Oil Change Frequency Non-Vette - CorvetteForum - Chevrolet Corvette Forum Discussion
Register FAQ Search Today's Posts Mark Forums Read Vendor Directory
Off Topic
Off Topic | Non-Corvette
Old 04-24-2012, 02:40 PM   #1
fast-vette
CF Senior Member
Support Corvetteforum!
fast-vette's Avatar
Default Oil Change Frequency Non-Vette
I had always been under the understanding that you should do an oil change/filter every 3000 miles for proper maintenance. I have read on numerous sites that thinking is now antiquated and the norm now is 5000K miles.
How often in miles do you change your oil/filter in you non-vette vehicle.
fast-vette is offline   Reply With Quote
Old 04-24-2012, 02:43 PM   #2
ptindall
CF Senior Member
ptindall's Avatar
I'm doing 5000. Synthetic in the nice cars, conventional in the beaters. I don't claim to know what's best or what's required, but that's what I'm doing.
ptindall is online now   Reply With Quote
Old 04-24-2012, 02:45 PM   #3
thechosenone
CF Senior Member
3000 for the vette and 5000 for everything else (dailies). I always use Mobile 1 as it is only $25.00 at Walmart for 5qts. And a Mobile 1 oil filter.
thechosenone is offline   Reply With Quote
Old 04-24-2012, 02:48 PM   #4
GotCorvette?
CF Senior Member
GotCorvette?'s Avatar
I drive my cars so little now I change them once every year.
GotCorvette? is offline   Reply With Quote
Old 04-24-2012, 03:01 PM   #5
Casper001
CF Senior Member
Casper001's Avatar
I run synthetic and Acura recommends 7500 mile intervals on mine.
Casper001 is offline   Reply With Quote
Old 04-24-2012, 03:05 PM   #6
TurboTnZ06
CF Senior Member
TurboTnZ06's Avatar
I was doing 3k, but with the price of K&N filter and Mobil 1, I switched to 5k miles on my all LSX fleet. I change the oil in my drag car more often, like after each race.
TurboTnZ06 is offline   Reply With Quote
Old 04-24-2012, 03:09 PM   #7
91Vette
CF Senior Member
91Vette's Avatar
I go by the oil life monitor on both of my current cars. It pretty much works out to around every 7,500 miles.
91Vette is offline   Reply With Quote
Old 04-24-2012, 03:16 PM   #8
Larry/car
CF Senior Member
Larry/car's Avatar
Oil life monitor = Mobil 1 - 10,000 + miles Colorado currently has 110,000 total miles, no problems
Larry/car is offline   Reply With Quote
Old 04-24-2012, 03:32 PM   #9
Tormania
CF Senior Member
Cruise-In IV Veteran
Cruise-In V Veteran
Tormania's Avatar
You are dating yourself if you still think 3000 mile oil changes are needed on modern cars. I run Mobil 1 in all of my vehicles. Typically I run the vehicles around 7500-8000 miles between changes.
Now some manufacturers are recommending oil change intervals as long as 10000-15000 miles, depending on car and driving habits.
Some folks will swear by 3000 mile oil changes with the mantra, [redneck accent]"It's cheap insurance" [/redneck accent]. If that's the case, if 3000 miles is good, then 2000 miles is better and 1000 miles is best, right? LOL!
Cars AND oil have improved so much in the last 20-30 years the 3000 mile oil change is a thing of the past. Pre-1980 cars not included.
Tormania is offline   Reply With Quote
Old 04-24-2012, 03:34 PM   #10
Gigdy
CF Senior Member
Gigdy's Avatar
Just before you sell the car.
Gigdy is offline   Reply With Quote
Old 04-24-2012, 03:46 PM   #11
GSMVetteless
CF Senior Member
GSMVetteless's Avatar
2000 honda odyssey - 145k miles - changed every 7500 miles with walmart brand synthetic. ZERO engine issues.
GSMVetteless is offline   Reply With Quote
Old 04-24-2012, 03:52 PM   #12
thechosenone
CF Senior Member
Quote:
Rumor is, that it is just Mobile 1.
Old 04-24-2012, 03:57 PM   #13
Dale1990
CF Senior Member
St. Jude Donor '15
Dale1990's Avatar
5-6k for Vettes and non-Vettes. The Vettes do get Mobil1, though, since it is easy to get.
I've had most vehicles go over 200k with no noticeable oil loss between changes with this method so I'll stick to it.
Dale1990 is offline   Reply With Quote
Old 04-24-2012, 03:57 PM   #14
fishingdan
CF Senior Member
St. Jude Donor '10-'11-'12-'13-'14-'15-'16-'17
fishingdan's Avatar
4k to 5k on my daily driver and 3k on the vettes
fishingdan is offline   Reply With Quote
Old 04-24-2012, 04:01 PM   #15
ptindall
CF Senior Member
ptindall's Avatar
Common sense tells me no matter how good the oil is and how good modern engines are, neither stop dirt and grit from taking its toll over time. How much wear the accumulated dirt and grit causes and how long it would take before it would causes a problem for a failure, I have no idea.
Old 04-24-2012, 04:04 PM   #16
Entropy
CF Senior Member
St. Jude Donor '08-'09
Entropy's Avatar
Around 5000 miles on both cars. My car gets Mobil 1, wife's car gets the Motorcraft syn blend.
Entropy is offline   Reply With Quote
Old 04-24-2012, 04:22 PM   #17
SonOf65again
CF Senior Member
Quote:
Dirt and grit is the job of the filter, but the oil will break down and no longer provide lubrication over time, and can turn into sludge if it is run long enough. It was a big problem with the late 90's Toyota V6's when they recommended 15k service intervals or whatever it was.
SonOf65again is offline   Reply With Quote
Old 04-24-2012, 04:25 PM   #18
Mr.TT
CF Senior Member
St. Jude Donor '10, '15-'16
Mr.TT's Avatar
While you are certainly correct, 3000 is arbitrary, as is 5000. Why not 2000? Every 100 miles would be the best, right?
All our cars have an oil life monitor so we follow that. Barring that, I do what the book says. I figure the owner's manual/DIC is going to be much better than what the oil bottle says, and especially what Jiffy Lube says.
The ones I do have trouble trusting are these new BMWs with 10-15k intervals. Oh, and they have free maintenance for 40k miles... coincidence?
Mr.TT is offline   Reply With Quote
Old 04-24-2012, 04:27 PM   #19
Carguy2112
CF Senior Member
St. Jude Donor '14
Carguy2112's Avatar
I'm typically between 4k to 5k.
Carguy2112 is offline   Reply With Quote
Old 04-24-2012, 04:41 PM   #20
ProfMoriarty
CF Senior Member
ProfMoriarty's Avatar
C6 - end of summer before I put it awway for winter. ~2750 mi
DD - 5K
ProfMoriarty is offline   Reply With Quote
Go Back   CorvetteForum - Chevrolet Corvette Forum Discussion >
Reload this Page
  • Oil Change Frequency Non-Vette
    Related Topics
    Thread Thread Starter Forum Replies Last Post
    A/c Delco Oil filter! 3 Z06ZR1 C6 Corvette General Discussion 10 04-02-2011 12:49 PM
    How much do you pay for an oil change? Blue Lion Off Topic 34 02-28-2011 08:27 AM
    Oil filter.......different sizes??? LT4BUD C4 Tech/Performance 14 10-08-2007 11:01 PM
    Hurst Shift in 1993 6 Speed jpglucker C4 Tech/Performance 1 04-08-2005 10:37 PM
    Let's see the aftermarket c4 wheels! rbesq C4 General Discussion 68 10-14-2004 11:14 AM
    Search this Thread:
    Click for Advanced Search
    Posting Rules
    You may not post new threads
    You may not post replies
    You may not post attachments
    You may not edit your posts
    BB code is On
    Smilies are On
    [IMG] code is On
    HTML code is Off
    Trackbacks are Off
    Pingbacks are Off
    Refbacks are Off
    Forum Jump
