Electricians Please ... Can an Electrical Outlet go bad? - CorvetteForum - Chevrolet Corvette Forum Discussion
Off Topic
Off Topic | Non-Corvette
Old 07-14-2009, 01:49 PM   #1
Dave1998
CF Senior Member
Dave1998's Avatar
Default Electricians Please ... Can an Electrical Outlet go bad?
My basement upright freezer started tripping the 15 amp breaker after being plugged into the outlet for 10 minutes. All food was ruined.
I then plugged the freezer into a heavy duty extension cord and plugged it into another outlet 12 feet closer to the circuit box on the same breaker and it has run fine for 2 hours. The breaker still has not tripped. I suspect it wont.
What is the correct course of repair?
Dave1998 is offline   Reply With Quote
Old 07-14-2009, 01:51 PM   #2
Cybercowboy
CF Senior Member
Stealthy Puma Member
Cruise-In IV Veteran
Cybercowboy's Avatar
Location: Blacker than the blackest black, times infinity.
Yeah, they can short out. Easy to replace too.
Cybercowboy is offline   Reply With Quote
Old 07-14-2009, 01:51 PM   #3
HOWSER
CF Senior Member
St. Jude Donor '09
HOWSER's Avatar
Yes, they can go bad. Sounds like this is what happened here with you.
HOWSER is offline   Reply With Quote
Old 07-14-2009, 01:59 PM   #4
wytevette
CF Member
wytevette's Avatar
Turn off the breaker.
Make sure it is off.
Pull the outlet out.
Make sure the screws that hold the wires on are tight.
Wouldn't hurt to check the ground pigtails either.
Check all screws on all outlets going back to the breaker.
Re-assemble
Turn on breaker and test.
I hope the original installer didn't use those "push in" type outlets where you strip a little of the end of the wire an poke it in.
wytevette is offline   Reply With Quote
Old 07-14-2009, 02:06 PM   #5
Dave1998
CF Senior Member
Dave1998's Avatar
I think you are all on the right track.
Back in February, the breaker tripped once, and then never again until last week. I have now tried this outlet like 5 times and in each case, within 10 minutes, it trips the breaker. I believe it has to be the outlet, or less likely, the wiring between the 2 boxes which seams less likely.
Old 07-14-2009, 02:12 PM   #6
Petew1971
CF Senior Member
Petew1971's Avatar
I just changed out a wall switch without turning the breaker off.... I got electrocuted once and made some nice sparks but it wasnt a big deal...get to work and swap out that outlet
Petew1971 is offline   Reply With Quote
Old 07-14-2009, 02:18 PM   #7
HOWSER
CF Senior Member
St. Jude Donor '09
HOWSER's Avatar
Quote:
At times I could believe this.
Old 07-14-2009, 02:20 PM   #8
Petew1971
CF Senior Member
Petew1971's Avatar
Quote:
its actually true I wanted to see if I could swap a switch out without turning the breaker off ..it was just a test ...I failed
Old 07-14-2009, 02:43 PM   #9
LarryMJones
CF Senior Member
St. Jude Donor '13-'14-'15-'16-'17
LarryMJones's Avatar
When I was in college working in a large office building maintenance dept I did that all the time. No problem for a 20 year old kid, right.
It was easier than running down the breaker in a panel that contained 50 or 60 breakers.
I didn't even use insulated pliers cause I was standing on vinyl tile, an insulator. Just like a bird setting on a wire right? The maintenance electrician taught me the trick.
Then I managed to grab a grounded piece of metal romex flex conduit in my left hand, while cutting into the hot wire with my right hand, completing the circuit. Fortunately I was with an experienced electrician who knew how to pull me off the circuit. I was locked on the pliers, all muscle function was locked up tight except for the vocal cords which worked rather well.
If it can be disconnected do it. I was very lucky, if I had been alone I have no doubt it would have been fatal.
LJ
LarryMJones is offline   Reply With Quote
Old 07-14-2009, 02:45 PM   #10
Z064life
CF Senior Member
St. Jude Donor '06
Z064life's Avatar
you wouldn't believe how many wire cutters I've ruined because someone said the power was out and I cut through the hot, neutral, and ground wire at once
Z064life is offline   Reply With Quote
Old 07-14-2009, 02:49 PM   #11
mrvette
CF Senior Member
mrvette's Avatar
Refrigerators, washers, dryers well pumps, etc do NOT LIKE any GFI breaker, take that check first....bet that breaker is only 15 amp IF it's the one in the box that's tripping....check what else is on the circuit....
mrvette is online now   Reply With Quote
Old 07-14-2009, 04:36 PM   #12
AD2VET
CF Senior Member
CI 2-3-4-5-6-7-8-9-10 Vet
St. Jude Donor '09-'10
AD2VET's Avatar
Quote:
Why, are these not as good as the other kind?
Are you dead?
AD2VET is offline   Reply With Quote
Old 07-14-2009, 04:47 PM   #13
Petew1971
CF Senior Member
Petew1971's Avatar
LJ
Quote:
Quote:
Are you dead?
Old 07-14-2009, 04:48 PM   #14
touringmike
CF Senior Member
touringmike's Avatar
Every switch/outlet I've seen/used for the past 30 years has the push-in AND screw terminals on it.
I'm quite sure they all are made this way.
touringmike is offline   Reply With Quote
Old 07-14-2009, 04:49 PM   #15
Silverspeed
CF Senior Member
St. Jude Donor '13, '15
Silverspeed's Avatar
Did you check the expiration date?
Silverspeed is offline   Reply With Quote
Old 07-14-2009, 04:51 PM   #16
jfb
CF Senior Member
Push in connection outlets are not as good as ones with screws because they rely on a thin blade biting into the wire. These connections have very little connection area and over time the connection becomes faulty. A screw connector has a large area connection to the wire and is much more reliable.
jfb is offline   Reply With Quote
Old 07-14-2009, 04:54 PM   #17
CertInsaneC5
CF Senior Member
Cruise-In X Veteran
CertInsaneC5's Avatar
Location: Freezing in the Midwest. Fort Wayne IN. Global warming my azz.
Just like old times. Except you were on dry land.
CertInsaneC5 is offline   Reply With Quote
Old 07-14-2009, 05:06 PM   #18
NYC6
CF Senior Member
NYC6's Avatar
Some have not made it the the 21st Century yet!
Dont know when your house was built but check if you have aluminum wiring. The house I grew up in(built in 60's) had al. to cooper connections at the outlets which were a big problem. Tripping circuits and in some cases fires. A 4 year girl died in one of these fires 2 blocks from my house when I was a kid.
And copper wiring can also get very brittle over time especially at outlet connections and cause shorts also.
NYC6 is offline   Reply With Quote
Old 07-14-2009, 05:06 PM   #19
wytevette
CF Member
wytevette's Avatar
Point taken. Yeah, they (15amp) are made that way. Unfortunately, too many guys are tempted to use the push in, which is adequate for NEC. If it is ok for NEC, that is good enough, and I am only stating my opinion.
I don't want to get into a pissing match, but I am of the opinion that those spring loaded push in contacts are not nearly as good as the screw. Adequate, but not as good. I got this opinion based upon what I have been told by my local electrical inspector, as well as instructors in continuing education.
That said, I don't use the push in contacts.
The argument could be made that a screw can work loose (and they do), but I just prefer the screws.
I have yet to see a 15 amp outlet with a spring loaded contact for the ground. The ground is the most important safety component of the device, and they use a screw for that.
Old 07-14-2009, 05:12 PM   #20
Burnt71
CF Senior Member
Burnt71's Avatar
Push in contacts suck. Quality commercial receptacles do not have the holes for push in connections.
Burnt71 is offline   Reply With Quote
Go Back   CorvetteForum - Chevrolet Corvette Forum Discussion >
Reload this Page
  • Electricians Please ... Can an Electrical Outlet go bad?
    Related Topics
    Thread Thread Starter Forum Replies Last Post
    Need recommendation for UPS. 427Z0SX Off Topic 13 06-19-2016 10:50 PM
    Electrical question snide Off Topic 13 05-30-2016 06:44 PM
    strange electrical circuit issue...help is appreciated jd Off Topic 16 09-09-2015 09:42 AM
    Electrical Question - AFCI amofg4 Off Topic 25 07-01-2015 03:21 PM
    [Electrical] No power to room? Gipper Off Topic 33 11-17-2007 08:36 PM
    Tags
    bad, circuit, clicking, completing, elec, electric, electrical, hot, makes, outlet, outlets, phone, pictures, power, receptacle, sound, spoil, wall, wire
    Search this Thread:
    Click for Advanced Search
    Posting Rules
    You may not post new threads
    You may not post replies
    You may not post attachments
    You may not edit your posts
    BB code is On
    Smilies are On
    [IMG] code is On
    HTML code is Off
    Trackbacks are Off
    Pingbacks are Off
    Refbacks are Off
    Forum Jump
    • Ask a Question
    What's your question?
    Send
