OK all you S10 Blazer saggy door/hinge pin challanged mofos, I found the cure.... - CorvetteForum - Chevrolet Corvette Forum Discussion
Off Topic
Off Topic | Non-Corvette
Old 08-22-2011, 09:09 PM   #1
touringmike
CF Senior Member
touringmike's Avatar
Default OK all you S10 Blazer saggy door/hinge pin challanged *****, I found the cure....
Feel free to us it.
touringmike is offline   Reply With Quote
Old 08-22-2011, 09:10 PM   #2
CHASLS2
CF Senior Member
St. Jude Donor '13
It needs a 6.2 swap.
CHASLS2 is offline   Reply With Quote
Old 08-22-2011, 09:33 PM   #3
thetaxman
CF Senior Member
you might be a redneck......
thetaxman is offline   Reply With Quote
Old 08-22-2011, 09:34 PM   #4
TPFKATK
CF Senior Member
Support Corvetteforum!
TPFKATK's Avatar
Awesome.
A pterodactyl pooped on your hood.
TPFKATK is offline   Reply With Quote
Old 08-22-2011, 10:07 PM   #5
touringmike
CF Senior Member
Quote:
Originally Posted by TPFKATK View Post
Awesome.
Nah.
Just didn't do the "wax off" procedure yet.
Old 08-22-2011, 11:17 PM   #6
thetaxman
CF Senior Member
Quote:
Originally Posted by touringmike View Post
Nah.
I'd say a bit too much waxing off.....
Old 08-22-2011, 11:19 PM   #7
pkazsr
CF Senior Member
Cruise-In X Veteran
St. Jude Donor '09
pkazsr's Avatar
I have to lift the door of my S10 to close it so I made the mistake of clicking on this thread.
pkazsr is offline   Reply With Quote
Old 08-22-2011, 11:36 PM   #8
blown87
CF Senior Member
GA Events Coordinator
blown87's Avatar
Got a 20$ that says "Meth" may have helped a bit on that mod.
But all the GM's with that POS hinge have that problem, I bet the shop has done a hundred of them.
blown87 is offline   Reply With Quote
Old 08-23-2011, 12:05 AM   #9
J S Machine
CF Senior Member
St. Jude Donor '10-'11-'12-'13-'14-'15-'16
St. Jude Knife Maker
J S Machine's Avatar
My '95 Z71 has the same sagging hinge problem...aggravating as fire..
J S Machine is offline   Reply With Quote
Old 08-23-2011, 12:51 AM   #10
99mallett
CF Senior Member
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15-'16-'17
99mallett's Avatar
Location: The line waiting to see Santa Claus stretched all the way back to Terre Haute, and I was at the end, Indiana
This was parked next to me a while back...
99mallett is offline   Reply With Quote
Old 08-23-2011, 01:14 AM   #11
blown87
CF Senior Member
blown87's Avatar
Quote:
Why don't you repair it before it really gets expensive.
Once you have to break out the welder, it tends to get into you check book.
Old 08-23-2011, 05:13 AM   #12
Black94LT1
CF Senior Member
Cruise-In 10-11-12 Veteran
St. Jude Donor '09-'10-'11-'12-'14
Black94LT1's Avatar
If it is just the bushings, it is an easy and cheap fix, about $10 and an hours work.
Black94LT1 is offline   Reply With Quote
Old 08-23-2011, 08:10 AM   #13
J S Machine
CF Senior Member
Quote:
Where can I find the bushings?
Another thing, there is a small piece in the hinge assembly which looks like a flat piece of metal with indentions. These little indentions ride on the protruding downward hinge pin, and position the door at the several stop points as it is being opened. The force from the spring and /or repeated openings and closings caused the little flat piece to break off the bottom of the hinge pin. The doors still open and close fine, but if I am parked on a hill they will not open and stay open at all.
I asume the only fix is to replace that pin, which would be fine to do if I were putting bushings in.
Old 08-24-2011, 08:37 PM   #14
Black94LT1
CF Senior Member
Black94LT1's Avatar
The pins and bushings are avialable in the "help" section at any box parts store (autozone, etc). I'm not sure on the hold open portion, that may not be as easy to fix as that part is part of the hinge itself if I recall correctly.
Here is a pretty good link on the process to replace the bushings. I did most of mine by using various sockets and C clamps to press parts in and out rather than using prybars, hammers, punches, etc, but whatever works best for your situation.
http://www.bodyshopzone.com/archives...replace_1.html
Also, if you are looking for the tool to remove and replace the spring, I found one at Harbor Freight for about $4 or $5, compared to $30 or so I was finding on-line.
Go Back   CorvetteForum - Chevrolet Corvette Forum Discussion >
Reload this Page
  • OK all you S10 Blazer saggy door/hinge pin challanged mofos, I found the cure....
    Related Topics
    Thread Thread Starter Forum Replies Last Post
    img test 1%r Testing 0 10-28-2016 02:05 AM
    Cleaned up Ready to Show Yoggi C5 General 29 06-21-2008 12:47 PM
    Car Show Pics ChancWds C3 General 5 09-27-2006 01:48 AM
    Car show in Portland Rgd2424 C5 General 6 03-07-2006 10:07 AM
    Portland Roaster show Rgd2424 C5 General 10 03-08-2005 01:06 PM
    Tags
    10, blazer, change, door, doors, fix, hinge, hinges, kit, pin, pins, repair, replace, replacement, s10, saggy, sale
    Search this Thread:
    Click for Advanced Search
    Posting Rules
    You may not post new threads
    You may not post replies
    You may not post attachments
    You may not edit your posts
    BB code is On
    Smilies are On
    [IMG] code is On
    HTML code is Off
    Trackbacks are Off
    Pingbacks are Off
    Refbacks are Off
    Forum Jump
    • Ask a Question
    What's your question?
    Send
