Livernois/RHS 429ci Stroker for 2006 CTS-V
Supporting Tuner
An out of state customer sent his 2006 CTS-V to us for a long list of modifications.
We are currently building the new engine which is based of off an RHS aluminum block. This will be a N/A 429ci build
Parts consist of:
Livernois Forged Steel Stroker Crankshaft
Livernois Exclusive 11:1 compression Forged Pistons w/ Fully Coated Top and Skirts
Livernois Exclusive Rings, Locks, and Wrist Pins
Livernois Spec H-Beam Rods w/ ARP 2000 Bolts
Livernois CNC LSX-LS7 Cylinder Heads
Livernois Stage 2R Max Camshaft
Comp Short Travel Race Hydraulic Roller Lifters
Coated Bearings
ARP Studs
Melling Oil Pump
Here are some photos minus intake and covers
We will also be installing:
Kooks Longtube Headers
Kooks Midpipe w/ Cats
Corsa Exhaust
CAI
LS9 Clutch
Aluminum Flywheel
Shifter
Coil Overs
Sway Bars
Toe Rods
Trailing Arms
9" Differential
35-Spline Axles
Thanks for looking!
Regards,
Rick LeBlanc
Livernois Motorsports
Parts consist of:
Coated Bearings
ARP Studs
Melling Oil Pump
Corsa Exhaust
CAI
LS9 Clutch
Aluminum Flywheel
Shifter
Coil Overs
Sway Bars
Toe Rods
Trailing Arms
9" Differential
35-Spline Axles
Thanks for looking!
Regards,
Rick LeBlanc
Supporting Tuner
Supporting Tuner
Supporting Tuner
We have several C6Z N/A stock bottom end head/cam, bolt-on builds that make 600-630 RWHP with our stage 3 camshaft, but it's more aggressive than he wants in this car.
Thank you,
Rick
I'm not sure. He's not using a very aggressive camshaft. Specs are 235/242 .603/.618 114 LSA.
Thank you,
Rick
Thank you,
Rick
