Other Cars Non-Corvette Content, Daily Drivers, Winter Beaters, Work Trucks, Tow Vehicles, for sale
FS: 2009 Mustang GT 3V 5.0L Street Legal Road Course Car
Old 06-21-2015, 10:37 PM
Gray Ghost GS
"AlohaC5" Senior Member
Support Corvetteforum!
Gray Ghost GS's Avatar
Default FS: 2009 Mustang GT 3V 5.0L Street Legal Road Course Car
2009 Mustang GT 3V 5.0L (440 HP / 425 TQ) Naturally Aspirated [Street Legal] for the road courses
$29,500 FIRM
TRANSFERABLE FORD ESP PREMIUM CARE $0 DEDUCTIBLE WARRANTY TILL APRIL 6, 2016!!
http://baltimore.craigslist.org/cto/5147637940.html
VS. a '15 Mustang 5.0: This car is lighter, stronger, faster, better retro styling and handles just as well.
This Mustang GT is a professionally prepped street legal road course car (HPDE/Time Trial).
Low miles: Less than 41,000 miles. JDM 5.0L with JPC Racing upgrades motor: 1,500 miles
NOTE: This Mustang only has normal street miles on the 3V 5.0L engine (NO road course).
JPC Racing Dyno May 2015: 393 rwhp and 380 rwtq
Video at Virginia International Raceway (VIR) full course with previous modded 4.6L motor.
Kelly Blue Book: $20,500 plus $25,000 in forged race motor, built powertrain, brakes, cooling, suspension, and other performance parts!
JDM 3V 5.0L 302 FORGED Race Motor
* FRPP Aluminator block #M-6010-A46NA: Plate hones for a truer bore geometry
* Speed Pro NASCAR bearings
* JDM Spec ring pack with Moly top rings for better seal and longevity
* JDM Spec Custom Forged Manley Pistons
* Manley Forged Steel 4340 Connecting Rods with ARP Fasteners
* JDM Spec Kellogg Forged Steel Crankshaft
* Induction Hardened Journals and 8 Bolt Flange
* JDM Custom Grind Comp Cams
* Comp Cams Phaser Limiter Kit
* PAC 1233 Valve Springs
Jesel Race Followers $3,075
ATI 15% Super Damper Pulley $372
FRPP 39 lbs. Fuel Injectors (new style) $300
JLT Performance Series 3 Cold Air Intake $260
Ford Racing High Volume Oil Pump w/ Pick Up with TSS Billet Gears $500
Moroso Oil Pan #20548 with Windage Tray #22933 $415
Ford Racing CNC Ported Cylinder Heads #M-6049/6050-N3VPA $1,900
Ford Racing Laser Etched Black Valve Covers $280
Prothane Bullet Motor Mounts $140
JLT Black Oil Separator $120
JPC Braided Clutch Line Kit $60
Exedy Mach 500 Stage 3 Clutch $500
SPEC Billet Steel Flywheel $310
Mustang Axle Reservoir Overflow kit $125
New OEM Battery $125
Raxiom Sequential Tail Light Kit - Plug-and-Play $130
Brakes, Suspension and Cooling:
Wilwood Superlite SL6 140-9110 / SL4 140-9221 BBK with Brake Flexline Kits $3,500
Moser Engineering 31 Spline Forged Steel axles $400
Vogtland 1.2" Sport Springs $240
Maximum Motorsports Caster/Camber Plates $325
Steeda Sport Sway Bars with billet end links $540
Koni Yellow Sport Adjustable Front /Rear Struts & Shocks $640
Cervini Type III Chin Spoiler Textured Black $260
Steeda X5 Ball Joint & Bumpsteer Kit $170
Prothane Total Mustang Bushing Kit $165
BMR Adjustable Lower Control Arms with poly bushings $250
Steeda Adjustable Upper Comp/Street Kit w/ HD Mount $190
Steeda Strut Tower Brace $170
BMR Subframe Connectors $280
Agent 47 High Flow Lower Grill and Agent 47 Cooling Kit $600
Carbotech Brake Pads XP12 -- Front XP10 - Rear
Fays2 F2S Watts Link $675
Griggs Racing Power Steering Cooler $260
Fluidyne Aluminum Radiator $610
Taylor Battery Relocation Kit - NHRA Approved (Trunk) $240
APR Performance Carbon Fiber Adjustable Rear Wing GTC-200 with Gurney Flap $950
Engine, Drivetrain and Exhaust:
BBK Twin 62mm Throttle Body $330
2008 OEM Intake Manifold with Steeda Billet CMDPs $280
American Racing Long Tube Headers 1-5/8" With Catted X-Pipe 2.5" Stainless Steel $1,575
Bassani Stainless Steel 2.5" Race Exhaust $470
Ford Racing Gears 3.31 (Also have a set of FRPP 3.55 gears in excellent condition) $180
Axle Exchange Aluminum 1-piece Driveshaft $790
Steeda Lightweight Radiator Support $200
MGW Shifter 3650 and Roush Billet Shift **** w/ Grips $325
Moroso Radiator Expansion tank $140
S.O.S. Triple Pillar Pod with Auto Meter Gauges $150 + $450
Raptor Performance Shift Light (Black with Red LED) $120
Ford Racing Rear Differential Cover $185
Torsen T2R torque-bias differential $670
Front and Rear Tow Hooks (Recovery) $300
Corbeau Mustang Harness Bar $300
Camera Mount by IO Port Racing $120
Sony WX-GT90BT Double DIN CD Receiver
Tuned by Hi-Tech Tuning (Ed Hutchings) I have the HP Tuners file (unlocked) on CD
Extra set of 18" x 9.5" GT-500 OEM Wheels with Hoosier R6 (275/35R18) race slicks
TraqMate Complete Lap Timing System - wired for system with all software updates.
Custom car cover designed to support the carbon rear wing - still in great condition.
Lots of extra parts and items that go with the car - this is a "turn key" car for FUN!!
Multiple sets of Carbotech and Hawk brake pads for the road courses - BIG savings.
Extra Wilwood two-piece front brake rotors with new brake rings. Great for backup.
Gray Ghost GS is offline
Quick Reply: FS: 2009 Mustang GT 3V 5.0L Street Legal Road Course Car
