Need Help With Bleeding ABS Brakes On 2003 2500HD Chevy - CorvetteForum - Chevrolet Corvette Forum Discussion
Off Topic
Off Topic | Non-Corvette
Old 11-05-2012, 11:32 AM   #1
K-Spaz
CF Senior Member
I believe in the Beer Fairy
K-Spaz's Avatar
Location: Williamsport PA. The numbers will confess to anything, if you torture them long enough.
Default Need Help With Bleeding ABS Brakes On 2003 2500HD Chevy
I had some troubles with the brakes on my 03 pickup last week. Decided to purchase new calipers for the rear (both sides). While looking, my brake lines on it were rusted pretty bad and I decided to replace most of them. Also stuck on a new master cylinder which probably did not need replaced. It was cheap and easy, and makes me feel better about the whole thing.
So, there's 2 lines from the MC down to the ABS box along the frame rail, 2 lines coming back to the front brakes, all those are new. One line then goes from the abs block to the rear but goes up over the fuel tank and it's not rusted bad so I decided to just leave it be. In any case, now I've got to bleed things and I'm afraid to send air into the ABS block. Searching online to find something specific to the vehicle has not been fruitful, and I figured someone here would know what I'm up against.
The only scan tool I own is an AutoXray 6000 series. I'm pretty sure it does not do abs brakes. Through my reading, I see people say about clamping valves open, and using a scan tool to open them, and also bleeding without opening them. I'm not getting a warm fuzzy feeling about the whole thing.
I'm tempted to remove the master cylinder again and try to bleed it on the bench one more time. I did that already, but only had the plastic plugs for it so it never was perfect, they seem to leak some air back in. So just to feel better about not sending air into the abs box, I was going to try that again. Even though, I think it's fine right now.
I have a helper for pushing the brake pedal, but I do not own a brake bleed kit for one person jobs. If that's a mandatory item, I guess I'll get one, but I don't want to if it's not needed. There is a Harbor Freight 15 miles away, but theirs have very mixed reviews.
Any help with a procedure for the abs module is very much appreciated. I do not own a service manual for the truck. Probably should get one...
K-Spaz is offline   Reply With Quote
Old 11-05-2012, 11:46 AM   #2
wcsinx
CF Senior Member
wcsinx's Avatar
I'll look in my service manual tonight if nobody gives you a definitive answer before then.
But I'm pretty sure you can just bleed normally. That is to say, the fluid circuit is just like a non-ABS car unless the ABS is actually operating (pumping). Now on the other hand if you actually want to flush the fluid out of the ABS module (which may not be a bad idea on an '03) that's where you get into the scan tool wizardry.
And FYI you'll never get a perfect bench bleed on an MC. You just need enough fluid in the piston so that you're not air locked when you go to bleed the wheel cylinders. Also bear in mind you'll need to bleed all the new lines as well while they're disconnected.
wcsinx is offline   Reply With Quote
Old 11-05-2012, 11:48 AM   #3
Umrswimr
CF Senior Member
St. Jude Donor '05
Umrswimr's Avatar
Location: Overwhelmed as one would be, placed in my position.... DFW, TX
IIRC- If you get air in the ABS, you'll basically need a TECHII to open the ABS valve to bleed the air out. I had the same issue on my C5 and no amount of bleeding would fix it. The only other recommendation I saw was to repeatedly engage the ABS (which is really hard when there's air in there) and bleed the brakes until you get the air out. I changed a gallon of brake fluid and finally had to take it in. I think they charged me $150.
Umrswimr is offline   Reply With Quote
Old 11-05-2012, 11:54 AM   #4
chevyjeff
CF Senior Member
chevyjeff's Avatar
gravity bleed or use vacuum system first to get most of all air out of lines.
then go out to gravel or dirt road and lock the brakes up a few times to engage abs.
then re-bleed same as above. rinse repeat untill pedal no longer goes to floor.
chevyjeff is offline   Reply With Quote
Old 11-05-2012, 11:57 AM   #5
K-Spaz
CF Senior Member
K-Spaz's Avatar
Thanks guys. Mostly I guess I'm worried about what a few people say, that damage to the abs unit can occur if you stick air in there. I find that hard to imagine, but stranger things have been known to be true. Even if I do have to take it somewhere to get it done, I want to be able to bleed them to where it's safe to drive, and of course not cause permanent damage. I decided to wait before beginning the process in case there was a trick to it and it's not reversible if I do something wrong first.
/crossposting edit...
ChevyJeff, gravity bleed = same thing as using a pedal? These are 1/4" lines, so I'm not sure air will move down the lines with the small amount of flow when using gravity to do the job.
Old 11-05-2012, 12:30 PM   #6
chevyjeff
CF Senior Member
chevyjeff's Avatar
gravity bleed. =
Remove top off master cylinder, crack open furthest bleeder screw (pass rear I think) drink a beer and wait for fluid to run out until it looks clean keep eye on fluid level in master cylinder. Do not let it run dry.
Close bleeder screw and move to drivers rear and repeat. Then do pass side front then the driver side front.
I have had good luck w this technique, my vaccum pump bleeder tends to draw air bubbles past the bleeder screws so it is hard to tell when all air is out. I usually start off w/ vaccum pump to kick start process and then let it gravity bleed until clear fluid comes out. (you may have to wait 10 min or more to get fluid to come out w/ out kick starting it w/ pump). Chances are if it wont gravity bleed you may have a restriction in the system.
Old 11-05-2012, 01:16 PM   #7
K-Spaz
CF Senior Member
K-Spaz's Avatar
I'll give it a shot. Only restriction would be the abs module with everything else new.
Thanks again!
Old 11-05-2012, 01:59 PM   #8
Pilot Dan
CF Senior Member
Pilot Dan's Avatar
with Chevyjeff. I had to replace ALL my brake lines last month in my 2004 Chevy 1500 and gravity bleeding worked fine. I did not disturb the master cylinder, so I am thinking as well that your M/C still has some air in it.
Pilot Dan is offline   Reply With Quote
Old 11-05-2012, 02:00 PM   #9
JackDidley
CF Senior Member
JackDidley's Avatar
Does it have hydroboost ? I did a 94 dually recently and had to have the motor running to get it bled. Dont know why but its the only way I could get all the air out.
JackDidley is offline   Reply With Quote
Old 11-05-2012, 02:27 PM   #10
MGorman
CF Senior Member
MGorman's Avatar
I recently replaced all the brake lines (from the master cylinder to the rear calipers) on my neighborís 2002 2500HD. I too was concerned about needing a TechII to bleed to air out of the ABS pump.
I ended up using a pressure bleeder. It worked perfectly. It bled every last bit of air from the system and was really easy to use.
MGorman is offline   Reply With Quote
Old 02-12-2015, 12:54 PM   #11
hdiscus7
Junior Member
Default pilot dan, question for you
I just replaced one of my rear brake lines on my 2003 chevy silverado 4x4 1500 and in order to do so I had to remove my brake line from the abs module ofcourse and had to remove the two lines going to the front and rear proportioning valves just to access the rear brakeline with a wrench. after replacing the rear brake line i put them all back in the abs module and did a regular manual bleed of the system and noticed the pedal was still very soft, although when i bled the system i had a steady stream of fluid on all calipers. Do you think there could still be air in the abs module that i unscrewed other lines on? The master cylinder never ran dry. Maybe there is a small leak in the new brake line I installed? if there is would it cause my brake to be soft even if its minimal? will air get into my abs module when replacing brake lines? Ive just got to get this sucker back on the road before duty tomorrow. Hope to hear from you soon? thanks!
Jordan
hdiscus7 is offline   Reply With Quote
Old 02-12-2015, 01:02 PM   #12
tomc8at
CF Senior Member
tomc8at's Avatar
2500hd do rule...
tomc8at is offline   Reply With Quote
Old 02-12-2015, 01:06 PM   #13
hdiscus7
Junior Member
Default confused
im new to the thread and forum and dont understand what youre saying about "do rule". Im confused,My apologies
Old 02-12-2015, 01:23 PM   #14
Strats-N-Vettes
Friend Request Magnet
Support Corvetteforum!
Strats-N-Vettes's Avatar
Quote:
Originally Posted by tomc8at View Post
2500hd do rule...
Quote:
.....he is giving your truck a compliment.
brake bleeding your truck:....yes...still air in lines you cannot get out manually.
Find a shop with a powered pulse bleeder and problem solved.
Strats-N-Vettes is offline   Reply With Quote
Old 02-12-2015, 01:57 PM   #15
MN-Brent
CF Senior Member
MN-Brent's Avatar
Id try it again with the Motive Power Bleeder - cheap and effective. If that doesn't get it, then take it in.
MN-Brent is offline   Reply With Quote
Go Back   CorvetteForum - Chevrolet Corvette Forum Discussion >
Reload this Page
  • Need Help With Bleeding ABS Brakes On 2003 2500HD Chevy
    Related Topics
    Thread Thread Starter Forum Replies Last Post
    Anyone have a GM tech 2 scanner so I can bleed my C5 brakes? regorih C5 Forced Induction/Nitrous 14 03-10-2014 04:16 PM
    Help - Bench Bleed Master Cylinder 98IndyPacer C3 Tech/Performance 7 07-15-2008 09:12 PM
    If the master cylinder ran dry... Terrible Juan C4 Tech/Performance 8 03-21-2008 12:08 AM
    Bleeding the Brakes ABS module mitchcole C4 Tech/Performance 7 11-07-2004 10:32 PM
    Brake Bleeding dndrsn C4 Tech/Performance 7 07-31-2004 12:40 AM
    Search this Thread:
    Click for Advanced Search
    Posting Rules
    You may not post new threads
    You may not post replies
    You may not post attachments
    You may not edit your posts
    BB code is On
    Smilies are On
    [IMG] code is On
    HTML code is Off
    Trackbacks are Off
    Pingbacks are Off
    Refbacks are Off
    Forum Jump
    • Ask a Question
    What's your question?
    Send
