oops gasoline in a duramax - CorvetteForum - Chevrolet Corvette Forum Discussion
Register FAQ Search Today's Posts Mark Forums Read Vendor Directory
Off Topic
Off Topic | Non-Corvette
Old 09-16-2009, 07:33 PM   #1
germanc5
CF Senior Member
germanc5's Avatar
Default oops gasoline in a duramax
one of our guys put gasoline in the company duramax dually on a road trip. obviously they drove it a little ways and it quit. will there be any immediate or long term damage?
germanc5 is offline   Reply With Quote
Old 09-16-2009, 07:36 PM   #2
NEWudERA
CF Senior Member
Support Corvetteforum!
NEWudERA's Avatar
I think it is fugged
NEWudERA is offline   Reply With Quote
Old 09-16-2009, 07:37 PM   #3
roadracer247
CF Senior Member
roadracer247's Avatar
This is what happened to the last guy who tried this...
roadracer247 is offline   Reply With Quote
Old 09-16-2009, 07:37 PM   #4
63C2splitter
CF Senile Member
St. Jude Donor '08
63C2splitter's Avatar
Doesn't sound good. How much gas vs. amount of Diesel in the tank?
63C2splitter is offline   Reply With Quote
Old 09-16-2009, 07:38 PM   #5
JackDidley
CF Senior Member
JackDidley's Avatar
I'd say, its goof chinked.
JackDidley is offline   Reply With Quote
Old 09-16-2009, 07:40 PM   #6
KarlK
CF Senior Member
KarlK's Avatar
Drain the tank of gas, pull the fuel pump line, turn key to turn on pump and pump residual gas in the line.
Reconnect line, fill with diesel, turn key and cross fingers.
The above worked on a Powerstroke with "0" ill effects. Don't ask me how I know.
KarlK is offline   Reply With Quote
Old 09-16-2009, 07:43 PM   #7
germanc5
CF Senior Member
germanc5's Avatar
they're at the chevy dealer in western ky. right now. the service dept. said it should be fine but i was wondering if any one has close experience with an incident like this.
Old 09-16-2009, 07:43 PM   #8
Corvette Kid
Large Upstanding Member
St. Jude Donor '04-'05-'06-'07
Corvette Kid's Avatar
Location: Welcome President Trump... now drain the swamp!
Quote:
Good chance. The bad thing is, is that it was run until it quit. The damage could be severe.
Corvette Kid is offline   Reply With Quote
Old 09-16-2009, 07:46 PM   #9
Stoge
CF Senior Member
Stoge's Avatar
Location: Please return your stewardess to her original upright position. Tulsa, OK
We had a similar incident with a Yanmar diesel powered John Deere Pro Gator at work. We had to drain the tank & lines & replace the fuel filter. It has been running like normal since then.
Stoge is offline   Reply With Quote
Old 09-16-2009, 07:47 PM   #10
KarlK
CF Senior Member
KarlK's Avatar
Quote:
me
Old 09-16-2009, 07:48 PM   #11
C5Nate
CF Senior Member
Kansas City Area Coordinator
St. Jude Donor '08-'09-'10-'11,'13
C5Nate's Avatar
Psssst.....there is no "pump" to pump the fuel.
Depends on the mixture.
If it ran till it quit, then its probably toast.
Drain the tank, blow out the lines until the return line comes out clean.
Put about 5 gallons of diesel in the tank, prime the fuel up to the filter using the hand primer. Hope for the best.
IMHO, they have a the very least shortened the life expectancy of the diesel.
C5Nate is offline   Reply With Quote
Old 09-16-2009, 07:48 PM   #12
germanc5
CF Senior Member
germanc5's Avatar
me
doh!
Old 09-16-2009, 07:49 PM   #13
C5Nate
CF Senior Member
C5Nate's Avatar
Quote:
Yes, but you were not running down the highway at 70 mph either.
Old 09-16-2009, 07:51 PM   #14
KarlK
CF Senior Member
KarlK's Avatar
There is an electric pump on the 7.3 PSD's, not sure about Max's.
Mine ran till it quit, had 12000 miles on it. I did the above procedure. Filled it up, fired right up and I have not replaced an injector, pump, nothing. I have 150K on it now.
We've had a few service techs do the same on our Powerstoke service trucks with no damage.
Old 09-16-2009, 07:55 PM   #15
Stoge
CF Senior Member
Stoge's Avatar
Yeah and we're not turbocharged either, but I'll bet its still worth a try.
Why would speed matter?
Old 09-16-2009, 07:55 PM   #16
DarthStimpy
CF Senior Member
DarthStimpy's Avatar
Unless it was at full boost there shouldnt be enough compression to ignite the gasoline, and therefore the engine just stalled. No harm.
DarthStimpy is offline   Reply With Quote
Old 09-16-2009, 10:01 PM   #17
C5Nate
CF Senior Member
C5Nate's Avatar
Putten around in a Gator VS 7,000 lbs of truck hauling azz down the highway. Lots more revolutions before it dies.
Old 09-16-2009, 10:03 PM   #18
hendrix68
CF Senior Member
St. Jude Donor '13-'14-'15-'16
hendrix68's Avatar
Shameful.
hendrix68 is offline   Reply With Quote
Old 09-16-2009, 10:03 PM   #19
C5Nate
CF Senior Member
C5Nate's Avatar
No pump on the Dmax. Suction feed to the filter.
Like I said earlier, depends on the mixture of diesel VS gas. May be fine but it had to hurt it some.
I put a couple gallons of gas in my diesel by accident when BP first came around. Friggen brits dont know that Green means diesel here in the states. Not reg. gas
Ran fine but that was a 10:1 mixture.
Old 09-16-2009, 10:19 PM   #20
JRD77VET
CF Senior Member
St. Jude '03-'04-'05-'06-'07-'08-'09-'10
JRD77VET's Avatar
Quote:
Huh?? Diesels have more compression that gas engines. That's how the diesel fuel ignites
Used to be a local used car lot that specialized in nice low mileage cars.
The owner's wife grabbed an almost new MB diesel and filled it with gas before she left.
The engine grenaded a few miles down the road.
The owner was not happy
JRD77VET is offline   Reply With Quote
Go Back   CorvetteForum - Chevrolet Corvette Forum Discussion >
Reload this Page
  • oops gasoline in a duramax
    Related Topics
    Thread Thread Starter Forum Replies Last Post
    Exhaust mods for a 2011 Duramax 2th farmer Off Topic 11 11-23-2011 07:25 AM
    Help needed on Duramax Diesel 99 hardtop 08 Off Topic 12 09-05-2011 07:38 PM
    lifted 2003 Chevy K2500hd Duramax Diesel ~FS~ kenneyd Other Cars 2 07-01-2010 03:12 PM
    Towing open trailer with duramax jabrun Autocrossing & Roadracing 36 02-02-2009 09:26 PM
    Duramax Owners step in side please.... NTRBL33 Off Topic 20 06-07-2007 11:54 AM
    Tags
    2005, 2006, clean, corvette, drain, duramax, expectancy, filling, gas, gasoline, life, pumping, put, reg, tank
    Search this Thread:
    Click for Advanced Search
    Posting Rules
    You may not post new threads
    You may not post replies
    You may not post attachments
    You may not edit your posts
    BB code is On
    Smilies are On
    [IMG] code is On
    HTML code is Off
    Trackbacks are Off
    Pingbacks are Off
    Refbacks are Off
    Forum Jump
