Best interior caulk to seal sheetrock/molding cracks? - CorvetteForum - Chevrolet Corvette Forum Discussion
Off Topic
Off Topic | Non-Corvette
Old 11-26-2011, 04:58 PM   #1
SLO VETTE
CF Senior Member
SLO VETTE's Avatar
Default Best interior caulk to seal sheetrock/molding cracks?
Nothing drives me more bats&!#! crazy than home settling a year or so after remodel...but what can I do....
F'ing green pine molding. Never again. I'm using mdf or composite.
Even jeld-wen's high-end line of solid wood doors.....shriveling like a...well..let's just say joints are shriveling and i have to re-paint that too.
Oh yeah, back to my question....what is best interior caulk to use to re-do the molding/sheetrock joints? Is it destined to crack as well in the next year or so of heat/cold cycles?
I've always used phenoseal, which is supposed to be great, but hey....the wall/molding settling probably stretched it too far as well.
Thanks for any tips.
SLO VETTE is offline   Reply With Quote
Old 11-26-2011, 06:04 PM   #2
Mr turbo rotary
CF Senior Member
Mr turbo rotary's Avatar
Bump...(self interest here)
Mr turbo rotary is online now   Reply With Quote
Old 11-26-2011, 07:31 PM   #3
Meh
CF Senior Member
Meh's Avatar
Do you like black caulk or white caulk?
Meh is offline   Reply With Quote
Old 11-26-2011, 07:39 PM   #4
BHRZ06
CF Senior Member
BHRZ06's Avatar
I use white alex plus on all of my remodels and have yet to have a problem with cracking.
BHRZ06 is offline   Reply With Quote
Old 11-26-2011, 07:41 PM   #5
SLO VETTE
CF Senior Member
SLO VETTE's Avatar
i've used that before on another place. similar results.
Old 11-26-2011, 07:55 PM   #6
Vork
CF Senior Member
Vork's Avatar
Been there and done that....I use paintable silicone now.
http://www.caulkyourhome.com/ge-sili...e-silicone.php
Vork is offline   Reply With Quote
Old 11-26-2011, 08:52 PM   #7
wetelvis
CF Senior Member
wetelvis's Avatar
Just use the regular Alex caulking. I use it on new construction jobs. I've been finding the plus hard to work with always oozing out the end
wetelvis is offline   Reply With Quote
Old 11-26-2011, 09:40 PM   #8
jasper711
CF Senior Member
For interior I've used white DAP brand, seems paintable. Being available at the local department store has much to do with my choice.
jasper711 is offline   Reply With Quote
Old 11-26-2011, 10:03 PM   #9
sixty4
CF Senior Member
St. Jude Donor '13
sixty4's Avatar
Dap or Phenoseal!
sixty4 is offline   Reply With Quote
Old 11-27-2011, 01:26 AM   #10
ruacop
CF Senior Member
ruacop's Avatar
DAP here...seems easily agreeable with paint.
ruacop is offline   Reply With Quote
Old 11-27-2011, 08:11 AM   #11
AU N EGL
CF Senior Member
AU N EGL's Avatar
Molding use DAP
sheetrock use joint compound, sand and paint
green pine? should have been kiln dried pine.
AU N EGL is offline   Reply With Quote
Old 11-27-2011, 11:36 AM   #12
SLO VETTE
CF Senior Member
SLO VETTE's Avatar
i'm assuming it was green--was from home depot.
if i wanted the best, driest stuff, it would've cost me at least 4-5x the price from high end lumberyard nearby. with the amount of linear feet purchased....that would've been a big price tag.
so, instead i gotta make due with what i got and find the best caulk and a re-touch a year later. that's worth the many thousands of $ saved. a major hassle, yes, but still worth it.
Old 11-27-2011, 12:12 PM   #13
ProfMoriarty
CF Senior Member
ProfMoriarty's Avatar
Quote:
Plus has nearly the consistency of Elmer's Glue and it shrinks too much when its dry.
Also AlexPlus white isnt as white as bright white paint. It dries a greyish shade of white and, therefore when applied over sunken nail heads, requires a paint touchup.
ProfMoriarty is offline   Reply With Quote
Old 11-27-2011, 12:46 PM   #14
slvrzo6
CF Senior Member
slvrzo6's Avatar
Here is a Subject I can offer some sound advise on.
I am a Home Builder / General Contractor.
I have built over 70 Custom Homes and over 300 Condo's.
We include a One Year Home Warranty with our homes.
Including Drywall nail pops and Trim / Molding Caulking separations.
It seemed to me that about every 8 months or so we were doing 1 Year Home Warranty Punch out Work. The majority of the Warranty work was always Crown Molding and Baseboard Caulking issues. These Repairs were becoming costly and usually involved sending over Painters to Re-caulk and Repaint Trim, and sometimes it ended up getting into the walls. How did we remedy this Problem? STOP THE PAINTERS IN THE BEGINNING FROM USING CHEAP JUNK REGULAR PAINTERS CAULKING! BIG STRETCH caulking has saved us thousands.. Available where ever Benjamin Moore Paints are sold. We almost NEVER have a caulking issue anymore. It stretches instead of cracking. Applies just like regular Alex Painters Caulk. We have been using it for 6 years now. About $6.00 a tube. But will save you the Redo work in the Future.
slvrzo6 is offline   Reply With Quote
Old 11-27-2011, 01:04 PM   #15
SLO VETTE
CF Senior Member
SLO VETTE's Avatar
I'll give this a whirl. All interior (and exterior) paint was Benjamin Moore, so hopefully they carry this brand of caulk.
Most gaps are around 1/16" or less. But, noticeable nonetheless. And still maddening!
Thanks.
Old 12-01-2011, 03:33 AM   #16
ruacop
CF Senior Member
ruacop's Avatar
Thanks. I am going to try that stuff.
Old 12-12-2011, 02:40 PM   #17
SLO VETTE
CF Senior Member
SLO VETTE's Avatar
slvrz06, i went to the benjamin moore paint place and they didn't have your suggested brand. instead they suggested "tower sealants" brand "tower tech" acrylic urethane elastic sealant. label says it has 800% elongation, which i presume to mean it'll stretch a lot.
anyone ever hear of this brand?
Old 12-12-2011, 02:44 PM   #18
Aerovette
CF Senior Member
Aerovette's Avatar
I don't think I have ever seen moulding/sheetrock seperation. That's a new one. Sheet rock to sheet rock and moulding to moulding I have seen.
Aerovette is online now   Reply With Quote
Old 12-12-2011, 05:21 PM   #19
65 Hardnoks
CF Senior Member
65 Hardnoks's Avatar
I just Googled "Big Stretch caulk" and found many places near me that sell it (Ace Hardware, for one).
Sounds like a product I wish I knew about before................
65 Hardnoks is offline   Reply With Quote
Old 08-30-2012, 12:18 PM   #20
r2down22go
Junior Member
Tower Sealants manufactures high quality sealants under a number of names (DuPont and others all use Tower as a manufacturer for their sealants. Tower Tech 2 exceeds the requirements of both ASTM C-834, and the more difficult ASTM C-920 class 25. Some of the other caulks listed here (Alex and Alex Plus) might pass ASTM C-834, but do not even come close to passing ASTM C-920.
Big Stretch is a nice product, but I love the Tower Products.
r2down22go is offline   Reply With Quote
Go Back   CorvetteForum - Chevrolet Corvette Forum Discussion >
Reload this Page
  • Best interior caulk to seal sheetrock/molding cracks?
    Related Topics
    Thread Thread Starter Forum Replies Last Post
    Building a house...is it possible for it to not be intensely frustrating? SteveR. Off Topic 50 11-11-2013 08:51 AM
    Ortho & Round up not working well. 6spdC6 Off Topic 47 06-27-2011 04:10 PM
    Paint or caulk first? Munch Off Topic 7 09-21-2009 10:56 AM
    Any USG Sheetrock 400 Race / Nextel Cup Fans here? ZR_Don Great Lakes 5 07-15-2007 06:51 PM
    Door Panel mounting thingies -- What & Where to get? Jack71 C3 Tech/Performance 4 07-30-2003 11:42 AM
    Tags
    caulk, caulking, cover, cracks, drywall, gaps, interior, molding, phenoseal, seal, sealing, separations, sheetrock, tech, tower, wall
    Search this Thread:
    Click for Advanced Search
    Posting Rules
    You may not post new threads
    You may not post replies
    You may not post attachments
    You may not edit your posts
    BB code is On
    Smilies are On
    [IMG] code is On
    HTML code is Off
    Trackbacks are Off
    Pingbacks are Off
    Refbacks are Off
    Forum Jump
    • Ask a Question
    What's your question?
    Send
