Difference between 1/2, 3/4, and 1 ton Chevy pickups? - CorvetteForum - Chevrolet Corvette Forum Discussion
Register FAQ Search Today's Posts Mark Forums Read Vendor Directory
Off Topic
Off Topic | Non-Corvette
Old 01-07-2012, 12:17 PM   #1
J S Machine
CF Senior Member
St. Jude Donor '10-'11-'12-'13-'14-'15-'16
St. Jude Knife Maker
J S Machine's Avatar
Default Difference between 1/2, 3/4, and 1 ton Chevy pickups?
I have a '95 K1500 with a 5.7 and 4L60E (I think). It may be a 700R4, but pretty sure it is a 4L60E. I love the old truck, but I have considered getting myself a 3/4 ton. I don't really want a dual wheel truck so I think a 3/4 ton would be better suited for me. I am aware that they make 1 tons without dual wheels out back, but I'm not sure exactly how that works. The only reason I would ever get rid of the old truck was if I traded it for a 3/4 ton or 1 ton. I never really drive the truck anymore. I use it for hauling things and occasionally driving it just to keep it from sitting up..an alternate vehicle of sorts. I thought of getting a camper one day in the distant future, and I'll need something to pull it with. I like my body style, the 88-98 trucks.
Would it be a rediculous and pointless idea (more trouble/cost than it's worth) to swap over 3/4 ton running gear?
I helped a friend do this one time with an '85 Blazer. He wanted bigger tires, so he went ahead and upgraded everything to 3/4 ton. We swapped out spindles up front, and put a 14 bolt rear end under it. It was a mud truck, so no heavier springs and all but you ge tthe idea.
I'm sure that it would be a little more involved with my truck, but I'm not sure. Leaf springs? What all would have to be moved? Would the transfer case work? Would I have to swap the whole front axle or would it just be the knuckles like we did on the old '85 Blazer? Would that transmission work with the new running gear?
I would essentially have a 1/2 ton that has been converted to a 3/4 or 1 ton so I would have the extra towing capacity if I ever needed it.
If the whole idea is nuts, What exactly is different about the 3/4 and 1 ton trucks? I suspect heavier springs, axles of course, and maybe a trans cooler, bigger radiator?? higher output alternator to support trailer lights, etc.
J S Machine is offline   Reply With Quote
Old 01-07-2012, 12:30 PM   #2
juiceman03070
CF Senior Member
Support Corvetteforum!
St. Jude Donor '08
juiceman03070's Avatar
Frame and drive train ..suspention,wheel&tire size
As the weight carry numbers go up so do the body ..
juiceman03070 is offline   Reply With Quote
Old 01-07-2012, 12:44 PM   #3
c4cruiser
CF Senior Member
c4cruiser's Avatar
The 3/4 ton frame is bigger, the brakes are probably different, the driveline (especially the front and rear diffs) is different, it will have bigger springs and shocks, HD cooling, and the trans should be different. 3/4 tons will typically have LT-rated tires where most of the 1/2 tons will use a P-metric (passenger car) tire. The wheels may be larger and carry more load.
It would be much easier to sell the 1/2 ton and look for a 3/4 ton. That way, everything you need in terms of towing capacity is there and ready to go. For a camper or travel trailer, you need to figure out what the weight will be and go from there. If you are towing something like 5000 to 6000 lbs, a 1/2 ton should work with a weight distribution hitch, helper springs or air bags. Add a larger tranny cooler too.
c4cruiser is offline   Reply With Quote
Old 01-07-2012, 12:57 PM   #4
J S Machine
CF Senior Member
Quote:
This may be the easiest way to go. If we ever get one, it doesn't have to be one of those huge 4 bedroom 50 ft long deals. A small camper trailer would be fine.
Old 01-07-2012, 01:03 PM   #5
Swany00
CF Senior Member
Swany00's Avatar
I'm a ford truck guy and there isn't much difference between a 3/4 and 1 ton ford except for ins and rated towing capacity. I wasn't aware of a gm having a srw 1 ton, thought the newer ones were all drw.
Doing a swap out might not be a great solution if you're going to pull a trailer (camper style) because if anything happens and it's registered as a 1/2 ton and you're over your max for 1/2 ton pulling capabilities without proper coverage, you could be screwed.
I'd just go with a newer truck if you can swing it. Better safe than sorry is my motto.
Swany00 is offline   Reply With Quote
Old 01-07-2012, 01:41 PM   #6
pablocruise
CF Senior Member
pablocruise's Avatar
You would want to switch to a 4L80E or a TH400.
pablocruise is offline   Reply With Quote
Old 01-07-2012, 02:02 PM   #7
Corvette Kid
Large Upstanding Member
St. Jude Donor '04-'05-'06-'07
Corvette Kid's Avatar
Location: Welcome President Trump... now drain the swamp!
I'm going with about a thousand pounds.
Corvette Kid is offline   Reply With Quote
Old 01-07-2012, 02:10 PM   #8
c4cruiser
CF Senior Member
c4cruiser's Avatar
Quote:
I used my old '99 Silverado K1500 extended cab Z71 to tow my car trailer and 87 coupe. Total towed weight was about 5600lbs and that truck (with the first year of the 5.3L motor and 270HP) towed it just fine at freeway speeds up to 75MPH.
I now have an '08 Silverado K1500 ext cab, Z71 and a 6.0L motor and it handles my new 20' enclosed car trailer with no problems. The towed weight is now at 6700 but I'm using a WD hitch.
Both trucks were equipped with a trailer towing package, 4-wheel disc brakes. My 08 will carry slightly more weight, but the 6 liter motor with 367HP and close to 400 ft-lbs of TQ is a big help. This truck also has a G80 locker diff instead of a positraction and a HD auto trans.
Also, back in the mid-90's, Chevy and GMC offered a HD1500 in both 2 and 4wd. They called it a "heavy-half" and was basically the 1/2 ton truck with a stiffer frame and heavy-duty springs and shocks. It was designed for those who didn't want the full 3/4 pickup but needed a higher cargo capacity than the 1/2 ton.
Old 01-07-2012, 02:14 PM   #9
J S Machine
CF Senior Member
Never thought of this. Thanks for helping me realize it. Very good point
Old 01-07-2012, 08:24 PM   #10
Vette_Minded
CF Senior Member
Vette_Minded's Avatar
If you have a 95 Z71 I believe they had an extra leaf and higher towing numbers.
Vette_Minded is offline   Reply With Quote
Old 01-07-2012, 08:36 PM   #11
RED-85-Z51
CF Senior Member
RED-85-Z51's Avatar
Location: I like a cars like I like my violence...DOMESTIC
1/2 ton load rating, base frame, V6, 305, 350...10 bolt rearend, 5 or 6 lug, 4L60 Light duty trans, HD cooling options, and stuff like that.
3/4ton, little heavier frame, heavier springs, Semi-Floater 14 bolt rearend, 4L60 trans, HD cooling, Tranny cooler, 8lug. 350, Diesel,
1 ton, HD frame, HD springs, Full FLoater 14 bolt, 4L80E, Severed duty cooling for engine and trans, 8 lug, 454, 350, Diesel
1 ton tow rating is 10,000lbs
RED-85-Z51 is offline   Reply With Quote
Old 01-07-2012, 09:48 PM   #12
Polar_Bear
CF Senior Member
Polar_Bear's Avatar
Quote:
Originally Posted by RED-85-Z51 View Post
1500
The GVW (Gross Vehicle Weight) of a 1 ton Dually is 10,000 lbs. Tow capacity was quite a bit higher than that. Up to 19,000 lbs (truck and trailer), if I believe this '91 GMC brochure. Compare that to today's numbers: 21,700 lbs for just the trailer on a new '12 Sierra 3500.
Polar_Bear is offline   Reply With Quote
Old 01-07-2012, 10:12 PM   #13
1911fool
CF Senior Member
1911fool's Avatar
1500
I have a 1/2 ton with a 14 bolt 5 lug rearend, factory.
1911fool is offline   Reply With Quote
Old 01-07-2012, 10:17 PM   #14
m and t's77
CF Senior Member
m and t's77's Avatar
Quote:
It's not a full-floater big differance with the semi-float you have.
m and t's77 is offline   Reply With Quote
Old 01-07-2012, 10:22 PM   #15
1911fool
CF Senior Member
1911fool's Avatar
Quote:
I have no clue what you are talking about. Can you explain it please?
The truck is a 454SS.
Old 01-07-2012, 10:27 PM   #16
VetteMed
VetteMed's Avatar
semi float uses c-clips to secure axles in the housing -- broken axle shaft leads to loss of the entire tire/wheel assembly -- BAD.
A full-floater has the hub assembly bolted to the end of the axle tube, and the axle shaft is not what holds the wheel/assembly in to the axle housing.
VetteMed is offline   Reply With Quote
Old 01-07-2012, 10:30 PM   #17
m and t's77
CF Senior Member
You have the small 14 bolt.
GM CORPORATE 14-BOLT
The "small" GM 14-bolt has a 9 1/2-inch ring gear diameter. It was used in the rear of 1964-and-later GM pickups, and in the rear of 1984-91 3/4-ton Suburbans.
With a 10 1/2-inch-diameter ring gear, the biggest 14-bolt GM rearend looks much like a Dana 70, and is but a few thousandths of an inch shorter in ring gear diameter. This axle is commonly used with big engines and/or overly large tires. It was used under 1973-87 3/4-tons.
Old 01-07-2012, 10:55 PM   #18
RED-85-Z51
CF Senior Member
RED-85-Z51's Avatar
Quote:
So Im looking at getting a 1996 K3500 Sierra, Factory 4:10's, 454/4L80E..using the chart, it can tow about a 11,000lb trailer? NICE
Old 01-07-2012, 11:01 PM   #19
RED-85-Z51
CF Senior Member
RED-85-Z51's Avatar
You have whats known as a factory exception.
C1500's came with 10 bolts out back..and 5 lugs front and rear.
The 454 made more torque than a 10 bolt can handle, hell the 350 made more torque than it can handle...
So GM's fix for this situation was to use the beefier light duty 14 bolt semi-floater rear end that was used in alot of 2500 trucks.
The problem then was that the 14 bolt was 8 lug...and this would have required using 8 lug wheels front and rear, meaning C2500 front suspenstion.....
GM's resolution was to make a limited number of 5 Lug 14 bolt semi- Floaters for the 454SS trucks.
Later on, they had an issue where they had a similar situation...they wanted to make a Light Duty 2500 truck...basically a 1500 with better springs and cooling, 350 gasser, and used a 6 lug 14bolt semi-floater
Old 01-07-2012, 11:16 PM   #20
su8pack1
CF Senior Member
su8pack1's Avatar
My two 2500HD's, gas and Duramax will each carry in the bed 3000 lbs legally with tags $153.00 p/y each. That's a load of coal level with the sides in an 8" bed.
su8pack1 is offline   Reply With Quote
Go Back   CorvetteForum - Chevrolet Corvette Forum Discussion >
Reload this Page
  • Difference between 1/2, 3/4, and 1 ton Chevy pickups?
    Related Topics
    Thread Thread Starter Forum Replies Last Post
    Blazer Wiper Motor Wiring In C4 Swap? bigedog8 C4 General Discussion 0 04-04-2014 11:06 PM
    Wilwood C4 brake system optimal composition pieces_r6 Autocrossing & Roadracing 25 06-12-2008 06:14 PM
    The forklift operator would not do this for a Tundra driver.... Gozar Off Topic 68 04-07-2008 04:22 PM
    Ram Hydraulic Throw Out Bearing catchme76 C3 Tech/Performance 5 11-07-2007 02:56 PM
    2 car trailer towing question jlucas Autocrossing & Roadracing 10 05-02-2007 12:52 AM
    Tags
    12, 14, 1953, 1984, bolt, broke, chevy, gm, half, pickup, price, rating, ton, tow, truck
    Search this Thread:
    Click for Advanced Search
    Posting Rules
    You may not post new threads
    You may not post replies
    You may not post attachments
    You may not edit your posts
    BB code is On
    Smilies are On
    [IMG] code is On
    HTML code is Off
    Trackbacks are Off
    Pingbacks are Off
    Refbacks are Off
    Forum Jump
