[guns]setting up a guitar case for AR-15 - CorvetteForum - Chevrolet Corvette Forum Discussion
Off Topic
Off Topic | Non-Corvette
Old 09-07-2012, 12:42 AM   #1
Gary04Z06
CF Senior Member
Gary04Z06's Avatar
Default [guns]setting up a guitar case for AR-15
So I picked up am older Fender case I want to setup for an AR, maybe some mags. I found the foam online that is used in standard rifle cases, like Pelicans. Anyone ever convert a guitar case before? Trying to decide if I should rip out the interior and use the foam with cutouts for the rifle, maybe cover the foam in the same material as the lining if I can find it? Keep the interior guitar like or abandon the guitar them and just do the foam?
Not one like in the movie Desperado.
Case basically looks like this, I can take some pics tomorrow.
Found this image (different case than mine) but shows just the foam interior: (probably the easiest)
Closet image I could find leaving the interior. maybe just add some straps to hold things down?
Gary04Z06 is offline   Reply With Quote
Old 09-07-2012, 12:57 AM   #2
DVNTST8
CF Senior Member
St. Jude Donor '09
DVNTST8's Avatar
Location: if you have a ? on my avatar, please contact me directly, you spineless twit
Il Mariachi
DVNTST8 is offline   Reply With Quote
Old 09-07-2012, 05:57 AM   #3
NuckinFutz93
CF Senior Member
NuckinFutz93's Avatar
I just removed the stock linings and filled my electric piano case with cut out foam for my 460s. It has worked great for 4 years and I have drug them everywhere.
NuckinFutz93 is offline   Reply With Quote
Old 09-07-2012, 07:44 AM   #4
C7Joy
CF Senior Member
C7Joy's Avatar
Never thought about doing that but the shape seems very practical for the purpose, especially adding mags and other accessories. Good stealth too!
C7Joy is offline   Reply With Quote
Old 09-07-2012, 09:33 AM   #5
The JOe
CF Senior Member
St. Jude Donor '10-'12
The JOe's Avatar
I made one for a friend a while ago. It wasn't the good pelican foam that plucked out but i did have a electric bow cutter (i cut foam wings for RC planes).
He made a disaster of it and asked me if i could make one after his home was robbed and his gun safe wasn't large enough to hold his quite valuable collection. We lived in a nice neighborhood and i would see him pull guns out to go shooting and always thought it was stupid and kind of flashing to the anti gunners in CA. Although he always loaded his truck to go shooting in the garage after that he did use the guitar case and i even made other instrument cases for him lol...
He took off his NRA stickers and other shooting stickers off his truck asap too... Sadly like anything of value its always best to be low key.
JOe
The JOe is offline   Reply With Quote
Old 09-07-2012, 09:50 AM   #6
Gary04Z06
CF Senior Member
Gary04Z06's Avatar
Quote:
Probably the easiest way to do it.
Old 09-07-2012, 09:52 AM   #7
ProfMoriarty
CF Senior Member
ProfMoriarty's Avatar
Breaking an AR15 style carbine into upper and lower receiver assemblies and using a plastic HD toolbox is another option.
ProfMoriarty is offline   Reply With Quote
Old 09-07-2012, 09:53 AM   #8
Gary04Z06
CF Senior Member
Gary04Z06's Avatar
JOe
That's one of the reasons I am doing it, little stealth. Still get the people that want to steal guitars.
Found this place that has flat foam and will cut to size. I'll just need to cut out for the AR.
http://www.custom-foam-inserts.com/trace-parts.htm
They have several types of foam too.
Old 09-07-2012, 10:47 AM   #9
1Patriot
CF Senior Member
1Patriot's Avatar
Seran wrap and spray foam. The fit will be perfect.
1Patriot is offline   Reply With Quote
Old 09-07-2012, 11:30 AM   #10
Gary04Z06
CF Senior Member
Gary04Z06's Avatar
Quote:
I was wodnering how well that would work...have you done it? Pics?
Old 09-07-2012, 11:33 AM   #11
ProfMoriarty
CF Senior Member
Quote:
I don't know of any spray foam that remains pliable after curing and doesn't chip and abrade at the edges leaving powdery crap, but maybe there's something available.
Old 09-07-2012, 11:49 AM   #12
lite blue
CF Senior Member
St. Jude Donor '12
lite blue's Avatar
Location: I'm going to need a bucket of ice and a roll of gaffer tape
Quote:
I was thinking about this the other day. Saw some tennis racket cases at a sporting goods store. Seems like it would be a good low key way to transport.
lite blue is offline   Reply With Quote
Old 09-07-2012, 11:54 AM   #13
ProfMoriarty
CF Senior Member
Quote:
I've used a polymer HD toolbox. I don't bother with it anymore, but it worked fine.
Line the bottom with foam padding and cut additional foam rectangles to separate the "halves."
Old 09-07-2012, 12:27 PM   #14
~Josh
CF Senior Member
~Josh's Avatar
Make your you have plenty of mags and maybe a spot for a bulk ammo box.
Having just the gun and maybe 2 mags is only enough to get you pinned down and ready to die.
~Josh is offline   Reply With Quote
Old 09-07-2012, 12:33 PM   #15
ProfMoriarty
CF Senior Member
Alrightythen
Old 09-07-2012, 12:46 PM   #16
bonnevillebill
CF Senior Member
bonnevillebill's Avatar
How are you going to pull the trigger with the case still closed? And where do the spent casings wind up?
bonnevillebill is offline   Reply With Quote
Old 09-07-2012, 01:03 PM   #17
Gary04Z06
CF Senior Member
Gary04Z06's Avatar
Quote:
Not setting it up to shot from. Just transport.
Old 09-07-2012, 01:04 PM   #18
Gary04Z06
CF Senior Member
Gary04Z06's Avatar
Couldn't fit enough ammo in there for going to the range.
Only going to put 2-3 mags in there with it, have a backup supply in ammo cans, and mag pouches with a "few" mags ready to go.
Old 09-07-2012, 01:48 PM   #19
PittMD1
CF Senior Member
PittMD1's Avatar
I am not a anti gun guy have several of my own BUT...Why would you need that kind of fire power for walking around?
PittMD1 is offline   Reply With Quote
Old 09-07-2012, 02:02 PM   #20
AGVI
CF Senior Member
Canadian Events Coordinator
AGVI's Avatar
Quote:
good point
AGVI is offline   Reply With Quote
Go Back   CorvetteForum - Chevrolet Corvette Forum Discussion >
Reload this Page
  • [guns]setting up a guitar case for AR-15
    Related Topics
    Thread Thread Starter Forum Replies Last Post
    [Guitars] Got rid of my Fender Hot Rod Deluxe NotSlo Off Topic 13 05-18-2013 12:46 PM
    [Guitars] Anybody used a Tremel-No to lock a floating trem down? DJ_Critterus Off Topic 13 03-13-2013 02:04 PM
    Paul Reed Smith Corvette 427 Standard 22 guitar captej C6 Parts for Sale/Wanted 7 07-08-2010 10:35 AM
    [Guitar] Post your guitars lexaudio Off Topic 78 02-09-2009 09:17 PM
    Show your Bizarre Guitars! VetteSlave Off Topic 27 05-16-2008 12:45 PM
    Search this Thread:
    Click for Advanced Search
    Posting Rules
    You may not post new threads
    You may not post replies
    You may not post attachments
    You may not edit your posts
    BB code is On
    Smilies are On
    [IMG] code is On
    HTML code is Off
    Trackbacks are Off
    Pingbacks are Off
    Refbacks are Off
    Forum Jump
    • Ask a Question
    What's your question?
    Send
