not the problem. Get it repaired now before you get stranded. I KNOW.
indy99 is offline   Reply With Quote
Old 09-05-2007, 03:01 AM   #8
ZippoMan
CF Senior Member
ZippoMan's Avatar
pure graphite spray is fine for keys, don't use WD40 though.
ZippoMan is offline   Reply With Quote
Old 09-05-2007, 03:04 AM   #9
Joe0121
CF Senior Member
St. Jude Donor '06
Joe0121's Avatar
Quote:
At my old job we had an old Ford van and the key would stick all the time. The SSgt in the Ops section was the only one who new how to get the darn thing out, so it would stick and I'd park it at the shop and walk by his office and say "Damn key is stuck again" Next day the Key would magically be out of the ignition and all would be well.
Joe0121 is offline   Reply With Quote
Old 09-05-2007, 06:52 AM   #10
bowtiebandit
CF Senior Member
bowtiebandit's Avatar
Quote:
It's a known issue with this body style, there is a TSB on it for the Equinox so I imagine it would cross over also. Your supposed to pull the cylinder and lubricate the housing if memory serves, can't remember my password to Dealerworld or I'd post it for ya.
bowtiebandit is offline   Reply With Quote
Old 09-05-2007, 09:14 AM   #11
repo
CF Senior Member
St Jude Donor '14-'15
repo's Avatar
Location: I wish I didn't sleep so late I used to be carried in the arms of cheerleaders
Short term fix. Don't do it.
repo is offline   Reply With Quote
Old 09-05-2007, 11:45 AM   #12
CGGorman
CF Senior Member
CGGorman's Avatar
Did you try deburring the keys on a wire wheel? Round over the sharp edges a hair and they should slide in easier...
CGGorman is offline   Reply With Quote
Old 09-05-2007, 12:33 PM   #13
rws.1
CF Senior Member
rws.1's Avatar
yes it can be used...
rws.1 is offline   Reply With Quote
Old 09-05-2007, 02:05 PM   #14
SteveR.
CF Senior Member
SteveR.'s Avatar
Quote:
Seems that way to me too, but I've used dry graphite lube on door locks and it seemed to last years.
I may try minor key deburring, don't want to wear the key out though.
Is the cylinder lube used in the TSB just a standard dry graphite lube?
How difficult is it to remove a key cylinder?
Old 09-05-2007, 02:08 PM   #15
Chicago
CF Senior Member
St. Jude Donor '15
Chicago's Avatar
Quote:
Chicago is offline   Reply With Quote
Old 09-05-2007, 02:08 PM   #16
Entropy
CF Senior Member
Entropy's Avatar
Many vehicles today use magnetic recognition, and the graphite might screw that up.
It's under warranty take it in.
Pulling a key cylinder used to be easy, but as a theft deterrent it's much more complicated these days.
Entropy is offline   Reply With Quote
Old 09-05-2007, 02:12 PM   #17
SteveR.
CF Senior Member
SteveR.'s Avatar
3yr/36k mile warranty, ~37k on the car.
Old 09-05-2007, 03:54 PM   #18
bowtiebandit
CF Senior Member
Call the dealer and asl if they'd consider covering it. I know here 1k it wouldn't be an issue to cover it,especially with known problems.
PM me your email addy and I'll send you what I can TSB wise..probably wont be until tomorrow though. I'd try a new key first though.
As far as the grease..it's usually red and I have no clue whats in it.
Old 09-05-2007, 04:22 PM   #19
jfb
CF Senior Member
Graphite won't hurt a magnetic strip, but if the key has a pellet like our Corvette keys do or if there is any kind of electronics in the key, I would not use graphite!!! Graphite is a good conductor of electricity. Call a dealer and ask if graphite can be used on the lock cylinder.
jfb is offline   Reply With Quote
Old 09-05-2007, 05:40 PM   #20
SteveR.
CF Senior Member
SteveR.'s Avatar
Thanks, will do.
Go Back   CorvetteForum - Chevrolet Corvette Forum Discussion >
Reload this Page
  • Graphite lubricant in car's ignition cylinder?
    Related Topics
    Thread Thread Starter Forum Replies Last Post
    What kind of lubricant for a radiator fan? ZippoMan Off Topic 4 07-05-2008 05:49 PM
    O/T ARCO Graphite Motor Oil SILENT BOB C1 & C2 Corvettes 6 11-16-2007 07:27 PM
    My Exhaust Manifold Graphite Lube Coating Technique paul 74 C3 Tech/Performance 38 08-15-2004 07:30 AM
    Can you lubricate ignition lock cylinder? jackdaroofer C4 Tech/Performance 3 09-04-2001 10:45 PM
    Lubricating Your Strg Column Ignition Lock Cylinder Jim Shea C3 Tech/Performance 4 08-10-2001 05:14 PM
    Tags
    car, cylinder, graphite, hurt, ignition, ignitions, lock, lube, lubricant, lubricate, lubrication, remove, stiff, stuck, switch
    Search this Thread:
    Click for Advanced Search
    Posting Rules
    You may not post new threads
    You may not post replies
    You may not post attachments
    You may not edit your posts
    BB code is On
    Smilies are On
    [IMG] code is On
    HTML code is Off
    Trackbacks are Off
    Pingbacks are Off
    Refbacks are Off
    Forum Jump
    • Ask a Question
    What's your question?
    Send
