Is this low Oil pressure OK?
The oil pressure at idle is directly related to the temperature and viscosity of the oil. I would say that what you see is perfectly okay, based upon my experiences with 5.7 liter engines. I've seen lower pressures that were very normal, once the oil was good and hot.
Yes it was indeed at normal operating temp when I took the pic., but when I noticed 25psi it jus kinda freaked me out. I was under the impression that a car shouldn't fall below about 40.
My Hummer H2 with the 6.2L motor typically shows just over 20psi of oil pressure once the engine is good and hot. Nothing to worry about as that is completely normal.
