2004 Silverado Body Mount Bushings question
Has anyone found an aftermarket replacement body mount bushing kit in RUBBER?? There are plenty in Polyurethane available but I have heard the ride is stiffer and they raise the body height by 1/2 inch.
Original OEM are available from the GM dealer in individual pieces from what I see (no kit) and the cost (list over $100 for just one) is way more than the whole replacement Prothane kit. Thanks in advance for any suggestions. I really just need to fix one corner. Dan
To answer your question, I have always been a GM truck guy, but I think this is the last one for me. The quality is poor in many areas. Not what it should be or was in my older trucks. So far, in the last 2 years, had to replace all the brake lines, now the body mounts, dealt with an engine coolant leak that was bad, ignition switch had to be R&R to fix that problem, several dash bulbs are out and they are not serviceable (LED's that are part of the circuit board) and the list goes on. All this on a 70,000 mile truck!!!! Most of the problems can be directly related to the bean counters cheaping out on key components and poor design and execution to save a few pennies. For instance, the clutch pedal is made out of plastic, PLASTIC!! It's a shame I had my last Silverado 23 years and it was a much better made truck.
