What's the difference between a Small Block & Big Block V8? - CorvetteForum - Chevrolet Corvette Forum Discussion
Off Topic
Off Topic | Non-Corvette
Old 12-04-2013, 06:55 AM   #1
s'noJob
CF Senior Member
s'noJob's Avatar
Default What's the difference between a Small Block & Big Block V8?
I know the straight vs AFU answer ratio is going to be high on this one.
Yeah, I get it:
small block BIG BLOCK
But I've heard these terms for years and never really understood the distinction.
s'noJob is offline   Reply With Quote
Old 12-04-2013, 07:00 AM   #2
MillertimeZ06
CF Senior Member
MillertimeZ06's Avatar
I've never really understood the difference between something small or big either
MillertimeZ06 is offline   Reply With Quote
Old 12-04-2013, 07:11 AM   #3
CHASLS2
CF Senior Member
St. Jude Donor '13
One weighs more than other also.
CHASLS2 is offline   Reply With Quote
Old 12-04-2013, 07:17 AM   #4
siege101
CF Senior Member
siege101's Avatar
As far as I know, its just that. One is bigger than the other.
siege101 is offline   Reply With Quote
Old 12-04-2013, 07:22 AM   #5
Easy Rhino
CF Senior Member
Easy Rhino's Avatar
There is no exact definition to answer the question you seek, only generalizations, but excess meaningless passion.
Some engines fit well into a so-called small block/big block categorization, e.g. small block chevy (265, 283, 302, 305, 307, 327, 350, etc.) and the big block chevy (396, 427, 454), and some don't, e.g. Pontiac some Mopar V-8s. Add to that some large displacement engines are boat anchors while some large displacement engines are smaller blocks.
Easy Rhino is offline   Reply With Quote
Old 12-04-2013, 07:27 AM   #6
Jughead
Senior Member since 1492
Support Corvetteforum!
St. Jude Donor '09
Jughead's Avatar
Location: 1.Just because I'm paranoid doesn't mean people aren't out to get me... 2.That which does not kill me will probably hurt like hell. Obama-shortest legacy ever!
that is my understanding as well. SB also referred to as a Mouse and BB called a Rat. I have a RAT.
Jughead is offline   Reply With Quote
Old 12-04-2013, 07:29 AM   #7
Easy Rhino
CF Senior Member
Easy Rhino's Avatar
Quote:
But the BB is also called the porcupine engine, and the Hemi called the elephant.
Old 12-04-2013, 07:30 AM   #8
Jughead
St. Jude Donor '09
Jughead's Avatar
I never heard that about the Hemi, but I'm hardly a Chrysler groupie.
Old 12-04-2013, 07:34 AM   #9
Easy Rhino
CF Senior Member
Easy Rhino's Avatar
Have you heard the jole about the duck and the nailhead Buick?
Old 12-04-2013, 07:54 AM   #10
Jughead
St. Jude Donor '09
Jughead's Avatar
must be before my time.
Old 12-04-2013, 07:58 AM   #11
SouthernSon
CF Senior Member
SouthernSon's Avatar
Location: Deal's Gap 2004 NCM Motorsports track supporter
Those little nail heads back in the 60's could fly! Even had two 4 barrels on some of them. The old rivieras were great.
As far as BB vs. SB, the torque difference is considerably different but I guess the physical size difference is the defining word. But, a small block overhead cam engine is probably larger than a BB pushrod.
SouthernSon is offline   Reply With Quote
Old 12-04-2013, 08:15 AM   #12
TerryL
CF Senior Member
St. Jude Donor '17
The current Vette motors are all SB's right? The base 364ci (and) the 427? Larger cubic inch but from a SB not the old BB. Boring and/or changing the stroke can add cubic inches to a motor but starting with a BB usually gives you more to...work with. 265s grew into 283s and then 327s and even a 383 'stroker' but never into 396 or 427s. They started as BBs.
TerryL is offline   Reply With Quote
Old 12-04-2013, 08:41 AM   #13
jim2527
CF Senior Member
jim2527's Avatar
Small blocks have a bore spacing of 4.4"
Big Blocks have a bore spacing of 4.84"
Bore spacing is the distance between the centerline of the pistons.
Wider bore spacing allows for larger pistons. Larger pistons require bigger blocks.
Small block and big block engines have essentially the same bore and stroke at 400 cid.
jim2527 is offline   Reply With Quote
Old 12-04-2013, 08:47 AM   #14
jim2527
CF Senior Member
jim2527's Avatar
Quote:
Kind of sort of..
The 'new' LS engines have the same bore and bore center line as the old SBC. The old SBC's were available as 400's.
At 400 cid the LSX has a similar bore and stroke the old BBC. At 427 cid its similar as well. 427 is about the max displacement for a LSX engine due the bore size. BBC can go up to 572 cid or so due its much larger bore size.
Old 12-04-2013, 09:03 AM   #15
Capt Van
CF Senior Member
St. Jude Donor '12, '16
Capt Van's Avatar
This is a small block, 283/245
This is a small block 427 (ZR1)
This is a big block 427/400
This is a great big block 10 cylinder 2014 Viper
Capt Van is offline   Reply With Quote
Old 12-04-2013, 09:15 AM   #16
pappy.72
CF Senior Member
pappy.72's Avatar
Quote:
Originally Posted by Capt Van View Post
This is a small block 378 (ZR1) (The Z06 has the 427)
fixt
pappy.72 is offline   Reply With Quote
Old 12-04-2013, 09:38 AM   #17
JetMechZ16
CF Senior Member
JetMechZ16's Avatar
The Mouse and Rat distinctions are for Chevrolet engines only.
I've asked this question before also. I phrased it a bit differently though as I asked what the defining characteristic is between the two. I have never gotten an answer to the defining characteristic. I know it is NOT displacement or physical dimmensions. Yes I understand that they are physically larger on the big block, but at what point does the engine change from being considered a big block or small block. We have 383 big blocks and some smaller displacement engines are also big blocks. We also have 454 small blocks and 454 big blocks.
Could it be the bore to stroke ratio? Longer stroke than bore size equating to a big block maybe? Or can you have a small block with a longer stroke than bore?
Or could it be deck height?
JetMechZ16 is offline   Reply With Quote
Old 12-04-2013, 09:44 AM   #18
JetMechZ16
CF Senior Member
JetMechZ16's Avatar
This would be true for one engine manufacturer, but not all.
Different engine manufactuerers have different bore spacings. i believe deck height also plays a role.
Old 12-04-2013, 09:44 AM   #19
lakota
CF Senior Member
Add original Chevy BB 348 which became 409, both had scalloped valve covers.
https://www.google.com/search?q=348/...KpsASnvYH4DQ&v
lakota is offline   Reply With Quote
Old 12-04-2013, 10:07 AM   #20
nate99
CF Senior Member
nate99's Avatar
Interesting question, but there is no science to the terms. It's mostly just what car guys have colloquially adopted as a distinction over the years. If you have read magazines like Hot Rod or Car Craft for a couple of decades, you probably have it sorted out.
GM/Chevy decided to use the "small block" descriptor that had been used for decades for the 265-400 c.i. family of 4.4" bore spaced V8's on the new LS engines that retained the 4.4" bore spacing, but essentially nothing else from the earlier engines.
Chevy exclusively used the same two blocks for so long, it made sense, but other manufacturers had engines come and go (or be modified more extensively) on a more regular basis that the comparison doesn't make much sense. A big block Ford is generally understood to be the 460 block, but the Ford FE was in between that and the Cleveland and Windsor V8's, so it doesn't make as much sense. Mopars had the LA engines that were their smallest V8's, but they had the B engines that went up to 440 ci and the Hemi engines that went to 426 from the factory.
Some call the shorter deck 350 and 403 Olds motors "small blocks", but they are otherwise architecturally the same (bore spacing, etc.).
nate99 is offline   Reply With Quote
Go Back   CorvetteForum - Chevrolet Corvette Forum Discussion >
Reload this Page
  • What's the difference between a Small Block & Big Block V8?
    Related Topics
    Thread Thread Starter Forum Replies Last Post
    Danney Williams abandoned son of president Bill Clinton, will file paternity suit!!!! vigalante Politics, Religion & Controversy 72 10-20-2016 11:44 AM
    2nd Annual Blockhead Picture Thread Part: 3 Vasta Southern California 3 01-03-2009 09:53 PM
    FS: 5.7L Aluminum block bored 3.905, Diamond Pistons LS1 Forged Dished Piston set 383c5 C5 Parts for Sale/Wanted 45 10-08-2008 06:40 PM
    Featured Corvette C5 ZO6 TicketBait C5 General 12 11-06-2007 12:42 PM
    how do u know if its a big or small block? 1980 razz C3 Tech/Performance 8 10-24-2001 10:29 PM
    Search this Thread:
    Click for Advanced Search
    Posting Rules
    You may not post new threads
    You may not post replies
    You may not post attachments
    You may not edit your posts
    BB code is On
    Smilies are On
    [IMG] code is On
    HTML code is Off
    Trackbacks are Off
    Pingbacks are Off
    Refbacks are Off
    Forum Jump
    • Ask a Question
    What's your question?
    Send
