FS: 2009 Mustang GT 3V 5.0L Street Legal Road Course Car
"AlohaC5" Senior Member
2009 Mustang GT 3V 5.0L (440 HP / 425 TQ) Naturally Aspirated [Street Legal] for the road courses
$29,500 FIRM
TRANSFERABLE FORD ESP PREMIUM CARE $0 DEDUCTIBLE WARRANTY TILL APRIL 6, 2016!!
I have a complete set of records since new to include upgraded components, warranty, etc.
http://baltimore.craigslist.org/cto/5147637940.html
VS. a '15 Mustang 5.0: This car is lighter, stronger, faster, better retro styling and handles just as well.
This Mustang GT is a professionally prepped street legal road course car (HPDE/Time Trial).
Low miles. JDM 5.0L w/ JPC Racing upgrades motor: 1,500 miles. Tuned by Ed Hutchings.
NOTE: This Mustang only has normal street miles on the 3V 5.0L engine (NO road course).
JPC Racing Dyno May 2015: 393 rwhp and 380 rwtq
Video at Virginia International Raceway (VIR) full course with previous modded 4.6L motor.
Forged race motor, built powertrain, suspension, brakes, cooling and misc. parts!
JDM 3V 5.0L 302 FORGED Race Motor
* FRPP Aluminator block #M-6010-A46NA: Plate hones for a truer bore geometry
* Speed Pro NASCAR bearings
* JDM Spec ring pack with Moly top rings for better seal and longevity
* JDM Spec Custom Forged Manley Pistons
* Manley Forged Steel 4340 Connecting Rods with ARP Fasteners
* JDM Spec Kellogg Forged Steel Crankshaft
* Induction Hardened Journals and 8 Bolt Flange
* JDM Custom Grind Comp Cams
* Comp Cams Phaser Limiter Kit
* PAC 1233 Valve Springs
Jesel Race Followers $3,075
ATI 15% Super Damper Pulley $372
FRPP 39 lbs. Fuel Injectors (new style) $300
JLT Performance Series 3 Cold Air Intake $260
Ford Racing High Volume Oil Pump w/ Pick Up with TSS Billet Gears $500
Moroso Oil Pan #20548 with Windage Tray #22933 $415
Ford Racing CNC Ported Cylinder Heads #M-6049/6050-N3VPA $1,900
Ford Racing Laser Etched Black Valve Covers $280
Prothane Bullet Motor Mounts $140
JLT Black Oil Separator $120
JPC Braided Clutch Line Kit $60
Exedy Mach 500 Stage 3 Clutch $500
SPEC Billet Steel Flywheel $310
Mustang Axle Reservoir Overflow kit $125
New OEM Battery $125
Raxiom Sequential Tail Light Kit - Plug-and-Play $130
Brakes, Suspension and Cooling:
Wilwood Superlite SL6 140-9110 / SL4 140-9221 BBK with Brake Flexline Kits $3,500
Moser Engineering 31 Spline Forged Steel axles $400
Vogtland 1.2" Sport Springs $240
Maximum Motorsports Caster/Camber Plates $325
Steeda Sport Sway Bars with billet end links $540
Koni Yellow Sport Adjustable Front /Rear Struts & Shocks $640
Cervini Type III Chin Spoiler Textured Black $260
Steeda X5 Ball Joint & Bumpsteer Kit $170
Prothane Total Mustang Bushing Kit $165
BMR Adjustable Lower Control Arms with poly bushings $250
Steeda Adjustable Upper Comp/Street Kit w/ HD Mount $190
Steeda Strut Tower Brace $170
BMR Subframe Connectors $280
Agent 47 High Flow Lower Grill and Agent 47 Cooling Kit $600
Carbotech Brake Pads XP12 -- Front XP10 - Rear
Fays2 F2S Watts Link $675
Griggs Racing Power Steering Cooler $260
Fluidyne Aluminum Radiator $610
Taylor Battery Relocation Kit - NHRA Approved (Trunk) $240
APR Performance Carbon Fiber Adjustable Rear Wing GTC-200 with Gurney Flap $950
Engine, Drivetrain and Exhaust:
BBK Twin 62mm Throttle Body $330
2008 OEM Intake Manifold with Steeda Billet CMDPs $280
American Racing Long Tube Headers 1-5/8" With Catted X-Pipe 2.5" Stainless Steel $1,575
Bassani Stainless Steel 2.5" Race Exhaust $470
Ford Racing Gears 3.31 (Also have a set of FRPP 3.55 gears in excellent condition) $180
Axle Exchange Aluminum 1-piece Driveshaft $790
Steeda Lightweight Radiator Support $200
MGW Shifter 3650 and Roush Billet Shift **** w/ Grips $325
Moroso Radiator Expansion tank $140
S.O.S. Triple Pillar Pod with Auto Meter Gauges $150 + $450
Raptor Performance Shift Light (Black with Red LED) $120
Ford Racing Rear Differential Cover $185
Torsen T2R torque-bias differential $670
Front and Rear Tow Hooks (Recovery) $300
Corbeau Mustang Harness Bar $300
Camera Mount by IO Port Racing $120
Many more extras!!
Sony WX-GT90BT Double DIN CD Receiver
Tuned by Hi-Tech Tuning (Ed Hutchings) I have the HP Tuners file (unlocked) on CD
Extra set of 18" x 9.5" GT-500 OEM Wheels with Hoosier R6 (275/35R18) race slicks
TraqMate Complete Lap Timing System - wired for system with all software updates.
Custom car cover designed to support the carbon rear wing - still in great condition.
Lots of extra parts and items that go with the car - this is a "turn key" car for FUN!!
Multiple sets of Carbotech and Hawk brake pads for the road courses - BIG savings.
Extra Wilwood two-piece front brake rotors with new brake rings. Great for backup.
$29,500 FIRM
Many more extras!!
Mustang is going to Piper Motorsports in October for the following upgrades:
* 4 point roll bar: attach harnesses & the camera
* Sparco Evo 3 seats with double lock seat sliders
* 6-point Schroth Harnesses
Total upgrade: $3,500 (Price of car will change once this work is completed).
