Cemented basketball pole removal? - CorvetteForum - Chevrolet Corvette Forum Discussion
Off Topic
Off Topic | Non-Corvette
Old 06-22-2010, 03:47 PM   #1
Jughead
Senior Member since 1492
Support Corvetteforum!
St. Jude Donor '09
Jughead's Avatar
Location: 1.Just because I'm paranoid doesn't mean people aren't out to get me... 2.That which does not kill me will probably hurt like hell. Obama-shortest legacy ever!
Default Cemented basketball pole removal?
I have a basketball pole that's seen better days. I want to remove it but it's cemented in about 2 feet of cement.
In lieu of a backhoe, what's the best way to remove it?
Jughead is offline   Reply With Quote
Old 06-22-2010, 03:49 PM   #2
longhorn341
CF Senior Member
St. Jude Donor '10
longhorn341's Avatar
Location: Wait 'til next year!!!!!! ---Emerald Coast of Florida
longhorn341 is offline   Reply With Quote
Old 06-22-2010, 03:49 PM   #3
lander
CF Senior Member
St. Jude Donor '09-'10-'11
lander is offline   Reply With Quote
Old 06-22-2010, 03:53 PM   #4
Kevin_73
CF Senior Member
Cruise-In X Veteran
St. Jude Donor '09-'11
Kevin_73's Avatar
Sawzall it down so there is about a foot of the pole left sticking up, drill a hole through the side and install a large bolt all the way through, then rent an engine hoist to pull it out of the ground. Hopefully it will pull the concrete out with it.
I had pretty good luck pulling old fence posts out by making a tripod (like a tepee frame) from old fence posts and using a comealong to pull them up too.
Kevin_73 is offline   Reply With Quote
Old 06-22-2010, 04:20 PM   #5
MEC5lady
CF Senior Member
St. Jude Donor '06-'07-'08-'09-'10-'11
MEC5lady's Avatar
Location: If there were no gutters, my mind would be homeless MD
Sawzall is one of the best tools around.
MEC5lady is offline   Reply With Quote
Old 06-22-2010, 04:24 PM   #6
HyperX
U.S. Marines 89-93
St. Jude Donor '10-'11-'12-'13-'14-'15-'16
HyperX's Avatar
I would mix salt and water. Pour mixture on pole. Get a case of beer and lawn chair and enjoy a few brewskies while pole rusts.
HyperX is offline   Reply With Quote
Old 06-22-2010, 04:50 PM   #7
BuckyThreadkiller
Successful Plumber
CF NCM Ambassador
CI 6-7-9-10 Veteran
NCM Member '09
BuckyThreadkiller's Avatar
Location: Top of the hill, 3rd mailbox on the right. Texas
Secure a large plumber's wrench (monkey wrench) around the pole, about a foot off the ground. Place a floor jack with the cradle under the wrench, right at the pole.
Jack the pole out of the ground. Catch the pole when it falls.
BuckyThreadkiller is offline   Reply With Quote
Old 06-22-2010, 04:56 PM   #8
lionsfan5454
CF Senior Member
lionsfan5454's Avatar
lionsfan5454 is offline   Reply With Quote
Old 06-22-2010, 05:00 PM   #9
PsychoNumber1
CF Senior Member
PsychoNumber1's Avatar
Location: Behind The Redwood Curtain, The State of Jefferson
...and boom goes the dynamite.
PsychoNumber1 is offline   Reply With Quote
Old 06-22-2010, 05:02 PM   #10
Pigface1
CF Senior Member
St. Jude Donor '03-'04-'05-'06-'07-'08
Pigface1's Avatar
Put a "please don't steal" sign on it.
Pigface1 is offline   Reply With Quote
Old 06-22-2010, 05:02 PM   #11
DT
CF Senior Member
DT's Avatar
When we first moved in there was a rusted out basketball pole and I just Sawzall'ed it down, pretty much flush and called it a day
DT is offline   Reply With Quote
Old 06-22-2010, 05:04 PM   #12
MardiGrasMan
CF Senior Member
MardiGrasMan's Avatar
Call Police and tell them someone told you there is a dead body buried there and they will dig it up for you. Just sit in your chair and watch.
MardiGrasMan is offline   Reply With Quote
Old 06-22-2010, 05:10 PM   #13
PsychoNumber1
CF Senior Member
Quote:
like the neighbor with drugs in his wood?
Old 06-22-2010, 05:21 PM   #14
04 commemorative
CF Senior Member
St. Jude Donor '17
04 commemorative's Avatar
I would cut it off with a sawzall and dig the cement out then break it up with a sledge...
04 commemorative is online now   Reply With Quote
Old 06-22-2010, 06:17 PM   #15
C5Nate
CF Senior Member
Kansas City Area Coordinator
St. Jude Donor '08-'09-'10-'11,'13
C5Nate's Avatar
I see no one here has ever removed a concreted pole from the ground.
You will bend an engine hoist boom before it will come out of the ground.
Leave the pole in the concrete; soak the ground around the concrete, wiggle the pole back and forth until the cement reams out the hole big enough to lift it out. A shovel will help break the suction that the water and soil make.
C5Nate is offline   Reply With Quote
Old 06-22-2010, 06:18 PM   #16
DT
CF Senior Member
DT's Avatar
You know, if you blank out a few words, this is one of the dirtiest posts ever:
Quote:
Originally Posted by C5Nate View Post
Leave the ****in the ****; soak the ****around the ****, wiggle the ****back and forth until the ****reams out the hole big enough to **** it out. A ****will help break the suction that the ****and ****make.
Old 06-22-2010, 06:21 PM   #17
AU Eagle
CF Senior Member
St. Jude Donor '08-'09-'10-'11, '14
AU Eagle's Avatar
Wait, this isn't you?
AU Eagle is offline   Reply With Quote
Old 06-22-2010, 07:00 PM   #18
Jughead
St. Jude Donor '09
Jughead's Avatar
Quote:
I was thinking of doing that using my Excursion, non diesel though.
Old 06-22-2010, 07:01 PM   #19
hendrix68
CF Senior Member
St. Jude Donor '13-'14-'15-'16
hendrix68's Avatar
Rent a skidloader. Easily removed.
hendrix68 is offline   Reply With Quote
Old 06-22-2010, 07:03 PM   #20
hendrix68
CF Senior Member
hendrix68's Avatar
Quote:
Doesn't have to be diesel. All you need is momentum. Just make sure you use heavy straps or chain for the job. And also make sure you have enough of it to prevent the pole from coming down on your vehicle. That almost happened in the posted video.
Go Back   CorvetteForum - Chevrolet Corvette Forum Discussion >
Reload this Page
  • Cemented basketball pole removal?
    Related Topics
    Thread Thread Starter Forum Replies Last Post
    Seal coating a cement driveway? WWK888 Off Topic 19 09-14-2011 12:51 PM
    Does gasoline dissolve rubber cement? Red99SS Off Topic 11 06-07-2011 06:29 PM
    For those who have put up an 'In-Ground' basketball system Ruz Off Topic 22 04-15-2010 02:50 PM
    Does anyone make a fiber cement board in tongue and groove? 1K SPORT Off Topic 0 09-16-2008 02:04 PM
    what's the best way to remove spilled/stained oil and fluids off cement qwiketz C4 General Discussion 20 08-29-2007 04:11 PM
    Tags
    angle, basketball, break, cement, cemented, concrete, grinder, jersey, kalamazoo, mi, michigan, pole, poles, removal, remove, removel
    Search this Thread:
    Click for Advanced Search
    Posting Rules
    You may not post new threads
    You may not post replies
    You may not post attachments
    You may not edit your posts
    BB code is On
    Smilies are On
    [IMG] code is On
    HTML code is Off
    Trackbacks are Off
    Pingbacks are Off
    Refbacks are Off
    Forum Jump
    • Ask a Question
    What's your question?
    Send
