Concrete Guys...ballpark me a 24 x30 slab - CorvetteForum - Chevrolet Corvette Forum Discussion
Off Topic
Off Topic | Non-Corvette
Old 04-14-2011, 04:39 PM   #1
Gary79
CF Senior Member
Default Concrete Guys...ballpark me a 24 x30 slab
oh knowledgeable concrete dudes, guesstimate the cost of a 24 x30 concrete slab. this will be for a small single story cottage/cabin at a nearby lake, basically, a living room/kicthen area, a bedroom, bath, and utility/pantry/storage room.
a mobile home sits on the site now, it will be hauled away or dismembered. the build site is level. the soil is sandy, gravel. the site drains well, and is 30 feet above the lake. the building will not be heated in the winter, except the occasional weekend. In this part of the country the temperature ranges from -20* to 110*, not every year but those are the extremes.
I am currently getting names of area contractors who live in that area, and want some idea of what to expect. I also don't know if just a slab will be sufficient or footings with the slab would be better. TIA
Gary79 is offline   Reply With Quote
Old 04-14-2011, 05:20 PM   #2
Muffin
CF Senior Member
Muffin's Avatar
That's 9 yards at 80 sqft per yard. You will need footers and something more than the 4 inch thick since it will be a load bearing pad. I just had a parking space about that size done, cost $1,350. I'll SWAG your cost will be twice that.
Muffin is offline   Reply With Quote
Old 04-14-2011, 05:22 PM   #3
Bill Irwin
CF Senior Member
If you're gonna put a roof on you better put footings in. Where your water coming from, and electric. Where's the sewerage going? Bill
Bill Irwin is offline   Reply With Quote
Old 04-14-2011, 05:58 PM   #4
DBlack1
CF Senior Member
Quote:
Probably the same place the mobile homes went.
A 12"x12" perimeter footer, rebar, wire, wash rock, clay packing base, plastic, and labor should put you around the $5k mark.
Crete here is right over $100/yd tax and delivered with fiber added. Figure 13 yards or so, a buck or two a sq/ft to form and finish (maybe more). 20 yds of clay $300, wash rock $400, metals, etc. should get you close to that amount.
DBlack1 is offline   Reply With Quote
Old 04-14-2011, 06:53 PM   #5
ieatyllwcryns
CF Senior Member
ieatyllwcryns's Avatar
<----- Said Ballpark
ieatyllwcryns is offline   Reply With Quote
Old 04-14-2011, 07:02 PM   #6
Gary79
CF Senior Member
water is rural municipal on site already, will need to be dug up and moved slightly, pieced out and up thru slab. electric is aerial, then drops down the pole to meter. pole will need to be moved about 5 feet. the septic is old but fully operational. I will need to dig it up and replace the pipe to the tank. this would be the time to do this.
Old 04-14-2011, 07:55 PM   #7
Dave concrete
CF Senior Member
Dave concrete's Avatar
Not familiar with winter in Ill. but if you have winters like us if town allows do a monolithic trench slab. If grade is flat frame with 2x4's and dig a 12" wide 3' deep trench perimiter. Depending if soil stays in tact expect to use between 21 to 25 yds of concrete. Some will say its overkill most haven't a clue. Doing it the right way you will never have a problem and for a bit more work and money and being its your home its worth it.
Dave concrete is offline   Reply With Quote
Old 04-15-2011, 11:20 AM   #8
Gary79
CF Senior Member
the roof will be a truss roof. what I am building is like a garage without the overhead door.
Old 04-15-2011, 01:32 PM   #9
Feen
CF Senior Member
I think you guys run on the same international code set as we do in NY, due to size and the structure is not heated, it will need to have a full frost wall installed down to below your local frost line.
Feen is offline   Reply With Quote
Old 04-15-2011, 03:57 PM   #10
CrustyOldGuy
CF Senior Member
CrustyOldGuy's Avatar
Driveway in front of new garage and sidewalk running down the side of it.
$3.00/square foot.
This covers everything except the ground preb (digging it down to the proper depth and making it level).
24x30 = 720
720 x 3 = $2160.00
Mine is getting poured on Tuesday.
CrustyOldGuy is offline   Reply With Quote
Old 04-15-2011, 04:07 PM   #11
Swany00
CF Senior Member
Swany00's Avatar
Quote:
nice
Swany00 is offline   Reply With Quote
Old 04-15-2011, 04:07 PM   #12
Dalannex
CF Senior Member
Dalannex's Avatar
Floating slab, rebar, including fill, finish, and backfill about $3200. That's a complete job first scoop of site prep to backfill as long as there isn't a whole bunch of crazy plumbing in the slab and the site is reasonable flat. If the site is a big hill or something that would require multiple loads of fill that of course would start to add up.
-Justin
Dalannex is offline   Reply With Quote
Old 04-15-2011, 08:59 PM   #13
Dave concrete
CF Senior Member
Quote:
I forgot to mention If I was doing this in my area we would get about
4,500 for this.
Old 04-15-2011, 09:11 PM   #14
Tact
Law Dawg Moderator
CF St. Jude Co-Organizer
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16
Tact's Avatar
Labor + materials = $5.50/ft(approx)
Tact is offline   Reply With Quote
Old 04-15-2011, 09:13 PM   #15
mrvette
CF Senior Member
mrvette's Avatar
RED flag on OLD septic systems, if you redo that house/foundation, you may well have to update that septic system.....
code vary, but they catch you on that sometimes....I know Maryland does....
some times you can NOT put in a new septic system due to updated codes, especially when replacing the structure....
my SWAG on the slab, ready to go....8000 bux.....
I"m move the slab, leave the utility pole.....
get caught up on the codes/requirements in your area before you get caught up in something cleaning out your wallet.....
mrvette is online now   Reply With Quote
Go Back   CorvetteForum - Chevrolet Corvette Forum Discussion >
Reload this Page
  • Concrete Guys...ballpark me a 24 x30 slab
    Related Topics
    Thread Thread Starter Forum Replies Last Post
    Concrete slab crack repair experts, come on in! (concrete dave) ZeusC6 Off Topic 38 11-03-2016 07:31 PM
    Contractors/Builders Please: Can Ya Give Me A Guesstimate? Over9K Off Topic 20 08-23-2016 07:32 PM
    Can a garage lift crack the slab KevinRH C6 Corvette General Discussion 13 04-08-2016 09:31 PM
    Polished Concrete Floors War Bonnet Off Topic 4 03-01-2016 01:29 PM
    Vette-port Buck Henry C6 Corvette General Discussion 18 07-21-2015 05:08 PM
    Tags
    15, 24, 24x, 24x30, 30, average, cement, concrete, cost, floating, needed, northeast, pad, price, slab
    Search this Thread:
    Click for Advanced Search
    Posting Rules
    You may not post new threads
    You may not post replies
    You may not post attachments
    You may not edit your posts
    BB code is On
    Smilies are On
    [IMG] code is On
    HTML code is Off
    Trackbacks are Off
    Pingbacks are Off
    Refbacks are Off
    Forum Jump
