If 1 HP Electric Motor = 0.746KW - CorvetteForum - Chevrolet Corvette Forum Discussion
Off Topic
Off Topic | Non-Corvette
Old 01-26-2011, 09:12 PM   #1
OHSIXX
CF Senior Member
Support Corvetteforum!
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-10-'11-'12-'13-'14-'15-'16-'17
OHSIXX's Avatar
Default If 1 HP Electric Motor = 0.746KW
Does that mean it uses 0.746 KW for one hour?
OHSIXX is offline   Reply With Quote
Old 01-26-2011, 09:24 PM   #2
mlongo99
CF Senior Member
Cruise-In VIII Veteran
mlongo99's Avatar
Only if you run it at full power for one hour.
Power is a function of time. It describes the amount of work (force acting over a distance) done in a given unit of time.
mlongo99 is offline   Reply With Quote
Old 01-26-2011, 09:43 PM   #3
jfb
CF Senior Member
One horsepower equals 550 foot pounds per second. 746 watts also equals 550 foot pounds per second.
jfb is offline   Reply With Quote
Old 01-26-2011, 10:08 PM   #4
JoesC5
CF Senior Member
An electric motor is not 100% efficient. A 1 horse motor is normally 78.8% efficient.
JoesC5 is offline   Reply With Quote
Old 01-26-2011, 10:20 PM   #5
Poppa Bud
CF Senior Member
Cruise-In IX Veteran
St. Jude Donor '08-'09-'10-'11-'12-'13
Poppa Bud's Avatar
Quote:
Is the motor 1 HP on the output shaft or electric usage?
Input = .746 KW / 120 V = 6.2 amps in.
To output 1 HP assuming 100% efficient (1/.746) /129 = 11.2 amps input.
Poppa Bud is online now   Reply With Quote
Old 01-26-2011, 10:36 PM   #6
OHSIXX
CF Senior Member
OHSIXX's Avatar
So.............
If my 1 HP motor runs 300 hours and the cost per KW is 13.1 cents the total costs is $29.10?
Old 01-26-2011, 10:46 PM   #7
LarryMJones
CF Senior Member
St. Jude Donor '13-'14-'15-'16-'17
LarryMJones's Avatar
KW x hours = KWH.
.746 KW x 1 Hr = .746 KWH
KW (kilowat) is like horsepower
hour is time
KWH is a measure of power consumed. Kilowatt hours (your electric meter reads in KWH)
If you only run it 10 minutes it only would register 0.124 kwh.
But that is at 100% efficiency of converting electric energy inti mechanical energy. Effiencies vary but on small motors are typically around 80%. So a real 1 hp motor will use .746/0.8 or 0.93 KW.
Run it 1 hour and your electric meter will read .93 kwh.
I use 1hp = 1kw for typical energy cost calculations. It's close enough as all motors vary slightly in efffiency. Some new high effiency motors are better.
LJ
LarryMJones is offline   Reply With Quote
Old 01-26-2011, 10:49 PM   #8
LarryMJones
CF Senior Member
Quote:
Originally Posted by OHSIXX View Post
So.............
At 80% effiency it actually would cost $36.27.
LJ
Old 01-26-2011, 11:03 PM   #9
Chicago
CF Senior Member
St. Jude Donor '15
Chicago's Avatar
What happens if it's on a treadmill?
Chicago is offline   Reply With Quote
Old 01-26-2011, 11:15 PM   #10
99C5Vert
CF Senior Member
St. Jude Donor '03-'11
99C5Vert's Avatar
Quote:
plane crash
99C5Vert is offline   Reply With Quote
Old 01-26-2011, 11:31 PM   #11
mrvette
CF Senior Member
mrvette's Avatar
All I know is I just went from air/air heat pump to water/air for the heat exchanger for unwanted heat.....
1/2 horse pump subbing for 1/2 horse outdoor fan motor....
BUT there is NO reverse heat cycle, it's just runs like a furnace....102f out the stack.... house WARM now, not fighting it....
mrvette is online now   Reply With Quote
Old 01-27-2011, 12:06 AM   #12
JoesC5
CF Senior Member
It would lose that ugly fat around the middle.
Old 01-27-2011, 01:28 AM   #13
Czarvette
CF Senior Member
Czarvette's Avatar
So.............
The motor may be rated at (i.e., capable of) 1 hp, but it's likely producing far less power... And thereby consuming far less electrical power.
Corvette LS1 engine is rated at 345 hp. How often is it actually called on to produce that much?
Czarvette is offline   Reply With Quote
Old 01-27-2011, 01:50 AM   #14
jasper711
CF Senior Member
it would use .746KWH in one hour. Electrical Energy = power x time
jasper711 is offline   Reply With Quote
Old 01-27-2011, 09:08 AM   #15
Poppa Bud
CF Senior Member
Poppa Bud's Avatar
What's the water source? Well water?
Old 01-27-2011, 12:41 PM   #16
1Patriot
CF Senior Member
1Patriot's Avatar
A simple question and 40 forensic responses. Love it.
The answer to your question is yes.
Now if you want details, read the above post.
1Patriot is offline   Reply With Quote
Old 01-27-2011, 12:43 PM   #17
smearig
CF Senior Member
smearig's Avatar
Depends on if we're talking about horsepower-minutes or horspower-hours.
smearig is offline   Reply With Quote
Old 01-27-2011, 12:47 PM   #18
vetluvr
CF Senior Member
St. Jude Donor '08
vetluvr's Avatar
HP = T X RPM/5252
HP = 33,000 lbs/ft/min
vetluvr is offline   Reply With Quote
Old 01-27-2011, 01:07 PM   #19
No Panic
CF Senior Member
CI 1-3-5-7-8-9-10-11 Vet
St. Jude Donor '10
No Panic's Avatar
Quote:
Originally Posted by 1Patriot View Post
...The answer to your question is yes...
Except he's mixing his units.
HP is Power.
0.746KW is Power.
"0.746 KW for one hour" is Energy.
In an engineering class, the answer would be No.
But that's only because he didn't ask the question correctly.
The answer to "what he really meant" is Yes.
No Panic is offline   Reply With Quote
Old 01-27-2011, 01:19 PM   #20
ter
CF Senior Member
ter's Avatar
Depends. You may have the peak start up HP. Typically the start up draw is double typical run power. You may find that it runs on 3 amps, and starts on 7 amps. The work that it needs to perform makes a difference in actual use, not just the rating. And as other guys pointed out, the efficiency makes a difference. So the rating is a ball park number, and YMMV.
ter is offline   Reply With Quote
Go Back   CorvetteForum - Chevrolet Corvette Forum Discussion >
Reload this Page
  • If 1 HP Electric Motor = 0.746KW
    Related Topics
    Thread Thread Starter Forum Replies Last Post
    LT4 Top End KW Baraka C5 Parts for Sale/Wanted 1 05-18-2016 04:44 PM
    oldmobile sugar Koufax C5 General 19 04-26-2016 04:06 PM
    Mele Kalikimaka and Hau'oli Makahiki Hou KenHorse Politics, Religion & Controversy 6 12-16-2015 11:44 AM
    2010 Burnout radio GS review Funny.... silvervettesyco C6 Corvette General Discussion 7 01-13-2010 03:43 PM
    test scott85vette Testing 2 09-19-2007 08:06 PM
    Tags
    0746, 1hp, corvette, cost, electric, energy, fan, hour, hp, input, kw, kwh, motoor, motor, run, usage
    Search this Thread:
    Click for Advanced Search
    Posting Rules
    You may not post new threads
    You may not post replies
    You may not post attachments
    You may not edit your posts
    BB code is On
    Smilies are On
    [IMG] code is On
    HTML code is Off
    Trackbacks are Off
    Pingbacks are Off
    Refbacks are Off
    Forum Jump
    • Ask a Question
    What's your question?
    Send
