Septic tank experts: is Rid-X any good? Or bad? - CorvetteForum - Chevrolet Corvette Forum Discussion
Off Topic
Off Topic | Non-Corvette
Old 06-04-2013, 02:04 PM   #1
SLO VETTE
CF Senior Member
SLO VETTE's Avatar
Default Septic tank experts: is Rid-X any good? Or bad?
Subject says it all.....
Question is for family member with a residential tank, about 1250 gal, with 3 dry wells for the liquids. Tank and wells running perfect thus far for about 2 decades, and it gets annual pumping and inspection.
I've read conflicting reports on Rid-X, and the septic service (who's continually serviced the system) has said absolutely do not use it. I'm just wondering it that's to ensure their continued service bill.
SLO VETTE is offline   Reply With Quote
Old 06-04-2013, 02:07 PM   #2
The_Dude
CF Senior Member
St. Jude Donor '11, '16
The_Dude's Avatar
Why bother if you're pumping annually. Our septic guy told us every 5 years was fine.
The_Dude is online now   Reply With Quote
Old 06-04-2013, 02:15 PM   #3
Czarvette
CF Senior Member
Czarvette's Avatar
Heard the same from our septic guy. Problem supposedly is that it liquifies the sludge which is then transported to your leach field, where it resolidifies and clogs up the leach field.
Better to have the tank pumped on a regular basis. The purpose is to remove the sludge that settles in bottom of the tank, but annual pumpings sound way too often. How much sludge is really in there after a year?
Czarvette is offline   Reply With Quote
Old 06-04-2013, 02:17 PM   #4
jmc12
CF Senior Member
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17
jmc12's Avatar
I have heard not to use it, no matter if you use it are not, you still need to pump the tank at least every two years..
With that being said (pump every two years) after I bought my house, within two years it needed to be pumped.. When the guy took the cover off he said, I bet this has never been pumped out, see how thick the crust is, he had to break it apart with a shovel..
jmc12 is online now   Reply With Quote
Old 06-04-2013, 02:20 PM   #5
98vert6spd
CF Senior Member
98vert6spd's Avatar
pump every 3-5 years and dont do anything else to it.
Also if you have a pump in it that pumps the water into the field, i tend to replace those with normal sump pump rather than grinder pumps.
I could be wrong but heres my mentality on it.
If the pump sucks up a solid somehow which could happen, or a tampon string or who knows what. Rather than the pump grind it up and send it into my leach field, id rather it burn up the pump. then i go to HD and pick up another sump pump for 129 or even free if the old one was still under warranty and im back in business as opposed to having a bunch of solids in my leach field.
I do this with all of my rental properties and my house. has worked so far.
98vert6spd is offline   Reply With Quote
Old 06-04-2013, 02:21 PM   #6
Mirroredshades
CF Senior Member
Mirroredshades's Avatar
I was watching hgtv or something and they said that flushing a thing of yogurt once a month is better than the $8 treatments. Don't know if it's true but we go through a ton of yogurt.
Mirroredshades is offline   Reply With Quote
Old 06-04-2013, 02:25 PM   #7
SLO VETTE
CF Senior Member
SLO VETTE's Avatar
I guess this question is like asking which pizza is better, pepperoni or mushroom?
Thanks for the info though.
Old 06-04-2013, 02:25 PM   #8
UNX PGMR
CF Senior Member
UNX PGMR's Avatar
Total waste of money.
According to RID-X (http://www.rid-x.com/faq.shtml)
Q: How does RID-X work?
A: RID-X Septic Tank System Treatment contains billions of 100% natural active bacteria and enzymes to break down household waste. By adding RID-X, you restore the delicate balance of beneficial bacterial and enzymes needed to help keep your system operating at full efficiency.
But according to Washington State University http://clark.wsu.edu/horticulture/sm...-additives.pdf
The simple act of using the system promotes the growth of bacteria needed to make the system work. The amount of
bacteria or enzyme in an additive dose remains small compared to the bacteria already in a tank and therefore provides little, if
any, benefit in wastewater breakdown. In addition, if many of the bacteria in your tank died due to introduction of a harmful
substance, introduced bacteria will likely die as well. One study of 48 septic tanks found no difference in sludge level between
tanks that used bacterial additives and those that did not (McKenzie, 1999).
UNX PGMR is offline   Reply With Quote
Old 06-04-2013, 02:26 PM   #9
The_Dude
CF Senior Member
The_Dude's Avatar
Quote:
I eat a lot of yogurt, so it gets in there one way or the other.
Old 06-04-2013, 02:30 PM   #10
EuroRod
CF Senior Member
EuroRod's Avatar
My tank is 27 years old. Never flushed. Never pumped. Never put in additional bacteria.
Never had a minutes problem.
My garden is built over my septic field, and it grows great veggies!
EuroRod is offline   Reply With Quote
Old 06-04-2013, 02:32 PM   #11
Mirroredshades
CF Senior Member
Quote:
That's what I'm sayin Dude.
Old 06-04-2013, 02:33 PM   #12
jmc12
CF Senior Member
jmc12's Avatar
I bet it is getting close to pump time, you have to have a lot of solids in there.. That is about how old my house is..
What hapenned was the crust got so high it would not let water out, that is what the guy told me..
Old 06-04-2013, 02:36 PM   #13
The_Dude
CF Senior Member
The_Dude's Avatar
It's not fun when it decides to backup.
Old 06-04-2013, 02:38 PM   #14
Railroadman
CF Senior Member
Railroadman's Avatar
Septic guy told me use Rid-X and buttermilk. You're scaring me with these "don't ever" stories!
Railroadman is offline   Reply With Quote
Old 06-04-2013, 02:39 PM   #15
The_Dude
CF Senior Member
The_Dude's Avatar
Quote:
It may be a waste of money, but I seriously doubt it's harmful.
Old 06-04-2013, 02:43 PM   #16
Mirroredshades
CF Senior Member
When I bought my house, it hadn't been done in 15 years. It was about 1/3 full of chit. Don't know why people think it needs to be done every few years. Unless you are related to Gozar.
Old 06-04-2013, 02:46 PM   #17
corvettezman
CF Senior Member
Support Corvetteforum!
St. Jude Donor '11-'12-'13, '15, '16-'17
corvettezman's Avatar
corvettezman is online now   Reply With Quote
Old 06-04-2013, 02:46 PM   #18
The_Dude
CF Senior Member
The_Dude's Avatar
We let it go for something like 8 or 9 years. Septic guy said it was time, and that the recommended interval was 5. We don't have a pump in our system though.
Old 06-04-2013, 02:56 PM   #19
Bingo Fuel
Let Me Bignofi That For U
St. Jude Donor '15, '17
Bingo Fuel's Avatar
^ This
Adding RID-X is like adding a teaspoon of salt to the ocean.
Try not to use bleach in your laundry or drain cleaners that kill off the bacteria.
If you're concerned about solids getting into the drainfield,
install an in-expensive filter on the out-flow side of the septic tank.
When you have your tank pumped, they remove the filter, hose it off and re-install it.
Bingo Fuel is offline   Reply With Quote
Old 06-04-2013, 03:00 PM   #20
Swany00
CF Senior Member
Swany00's Avatar
nice
Swany00 is online now   Reply With Quote
Go Back   CorvetteForum - Chevrolet Corvette Forum Discussion >
Reload this Page
  • Septic tank experts: is Rid-X any good? Or bad?
    Related Topics
    Thread Thread Starter Forum Replies Last Post
    Sump Pump Discharge - Where does it go? Gipper Off Topic 22 10-11-2016 10:54 PM
    Experience with septic mound systems? Dale1990 Off Topic 15 12-12-2014 02:06 AM
    Need cost for well and septic system jasper711 Off Topic 16 11-22-2009 09:45 PM
    Septic drain field mystery CFB Off Topic 13 11-16-2008 12:37 PM
    Septic tanks..... Mrs. K Off Topic 52 05-20-2008 06:47 AM
    Search this Thread:
    Click for Advanced Search
    Posting Rules
    You may not post new threads
    You may not post replies
    You may not post attachments
    You may not edit your posts
    BB code is On
    Smilies are On
    [IMG] code is On
    HTML code is Off
    Trackbacks are Off
    Pingbacks are Off
    Refbacks are Off
    Forum Jump
    • Ask a Question
    What's your question?
    Send
