How to convert 250V 20A outlet to 110V 20A? - CorvetteForum - Chevrolet Corvette Forum Discussion
Off Topic
Off Topic | Non-Corvette
Old 12-12-2008, 12:46 PM   #1
ProfMoriarty
CF Senior Member
ProfMoriarty's Avatar
Default How to convert 250V 20A outlet to 110V 20A?
In my "new" digs, there is apparently 250V (220V?) 20A service in the garage above where I've positioned my work bench.
The outlet looks like this:
I don't have any use for that voltage, but could definitely use 110V 20A for my compressor, etc.
What do I need to do to convert to 110V 20A?
TIA
ProfMoriarty is offline   Reply With Quote
Old 12-12-2008, 12:48 PM   #2
Umrswimr
CF Senior Member
St. Jude Donor '05
Umrswimr's Avatar
Location: Overwhelmed as one would be, placed in my position.... DFW, TX
An electrician.
Umrswimr is offline   Reply With Quote
Old 12-12-2008, 12:48 PM   #3
cadams
CF Senior Member
cadams's Avatar
you need a step down transformer.
cadams is offline   Reply With Quote
Old 12-12-2008, 01:09 PM   #4
ProfMoriarty
CF Senior Member
Quote:
Thanks, but what the hell good is this guy gonna do me?
Old 12-12-2008, 01:11 PM   #5
MTVette
CF Senior Member
MTVette's Avatar
Quote:
Originally Posted by Umrswimr View Post
An electrician.
Rather than using a transformer, just re-do the circuit breaker panel to connect the line to a 110 position on the panel and put in a different outlet in the workshop.
MTVette is offline   Reply With Quote
Old 12-12-2008, 01:13 PM   #6
ProfMoriarty
CF Senior Member
Quote:
How would I do that?
Install a 110V20A breaker into an empty slot and install a new outlet?
The current outlet is 3 wire 12 ga.
Old 12-12-2008, 01:13 PM   #7
jfb
CF Senior Member
I agree, you can even use the same wires that are in place! All you need is a 20 amp breaker and a new outlet. You will probably have to run a ground wire to the outlet.
jfb is offline   Reply With Quote
Old 12-12-2008, 01:16 PM   #8
1Patriot
CF Senior Member
1Patriot's Avatar
Is the current outlet 3 or 4 wire? You may be able to retag the wires and change the connections at each end.
1Patriot is offline   Reply With Quote
Old 12-12-2008, 01:18 PM   #9
mardyn
CF Senior Member
mardyn's Avatar
I've got a similar situation over in my equipment barn. I simply installed another box/outlet adjacent to the 220V plug, and used one side of the 110 line + the neutral and ground wires to the the 110 outlet... simple and took about 15 minutes to complete, plus I still have the 220V plug to run the air compressor or welder.
but, be freakin' careful when screwing with the installation... turn of the damn 220V breaker before even thinking about getting started.
Good Luck
mardyn
mardyn is online now   Reply With Quote
Old 12-12-2008, 01:19 PM   #10
N8sFavToy
CF Senior Member
N8sFavToy's Avatar
Quote:
That's a top-of-the-line transformer. Step down transformer would be like Bumble Bee.
N8sFavToy is offline   Reply With Quote
Old 12-12-2008, 01:20 PM   #11
utah997
Circles are Hard
Support Corvetteforum!
St. Jude Donor '07-'08-'09-'10-'11-'12-'13
utah997's Avatar
An electrician.
Roger that.
utah997 is offline   Reply With Quote
Old 12-12-2008, 01:22 PM   #12
ProfMoriarty
CF Senior Member
Quote:
Originally Posted by utah997 View Post
Roger that.
Who is this Roger the electrician of whom you speak?
Old 12-12-2008, 01:22 PM   #13
ProfMoriarty
CF Senior Member
dbl tap
Old 12-12-2008, 01:24 PM   #14
jfb
CF Senior Member
Can't your read? The electricians name is Roger That!
Old 12-12-2008, 01:24 PM   #15
00Nassau
CF Senior Member
St. Jude Donor '11
00Nassau's Avatar
You might want to look at this website to understand what is currently there:
http://220outlet.com/
00Nassau is offline   Reply With Quote
Old 12-12-2008, 01:25 PM   #16
Z064life
CF Senior Member
St. Jude Donor '06
Z064life's Avatar
please post a pic of the outlet...it is really easy if you have single phase 220, if you have dual phase you will have an extra wire, but that can be dealt with easily.
Z064life is offline   Reply With Quote
Old 12-12-2008, 01:28 PM   #17
ProfMoriarty
CF Senior Member
Good Luck
mardyn
IIRC, 220V service has 2 hot wires which would test at 110V each.
But this is where I get confoozled. I can see using one of the hot wires, a neutral, and ground to a separate 110V outlet, but I don't see how that would allow the 220 line to remain active if the neutral and ground have been utilized to wire the 110V outlet.
Old 12-12-2008, 01:28 PM   #18
C5Nate
CF Senior Member
Kansas City Area Coordinator
St. Jude Donor '08-'09-'10-'11,'13
C5Nate's Avatar
Good Luck
mardyn
Thats a fire or death waiting to happen.
Your original 220 breakers are joined together, you could have a big problems if one lag blows and the other doesn’t.
C5Nate is offline   Reply With Quote
Old 12-12-2008, 01:28 PM   #19
Indy-hp
CF Senior Member
St. Jude Donor '09
Indy-hp's Avatar
Yes. The three wires are two 110V positives (usually red and black wires) and one neutral (usually white). Reconnect the black wire to a new 110V breaker in the breaker box, disconnect the red wire altogether, and replace the outlet with a standard 110V using the black and white wires, again leaving the red disconnected. If there is a fourth, bare wire, that is a ground and can be reused as a ground.
Indy-hp is offline   Reply With Quote
Old 12-12-2008, 01:29 PM   #20
ProfMoriarty
CF Senior Member
Quote:
The pic of the outlet is in the first post.
Go Back   CorvetteForum - Chevrolet Corvette Forum Discussion >
Reload this Page
  • How to convert 250V 20A outlet to 110V 20A?
    Related Topics
    Thread Thread Starter Forum Replies Last Post
    Electricians Please Step In........ gltrap54 Off Topic 23 10-30-2016 10:05 PM
    Battery tender ANDYSG1950 Intros 5 03-08-2015 12:06 PM
    Installing 110v outlet in car Casper001 Off Topic 10 04-02-2012 04:23 PM
    Converting tail lights to 110v? MDR1970 C5 General 6 12-22-2009 06:05 PM
    My C6 N20 Install info SoldSyclone C6 Forced Induction/Nitrous 17 01-27-2009 02:39 AM
    Tags
    110v, 20, 20a, 220v, 250, 250v, amp, change, connection, convert, converter, outlet, plug, step, wire
    Search this Thread:
    Click for Advanced Search
    Posting Rules
    You may not post new threads
    You may not post replies
    You may not post attachments
    You may not edit your posts
    BB code is On
    Smilies are On
    [IMG] code is On
    HTML code is Off
    Trackbacks are Off
    Pingbacks are Off
    Refbacks are Off
    Forum Jump
    • Ask a Question
    What's your question?
    Send
