Other Cars Non-Corvette Content, Daily Drivers, Winter Beaters, Work Trucks, Tow Vehicles, for sale
FS: Rare 98 Cobra Convertible
Old 07-23-2014, 04:32 AM
PIXER
PIXER's Avatar
Default FS: Rare 98 Cobra Convertible
SOLD
I know the chances of someone on this forum seeing this and being interested are slim... But doesn't hurt
The time has finally come for me to sell my 1998 Cobra Convertible in the beautiful Bright Atlantic Blue. (1 of 227 ever made in this color)
I have owned this car for over 6.5 years now and simply don't drive it. I would love to hold onto it forever but it just doesn't make sense.
It was almost 100% stock when I bought it and I was pretty heavy into dedicating all my time and energy into it for the first 2-3 years... But since getting a fun DD and then 1.5 years ago getting a 13 GT500 I have come to realize it had been nearly 3 years since I bought anything for it (until recently to prepare it for sale).
Everything works as it should, A/C is cold, heat is hot, and I would feel confident driving it anywhere. However, I wouldn't for fear of rain (this car has NEVER seen rain in the entire time I have owned it)
I just finished having it professionally detailed top to bottom including Adams Polishes paint correction. The Paint looks absolutely stunning. Given its age and miles people are dumb founded when I tell them its almost all original paint.
Included in the sale of the vehicle will be a thumb drive with over 300 photos taken over the years of the vehicle in different stages, and different mods being installed.
Also included is "the book". With every single receipt, purchase order, item details and description of every item weather mod or replacement from the day I purchased the vehicle... totaling over $21,000 not including the price of the vehicle.
Engine:
• MMR 900 Shortblock using 18CC pistons (8.5:1 CR)
• ARP Mains
• ARP Headstuds
• ARP 2000 Rod Bolts
• ARP Crank Bolt
• HV FRPP oil pump with Cryo treated gears
• MMR Felpro head gaskets 0.036 thick
• 03 Cobra tick fixed “C” heads
• LDC Coiling mod to heads
• At time of built: all new gaskets throughout and new chain tensioners
• Mach 1 upper and lower intake manifold with intake spacer
• ’99 Cobra Throttle Body
• ’99 Cobra cruise and throttle cables
• Poly Motor mounts
• New water pump, plugs, and wires (FRPP red)
• Accell Coil Packs
• 220 Amp High Output Alternator (installed 1 month ago)
• JLT color matched cold air intake
• Home made “catch can”
Power Adder:
ZEX “wet” Nitrous System 125 Shot with ALL the toys including:
• Wide Open Throttle switch
• Window switch (allows to set amount of nitrous per RPM and gear)
• Zex purge kit (Nitrous Purges out Snake in grill’s mouth)
• Remote Bottle Heater
• Remote Bottle opener
• N20 gauge on bottle
• Stainless steel lines throughout
Transmission/ Driveline:
• D&D Viper spec T-56 6-speed (26 spline)
• Spec stage 3+ clutch
• MGW Shifter
• MMR Throw Out Bearing
• Poly Trans mount
• Speed-cal electronic speedometer adjuster
• 03 Cobra aluminum Driveshaft
Rear End:
• 31 Spline Superior C-clip axles
• FMS 31 spline track-lock differential
• FRPP 4:10 gears
• Trick flow aluminum girdle rear end cover
• All new gaskets/ seals at time of install
• UPR billet 8.8” spherical bushings
Suspension:
• UPR Extreme series Upper control arms
• Maximum Motorsports XD Lower Control Arms
• UPR maximum rear lower coil over brackets
• UPR rear coil-overs with Lakewood drag shocks
• PA Racing Tubular K-member
• PA Racing Tubular A-arms
• PA Racing front Coilovers with Afco street springs
Exhaust:
• BBK Longtubes
• BBK Off Road H Pipe
• Magnaflow Catback that was hand polished for a show quality shine
Interior/ Electronics:
• Blue LEDs replace all factory lighting
• Hurst Roll Control Line Lock
• Speed of Sound A-piller gauge pod
• Steering Colum gauge pod
• “Frog Eyes” gauge pod
• Custom radio gauge pod with 3 gauges, switches and indicator lights for bottle opener and heater
• Raptor Shift light with launch control feature
• Autometer Phantom: Boost/ Vac, Pyrometer, Wideband Air/ Fuel, Oil Temp, Oil Pressure. Water Temp, Fuel Pressure and Nitrous Pressure gauges all hooked to factory light dimmer
• JVC headunit with Bluetooth and Bluetooth audio streaming
• CDC lightbar
• Pioneer speakers throughout and new Mach door tweeters
• American Muscle Cobra floor mats
• Factory tonnue cover
Exterior/ Wheels/ Tires Brakes:
• Just professionally detailed and full 4 step Adam’s Polishes Paint correction
• New OEM front bumper just painted and installed (due to license plate holes)
• New Keanan Saleen S281 spoiler just painted and installed
• Tinted rear markers/ tail lights/ 3rd brake light
• “Cobra” stainless steel rear bumper inserts
• Smoke headlights and corners
• HID Headlights and fogs
• Tint- 5% all around, 35% entire windshield
• “fogs only” mod
• Underside of vehicle, specifically the rear end has several powder coated/ painted items to increase the show aspect for drivers following the vehicle (such as powder coated sway bar, and full POR 15 of the underside of the vehicle/ rear end)
• Plate flipper rear license plate (license plate flips down at the touch of a button inside the cab)
• Wheel spacers on both front and rear to make wheels/ tires flush
• Saleen style Chrome 18x9 and 18x10.5 wheels with Saleen center caps
• Extensively modified rear wheel wells/ fenders to fit 335/30/18 BFG KDW 2 rear tires
• 265/35/18 BFG KDW 2 front tires
• Painted brake calipers
I am 100% sure I am forgetting items, but that is the benefit of the “the book” for you to be able to review when items were purchased and installed.
This a solid built Car that turns heads and is a blast to drive.
It was tuned with SCT software by Lee Blankenship and is begging for boost.
On its 8.5:1 CR engine it made 281RWHP, 304 RWTQ N/A and on a 100 Shot it made 360 RWHP, 424 RWTQ.
It currently has the jets for a 125 shot installed… To be honest I never raced anyone with the N20 and really only cruise with the car if the weather is perfect. It has never been to the drag strip, although at 1 time I did have slicks and skinnies for the car (loved the look).
The car has just under 96k on the chassis and 7-8k on the engine/ transmission. I simply just don’t drive the car.
I am located in the Louisville area and can travel within reason to deliver the car.
The price is $13,900 and no trades please.
Please don’t hesitate to ask me any questions and come look the car over yourself.
It is in great shape (as the photos indicate) but it is definitely not perfect due to its age.
PIXER is offline
Old 07-31-2014, 04:00 PM
PIXER
PIXER's Avatar
Now on Autotrader:
http://www.autotrader.com/cars-for-s...78341720&Log=0
PIXER is offline
Old 08-07-2014, 11:49 AM
PIXER
PIXER's Avatar
Price Drop to $14,500
PIXER is offline
Old 08-11-2014, 08:23 PM
PIXER
PIXER's Avatar
Bump
PIXER is offline
Old 08-19-2014, 12:40 AM
PIXER
PIXER's Avatar
Bump
PIXER is offline
Old 08-20-2014, 12:33 PM
PIXER
PIXER's Avatar
$13,900
PIXER is offline
Old 08-22-2014, 09:47 PM
PIXER
PIXER's Avatar
Now on Ebay
http://www.ebay.com/itm/Ford-Mustang-SVT-Cobra-RARE-98-Bright-Atlantic-Blue-Cobra-Convertible-/111442848801?forcerrptr=true&hash=item19f282ec21&item=111442848801&pt=US_Cars_Trucks
PIXER is offline
Old 08-31-2014, 02:46 PM
PIXER
PIXER's Avatar
Sold
PIXER is offline
To FS: Rare 98 Cobra Convertible
Quick Reply: FS: Rare 98 Cobra Convertible
