427 bbc covette engine
I have a 427 bbc. block # is 3963512. The #'s on the front is "TO122LM" Then it has 19S716080 on the same flat area in the front. (right side) Is it worth anything? Or should I just use it in my Camaro as planned.
Thanks guys
Thanks guys
St. Jude Donor '08
Here's the deal ....both could be 2or 4 bolt mains the .the T O in the serial leads me to think truck ..MAY BE NOT
It was used in 1969 and it is a 396
It was also used in1970 ...thru 1976 as a 454...
just key up Chevy Big Block and you can trace it...HAVE FUN ..I HAVE PUT BIG BLOCKS IN EVERYTHING FROM Chevelles to a 1963 Suburban ..Keep me posted I have all kinds of parts..
In addition to what others have shared in your thread, here's a site with more info:
http://www.mortec.com/bbc.htm
If you really want to sell the engine, post/advertise in the Corvette Forum C3 parts for sale section.
Furthermore, if interested, you could post/advertise the engine in the NCRS website, C3 Documents and Stamped Parts. The engine might be worth a bit more money to a C3 owner.
A perusal of the 2 sites might give you some indication of engine worth and help you decide if you want to sell it.
If the engine is original to a C3, the likelihood of re-uniting it with the original car is 'needle in a haystack' venture.
