Sagging metal garage door - CorvetteForum - Chevrolet Corvette Forum Discussion
Off Topic
Off Topic | Non-Corvette
Old 03-06-2010, 12:21 PM   #1
BradSW
CF Senior Member
St. Jude Donor '15-'16
BradSW's Avatar
Default Sagging metal garage door
All of a sudden, the bottom panel of my metal (two car wide) garage door sags in the middle as it gets to the top when opened. The when I close it it builds a little pressure and pops back as it goes down. Can't be good for the opener or garage door. But can't seem to see what causes it.
Anybody experience this and know what causes it and how to fix it??
Garage is 19 years old.
BradSW is offline   Reply With Quote
Old 03-06-2010, 12:28 PM   #2
MARKRUBYRED
CF Senior Member
MARKRUBYRED's Avatar
Call an overhead door specialist. You don't want to start messing with the spring if you don't know what you are doing and lose a hand.
MARKRUBYRED is offline   Reply With Quote
Old 03-06-2010, 12:43 PM   #3
c4cruiser
CF Senior Member
Support Corvetteforum!
c4cruiser's Avatar
Is there a brace that goes across the width of the door? If the door is sagging in the middle when it's open, then the panel needs some sort of support. Has the door panel been hit?
c4cruiser is online now   Reply With Quote
Old 03-06-2010, 01:26 PM   #4
BradSW
CF Senior Member
BradSW's Avatar
Quote:
Yeah....I hear that.....NEVER mess with the springs. They were replaced about a year ago.
Old 03-06-2010, 02:30 PM   #5
BradSW
CF Senior Member
BradSW's Avatar
Quote:
No brace, just the frame and 3 vertical inserts across each panel.
Double checked.....not hit....that was my first thought.
Old 03-06-2010, 02:40 PM   #6
Swany00
CF Senior Member
Swany00's Avatar
something brokeded
Swany00 is online now   Reply With Quote
Old 03-06-2010, 07:43 PM   #7
tinner73
CF Senior Member
tinner73's Avatar
you may need a long piece(s) of heavy gauge metal angle to screw into the weak door panel for support 16 ga would work nicely. this will only put off the inevitable though.
tinner73 is offline   Reply With Quote
Go Back   CorvetteForum - Chevrolet Corvette Forum Discussion >
Reload this Page
  • Sagging metal garage door
    Related Topics
    Thread Thread Starter Forum Replies Last Post
    sagging rear - one side only corvettedave383 C3 Tech/Performance 10 09-17-2016 06:28 PM
    Adjusting door sag Sam Ruger C4 General Discussion 11 01-22-2013 08:40 PM
    68 Convertible - Frame Question Nichols1 C3 General 8 11-26-2012 09:26 PM
    67 Driver door sag emdoller C1 & C2 Corvettes 73 03-27-2012 08:11 PM
    need help with my doors Bigg Dee C5 General 2 09-24-2010 11:09 AM
    Tags
    brace, center, corvette, door, dooris, doors, fix, garage, metal, middle, repair, sag, sagging, sags, steel
    Search this Thread:
    Click for Advanced Search
    Posting Rules
    You may not post new threads
    You may not post replies
    You may not post attachments
    You may not edit your posts
    BB code is On
    Smilies are On
    [IMG] code is On
    HTML code is Off
    Trackbacks are Off
    Pingbacks are Off
    Refbacks are Off
    Forum Jump
    • Ask a Question
    What's your question?
    Send
