How to clean oil stain off our blacktop driveway? - CorvetteForum - Chevrolet Corvette Forum Discussion
Off Topic
Off Topic | Non-Corvette
Old 03-22-2009, 10:11 AM   #1
sampson
CF Senior Member
sampson's Avatar
Default How to clean oil stain off our blacktop driveway?
Our minivan blew it's oil filter on the drive home last week and there is an oil line about 1 mile down the highway, makes a right turn 1/4 and a left right into our driveway. Where the van parked is a spot about 8 feet round. Luckily the motor didn't seize but the stain on the driveway is huge and embarrassing.
Besides having the driveway resurfaced is there any sure fire method to clean it? I tried using car wash soap, Dawn and a broom but it didn't even put a dent in it.
sampson is offline   Reply With Quote
Old 03-22-2009, 10:19 AM   #2
SurfnSun
CF Senior Member
St. Jude Donor '10
SurfnSun's Avatar
Beats me. Would a weed burner get the oil out?
SurfnSun is offline   Reply With Quote
Old 03-22-2009, 10:42 AM   #3
belmor
CF Senior Member
belmor's Avatar
I am going thru a similar situation with a diesel fuel leak at my office, not much helps) got some driveway cleaner from autozone, poured it on and left it alone, as it has rained lately the spot has gotten smaller, I suppose it will take a couple more applications to get it out
~B~
belmor is offline   Reply With Quote
Old 03-22-2009, 10:51 AM   #4
Daytona Bob
CF Senior Member
St. Jude Donor '09 & '12, '14
Daytona Bob's Avatar
take kitty litter and use the back of your push broom to crunch it in.
Then sweep and repeat. (It acts as an absorbent)
Finally get a power washer to finish the job. Buy some driveway cleaner at the hardware store.
BTW why did the filter blow? Poor Design? Left it loose?
Daytona Bob is offline   Reply With Quote
Old 03-22-2009, 10:58 AM   #5
Red Rochester
CF Senior Member
Red Rochester's Avatar
plus degreaser
Red Rochester is offline   Reply With Quote
Old 03-22-2009, 11:01 AM   #6
sampson
CF Senior Member
sampson's Avatar
It was a defective filter
I analyzed it after I removed it and there was a tear in the sheetmetal under the rubber gasket. Looks like it allowed the oil to push under the gasket and finally worked it's way out. The guy at the auto parts store said the best he could do was to offer me a free replacement and his apologies. Last time I use STP, that's a fact!
Old 03-22-2009, 11:02 AM   #7
1Patriot
CF Senior Member
1Patriot's Avatar
Easy solution is to extend the stain to the edges of the drive and draw a line across the area and squate off the stain. Then it will look it belongs there.
1Patriot is online now   Reply With Quote
Old 03-22-2009, 11:05 AM   #8
MARVIN 34
CF Senior Member
MARVIN 34's Avatar
go to home depot and get some concrete cleaner.
MARVIN 34 is offline   Reply With Quote
Old 03-22-2009, 12:04 PM   #9
ProfMoriarty
CF Senior Member
ProfMoriarty's Avatar
I have a very slow leak in my 2001 pathfinder that's not worth the $ to fix.
Consequently, I have a nice oil slick where I park.
What about gasoline (unlit) or another organic solvent and a push broom?
ProfMoriarty is offline   Reply With Quote
Old 03-22-2009, 12:38 PM   #10
c4cruiser
CF Senior Member
Support Corvetteforum!
c4cruiser's Avatar
Gasoline will act as a solvent and will break up the oil part of the asphalt mix. We had a gas spill of about 3 gallons at out shop from a vehicle that was parked on asphalt. After about an hour, we saw cracks forming on the area and the next day, we could pull chunks of the asphalt up
Try some undiluted Simple Green on the spill and let it sit for a few minutes. Then brush with a stiff bristle push broom (get one to throw away) and use kitty litter to absorb the stuff. Try a few applications and on the last one, hose the area down.
If that doesn't clean it off, you may have to use a solvent and get some blacktop coating/sealer and apply over the entire driveway.
c4cruiser is online now   Reply With Quote
Old 03-22-2009, 12:45 PM   #11
DC-STRO
CF Senior Member
St. Jude Donor '05-'06-'07-'08-'09-'10-11-'12-'13
DC-STRO's Avatar
Location: After reading this thread, I gotta tell ya... you're an ass. .
I don't see the problem. Asphalt is actually a controlled oil spill. It's like mixing water and water.
DC-STRO is offline   Reply With Quote
Old 03-22-2009, 12:51 PM   #12
ZipZap
CF Senior Member
St. Jude Donor '07-'08-'09-'10
ZipZap's Avatar
Location: Time flies like an arrow. Fruit flies like a banana.
Have them come seal it for a couple hundred bucks. They should pressure wash it first, and the sealant should cover the remaining oil.
ZipZap is offline   Reply With Quote
Old 03-22-2009, 12:58 PM   #13
sampson
CF Senior Member
sampson's Avatar
Quote:
Which is kind of the problem. I don't want to draw the oils out of the asphalt and destroy it. I have a can of foaming coil cleaner which I tried on a previous smaller spill. It cleaned it but turned the asphalt brown, drawing most of the oils out. It's kind of a fine line between getting the oil up and damaging the driveway.
c4cruiser has some good advise, especially since I can get Simple Green for free
Old 03-22-2009, 01:03 PM   #14
utah997
Circles are Hard
St. Jude Donor '07-'08-'09-'10-'11-'12-'13
utah997's Avatar
Clearly you need to rip out an replace your driveway.
utah997 is offline   Reply With Quote
Old 03-22-2009, 03:31 PM   #15
Black94LT1
CF Senior Member
Cruise-In 10-11-12 Veteran
St. Jude Donor '09-'10-'11-'12-'14
Black94LT1's Avatar
Clean the surface with some detergent so that there is no free oil left and leave the rest to soak in and become part of the asphalt. In a couple of months go ahead and seal the driveway if you want the spot to not show.
Black94LT1 is offline   Reply With Quote
Old 03-22-2009, 03:37 PM   #16
lebvette
CF Senior Member
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15-'16-'17
lebvette's Avatar
All I do is take a small amount of lawnmower gas and pour on it. Let it soak for a few minutes and rinse it off with a water hose. It will look like it not going to work, but when it dries the spot is gone.
Larry
lebvette is offline   Reply With Quote
Old 03-22-2009, 05:17 PM   #17
SurfnSun
CF Senior Member
St. Jude Donor '10
SurfnSun's Avatar
Quote:
Larry
Doesn't gasoline dissolve & break up asphalt?
Old 03-22-2009, 05:24 PM   #18
lebvette
CF Senior Member
lebvette's Avatar
Quote:
Your right....mine is concrete. I need to read closer.:o
Larry
Old 03-22-2009, 06:01 PM   #19
rbridges
CF Senior Member
rbridges's Avatar
on our concrete driveway, I scrub a degreaser (purple power is what I use) to get rid of as much as possible. Afterwards, I take kitty litter and grind it in with a brick or my shoe and let it sit. It takes a few weeks, but the kitty litter will slowly absorb it.
Oil does not bind to concrete, but concrete is porous. detergents will dissolve oil, but unless you have something to absorb it, it will settle back into the concrete.
I've also read of people using concrete powder to absorb oil stains, but you obviously have to keep moisture away from it.
rbridges is offline   Reply With Quote
Go Back   CorvetteForum - Chevrolet Corvette Forum Discussion >
Reload this Page
  • How to clean oil stain off our blacktop driveway?
    Related Topics
    Thread Thread Starter Forum Replies Last Post
    Best stuff to get oil stains off driveway? BrandensBeast Off Topic 54 10-03-2016 10:27 AM
    Pro Tek Cleaner lionsfan5454 Off Topic 0 07-11-2009 06:00 PM
    Clean Driveway ? C4Cvette Off Topic 24 05-19-2007 04:29 PM
    Cleaning Driveway.......... lvrpool32 C3 Tech/Performance 16 04-21-2004 02:35 PM
    Brick Driveway Cleaning Oil Drips Juliet Car Care Discussion 9 06-05-2002 05:34 PM
    Tags
    asphalt, autozone, black, blacktop, clean, cleaner, driveway, driveways, engine, gas, motor, oil, stain, stains, top
    Search this Thread:
    Click for Advanced Search
    Posting Rules
    You may not post new threads
    You may not post replies
    You may not post attachments
    You may not edit your posts
    BB code is On
    Smilies are On
    [IMG] code is On
    HTML code is Off
    Trackbacks are Off
    Pingbacks are Off
    Refbacks are Off
    Forum Jump
    • Ask a Question
    What's your question?
    Send
