Replacing a front Wheel Bearing/Hub on my 2001 Tahoe this weekend.. Need Info - CorvetteForum - Chevrolet Corvette Forum Discussion
Off Topic
Off Topic | Non-Corvette
Old 09-26-2007, 05:55 PM   #1
chuckster
CF Senior Member
chuckster's Avatar
Default Replacing a front Wheel Bearing/Hub on my 2001 Tahoe this weekend.. Need Info
It's a 2 wheel drive Tahoe. Grinding sound from drivers side, increases with speed.. not the brakes.
What I need is the Bolt sizes so Imake sure I have the right tools...
There are 3 bolts that hold it to the spindle..What other extra large size bolts do I need to be aware of? What size and type are they? Any gotchas or just straight forward?
chuckster is offline   Reply With Quote
Old 09-26-2007, 06:18 PM   #2
ddecart
CF Senior Member
SPARTAN
CI 3-4-5-6-8-9-10 Vet
CI-9 AutoX Winner
CI-3 Go Kart Champ
St. Jude '03-'04-'05-'06-'07-'08-'09-'10-'11
ddecart's Avatar
Bolt sizes or socket sizes?
10, 13, 15, 18, 19, 21 (or 13/16)mm sockets will take off just about everything on a GM car.
ddecart is offline   Reply With Quote
Old 09-26-2007, 06:41 PM   #3
chuckster
CF Senior Member
chuckster's Avatar
Someone on a tahoe forum mentioned something large like 1 3/4" But I think they may have been referring to the hub nut only found on the 4 wheel drive model..
Old 09-26-2007, 06:44 PM   #4
Entropy
CF Senior Member
St. Jude Donor '08-'09
Entropy's Avatar
Quote:
Yeah it's either that or something like 32,34 or 36 mm (I can't remember).
I've never done a hub replacement on a 2WD model. Not too many of those in the snow states.
Entropy is offline   Reply With Quote
Old 09-26-2007, 06:44 PM   #5
C5Nate
CF Senior Member
Support Corvetteforum!
Kansas City Area Coordinator
St. Jude Donor '08-'09-'10-'11,'13
C5Nate's Avatar
Are you positive its not the little wear indicator on your brake pads.
The noise they make is very similar.
C5Nate is offline   Reply With Quote
Old 09-26-2007, 06:51 PM   #6
chuckster
CF Senior Member
chuckster's Avatar
Postitive.. It's a very similar feel and sound to when a brake pad is totally gone and its metal on metal grinding sound..
Like Cshhhhhh..Cshhhhhh...Cshhhhhh...Cshhhhhh that gets faster as I drive and slower when I slow down.. BUT... NO change in sound hitting the brakes..and gets worse turning.. I wish it were the pads...
Old 09-26-2007, 06:52 PM   #7
chuckster
CF Senior Member
chuckster's Avatar
Luckily I am only 2 wheel drive.. no worries..
Old 09-26-2007, 07:35 PM   #8
jack_squat
CF Senior Member
jack_squat's Avatar
You'll need a 5mm allen socket to remove the ABS sensor from the hub unless you have a new bearing cartridge that includes the sensor and pigtail. Some come with it (Genuine GM), some don't.
jack_squat is offline   Reply With Quote
Old 09-26-2007, 08:06 PM   #9
jcswm
CF Senior Member
jcswm's Avatar
if its louder on a left turn.... it's the right side hub
if its louder on a right turn.... it's the left side hub
2wd is very easy... one Beer job.... 2 beers if you take your time!!
jcswm is offline   Reply With Quote
Old 09-26-2007, 10:34 PM   #10
chuckster
CF Senior Member
chuckster's Avatar
Just jacked up each side tonight.. Its the driver side...
If I shake the wheel from top and bottom.. It's loose... and spins noisily..
The Passenger side is tight and smooth...
Looks like I know what I will be doing Saturday...
Old 09-26-2007, 10:48 PM   #11
jcswm
CF Senior Member
jcswm's Avatar
WOW.... your lucky!!! they've come WAY down in price
Advance and Discount both have them under $150.00
last one I did was over $400.00!!!
Old 09-26-2007, 10:54 PM   #12
AZ Z51
CF Senior Member
St. Jude Donor '05
AZ Z51's Avatar
I know some of those are bolted in with a negative torx socket
AZ Z51 is offline   Reply With Quote
Old 09-26-2007, 11:23 PM   #13
chuckster
CF Senior Member
chuckster's Avatar
Autozone... $144!!!
Old 09-26-2007, 11:24 PM   #14
chuckster
CF Senior Member
chuckster's Avatar
Quote:
That is what my original post is about. I dont want to get a surprise.. I am pretty sure the calipers have a huge torx bolt but not sure about the Spindle..
Old 09-27-2007, 11:35 AM   #15
jack_squat
CF Senior Member
jack_squat's Avatar
Calipers have a T55 TORX. You'll need a BIG breaker bar for them and the caliper bracket bolts. They're put on by Superman at the factory.
Old 09-28-2007, 08:57 AM   #16
AZ Z51
CF Senior Member
St. Jude Donor '05
AZ Z51's Avatar
you should be able to look at the back side of the spindle and see whats holding in the bearing with out taking it all apart.
Old 09-28-2007, 09:09 AM   #17
steck
CF Senior Member
steck's Avatar
yup, i paid a fortune too on my 2001 yukon. came as a whole 'assembly'.
it was causing my ABS to engage all the time as i came to a stop !!
cant help ya on the nut sizes....mechanic did it for me
steck is offline   Reply With Quote
Old 09-28-2007, 09:18 AM   #18
Son93SL2
CF Senior Member
Son93SL2's Avatar
I've never seen a 1 3/4" bolt on a regular car, a coal strip mining dump truck yes, Tahoe, no.
Son93SL2 is offline   Reply With Quote
Old 09-28-2007, 09:36 AM   #19
AZ Z51
CF Senior Member
St. Jude Donor '05
AZ Z51's Avatar
Quote:
the axel nut is pretty damn big
Old 09-28-2007, 10:13 AM   #20
scottycards
CF Senior Member
St. Jude Donor '08-'09-'10-'11-'12-'13
scottycards's Avatar
Just a guess- is this thing a Unit Bearing? Three ~1/2" (or metric equiv) twelve point bolts that hold it on to the knuckle?
If so, pull caliper, 36mm socket for spindle, pull spindle, then the three 12 pt bolts for unit bearing, then BFH to remove unit bearing, reverse to replace.
If it's not a unit bearing, forget everything I just typed........
scottycards is online now   Reply With Quote
Go Back   CorvetteForum - Chevrolet Corvette Forum Discussion >
Reload this Page
  • Replacing a front Wheel Bearing/Hub on my 2001 Tahoe this weekend.. Need Info
    Related Topics
    Thread Thread Starter Forum Replies Last Post
    '04 Chevrolet Tahoe Z71, Rust Free TX Truck, Excellent, Books/Receipts/Window Sticker Closer_2001 Other Cars 2 04-10-2015 12:35 AM
    Corvettes at Lake Tahoe this Year? Sunnyvale Dave Northern California 2 04-15-2014 12:35 PM
    Doughboy steering wheel Tahoe Dave C6 Corvette General Discussion 45 11-27-2013 06:20 PM
    Chevy Tahoe Feedback Denvrvette Other Cars 19 07-25-2013 12:05 PM
    5.3L supercharger wanted... Sunqueen C5 Forced Induction/Nitrous 15 01-03-2004 02:24 PM
    Tags
    2001, 2002, 2007, bearing, front, hub, remove, replace, size, sizes, socket, tahoe, torque, wheel, wrench
    Search this Thread:
    Click for Advanced Search
    Posting Rules
    You may not post new threads
    You may not post replies
    You may not post attachments
    You may not edit your posts
    BB code is On
    Smilies are On
    [IMG] code is On
    HTML code is Off
    Trackbacks are Off
    Pingbacks are Off
    Refbacks are Off
    Forum Jump
