Anyone ever have an above ground pool freeze solid? - Page 2 - CorvetteForum - Chevrolet Corvette Forum Discussion
Off Topic
Off Topic | Non-Corvette
Old 02-21-2010, 11:21 AM   #21
04 commemorative
CF Senior Member
04 commemorative's Avatar
I don't think that much water could freeze "solid" where you live
04 commemorative is offline   Reply With Quote
Old 02-21-2010, 11:25 AM   #22
VITE1
CF Senior Member
Support Corvetteforum!
Cruise-In X Veteran
St. Jude Donor '08-'09-'10
VITE1's Avatar
Location: Port St Lucie FL Life is hard, Then you die, FL USA
I know how you feel. Last year the apron around my in ground shifted and started to bend the frame. I had to have the concrete apron removed and replaced. That's a lot of mod money sitting out there now.
Good luck George.
VITE1 is offline   Reply With Quote
Old 02-21-2010, 11:27 AM   #23
juiceman03070
CF Senior Member
St. Jude Donor '08
juiceman03070's Avatar
I really think that you got your monys worth at 15 years....in this climate...
juiceman03070 is offline   Reply With Quote
Old 02-21-2010, 11:37 AM   #24
touringmike
CF Senior Member
touringmike's Avatar
Every winter, it freezes solid.
I drain 1/3 to 1/2 the water.
Throw 2 baketballs in, cover it up.
I installed this (doughboy) in 1988.
Replaced the original liner in 2007 (25mil/25 yr liner), with a 20mil/20 yr liner.
touringmike is offline   Reply With Quote
Old 02-21-2010, 11:37 AM   #25
6spdC6
CF Senior Member
6spdC6's Avatar
Location: A little town on the shores of the Great Sacandaga Lake in the "Peoples Republic" of upper NY state http://www.visitsacandaga.com/
Quote:
Originally Posted by kapayakapaya View Post
Around here we always drain all but a couple feet (to keep things in shape) in the winter
Did something that for 12 upstate NY winters. We drained a 1/3 put a cover on the pool and threw in a bunch of gallon plastic milk containers full of water to hold the cover from blowing. After a couple snow storms the cover was locked in place.
When the weather got warmer and things started to melt I would insert a siphon hose and draw off the water sitting under the snow/ ice. We never used a balloon. A couple of my neighbors had used the method above for years before I bought our pool with no problems!
6spdC6 is offline   Reply With Quote
Old 02-21-2010, 02:14 PM   #26
Fastguy
CF Senior Member
St. Jude Donor '03-'05
Fastguy's Avatar
Quote:
That is how I feel right now. I never really loved it to begin with. When we bought the house, I said, "That fugly thing is coming down".
Once I got it up and running, we decided to keep it. It pisses me off that I just bought a ton of new stuff for it at the end of the season. Cover, balloons, solar cover, ladder, chemicals, etc.
The dog will miss it.
Fastguy is offline   Reply With Quote
Old 02-21-2010, 02:17 PM   #27
Swany00
CF Senior Member
Swany00's Avatar
that sucks
Swany00 is online now   Reply With Quote
Old 03-14-2010, 02:18 PM   #28
Fastguy
CF Senior Member
Fastguy's Avatar
So-update.
Insurance adjuster comes out and gives me her assessment.
According to this girl, the weight of the ice in the pool caused the panels to burst and the uprights to bow.
Yes, you are reading that correctly. Her assertion is that once water freezes, it becomes heavier than water and caused the pool to buckle. Since it was due to negligence of not taking the ice off the pool, coverage was denied due to a part of my policy that says damage caused by excess weight of snow or ice isn't covered.
I called my agent and explained that I wanted another opinion.
They sent out a pool specialist who looked at it for a minute and explained exactly what happened. The top of all above ground pools freeze, as do the sides.
There was a panel failure that caused a leak. Once the water leaked out, the sides, which were big ice walls, tumbled in, causing the burst panels and bent uprights due to mechanical leveraging of huge slabs of ice, not actual ice expansion. Now I have to wait and see how my insurance company weasels out of this.
Old 03-14-2010, 02:28 PM   #29
JRD77VET
CF Senior Member
St. Jude '03-'04-'05-'06-'07-'08-'09-'10
JRD77VET's Avatar
If it wasn't thousands of dollars, I'd be laughing right now.
Check this out
http://ga.water.usgs.gov/edu/waterproperties.html
Water is unusual in that the solid form, ice, is less dense than the liquid form, which is why ice floats.
But it looks like ice is about 1/2 a lb heavier than water
Here's a quick rundown of some of water's properties:
◦Weight: 62.416 pounds per cubic foot at 32F
◦Weight: 61.998 pounds per cubic foot at 100F
◦Weight: 8.33 pounds/gallon, 0.036 pounds/cubic inch
◦Density: 1 gram per cubic centimeter (cc) at 39.2F, 0.95865 gram per cc at 212F
JRD77VET is offline   Reply With Quote
Old 03-14-2010, 02:33 PM   #30
Fastguy
CF Senior Member
Fastguy's Avatar
I asked the ins adjsuter if adding ice cubes to my drink would cause the glass to blow out and explode, due to the weight and all.
Old 03-14-2010, 02:34 PM   #31
Swany00
CF Senior Member
Swany00's Avatar
above ground pools are what, $500-$1k tops?
Old 03-14-2010, 02:37 PM   #32
DJ_Critterus
CF Senior Member
St. Jude Donor '09
DJ_Critterus's Avatar
Quote:
I'd be asking around for a new insurance company once you get finished with these idjits.
DJ_Critterus is offline   Reply With Quote
Old 03-14-2010, 02:41 PM   #33
jeff79'
CF Senior Member
St. Jude Donor '10
jeff79''s Avatar
I've never had my pool totally freeze solid....We've had 2 month stretches of below freezing weather, day and night, and never has that happened...Like another poster did though, I would drain as much off the top as the weather permitted, even if it was in January or February....Weight kills as you found out...Insurance companies suck !
jeff79' is offline   Reply With Quote
Old 03-14-2010, 02:44 PM   #34
JRD77VET
CF Senior Member
JRD77VET's Avatar
Quote:
WTF? You're talking a few hundred pounds difference plus ICE FLOATS
Old 03-14-2010, 02:45 PM   #35
jeff79'
CF Senior Member
St. Jude Donor '10
jeff79''s Avatar
Quote:
And expands......
Old 03-14-2010, 02:46 PM   #36
Petew1971
CF Senior Member
Petew1971's Avatar
what is the reason for adding 'balloons' or basketballs to the pool?
Petew1971 is offline   Reply With Quote
Old 03-14-2010, 02:47 PM   #37
Swany00
CF Senior Member
Swany00's Avatar
Quote:
was thinking the same thing
Old 03-14-2010, 02:48 PM   #38
jeff79'
CF Senior Member
St. Jude Donor '10
jeff79''s Avatar
It distributes the weight evenly to the walls....and gives an outlet for pressure in the center.
Old 03-14-2010, 02:49 PM   #39
JRD77VET
CF Senior Member
JRD77VET's Avatar
And expands......
So-update.
Panel failure caused the problem. Fastguy has had this same pool in that same exact location for many years. Only had a problem this year.
Old 03-14-2010, 02:50 PM   #40
Petew1971
CF Senior Member
Petew1971's Avatar
hhmm learn something new every day
Go Back   CorvetteForum - Chevrolet Corvette Forum Discussion >
Reload this Page
  • Anyone ever have an above ground pool freeze solid?
    Related Topics
    Thread Thread Starter Forum Replies Last Post
    Pool Owners ZO ZICK Off Topic 14 08-31-2016 08:20 AM
    Pool man says "We don't service pools with dog swimmers." Docbrock Off Topic 82 07-18-2016 04:55 PM
    pool of coolant scottstmaxx C3 General 9 12-16-2014 06:24 PM
    Pool Maintenance SLO C5 Off Topic 40 09-03-2007 06:18 AM
    Pool table setup - How much of a tip should I pay the guys? JR_VETTE Off Topic 27 08-24-2007 12:46 PM
    Tags
    24, days, failures, freeze, freezing, ground, inches, keeping, log, pool, poolsforum, solid, throw, water, wisconsin
    Search this Thread:
    Click for Advanced Search
    Posting Rules
    You may not post new threads
    You may not post replies
    You may not post attachments
    You may not edit your posts
    BB code is On
    Smilies are On
    [IMG] code is On
    HTML code is Off
    Trackbacks are Off
    Pingbacks are Off
    Refbacks are Off
    Forum Jump
    • Ask a Question
    What's your question?
    Send
