Which would be a better choice to buy first Corvette c6 coupe or Corvette c6 z06
the c6 z06 is my favorite, though I still like the c6 base a lot. I was wandering if I should buy a c6 ls2 or ls3 coupe first, since it's significantly cheaper than the z06. Or should I save up more, and buy the z06. Which would be best? ls2, ls3 or ls7 z06?
Received 4,553 Likes
2016 C2 of Year
2015 C3 of Year Finalist
I've owned base and Z06 models and currently have a C6 Z06. If roof off motoring isn't important to you, go with the Z06. It's a completely different animal both in handling and acceleration.
As an owner of a c6 z51 m6 and it's been a great car....still if your asking for advice....I'd recommend the c6 z06.
I wouldn't be afraid of mileage. These things are validated for 300k miles,
Of course if you want roof off motoring then get the 2008 c6 coupe z51 m6 with npp exhaust..
Jmo
Jmo
If you prefer the aggressive styling of the Z06 and having a Z51 but with the huge Z06 brakes/wheels/tires, and like the targa top or even a convertible, then consider getting a Grand Sport(for less money than a Z06) and drive it for a while. Then, if you feel 436 HP isn't enough, install either an Edelbrock E-Force or a Magnuson Heartbeat supercharger on it(for 600+ HP), after you have saved up the additional money.
Getting the very reliable LS3 in the GS will save you around $3,000(approximate cost to do the heads on the Z06's LS7) that can then be applied towards the supercharger.
All LS7's have valve guide problems, keep that in mind, just go to you tube and look for LS7 head problems.
If you don't mind removing the heads every 10K and spending a good buck on guides then buy one, otherwise I would buy an LS2 or LS3 any day.
BS......and if they did have the valve guide problem once its not a reoccurring problem after the upgrade. geez Luise.
OP get the z06 an 08 or later....imo. I've had four base c6's and they all were good BUT I wish I had a c6 z....its on the list.
Get any year c6 Z, have the heads done, do a cam while you are at it and call it a day, you will hate yourself for not going with the better looking, much faster car.
I've considered a C6Z multiple times and never considered the base car. The bodywork and motor are big pluses for me.
If you can afford it, meaning everything being more expensive on the C6Z, then it is a easy choice. But if you are looking for a value, the standard c6 or even a GS is still offers great performance for the dollar.
Instead of spending $3,000 for a head job on a Z06, spend another $6,000(you will save more than that buying a GS over a Z06) for a Magnuson Heartbeat supercharger and end up with another 125 HP(over the 505 HP Z06).
And the supercharger will have the mild street manners of a stock LS3, but the low end torque will surely impress you when you want to play around.
I have a Z06 that I love, but for the money, a supercharged GS coupe is hard to beat. Except for the front fenders and wheel design, there is no difference in appearance between the GS and the Z06, and the additional 125 horses(over the Z06) under the hood more than make up for the heavier steel frame in the GS.
For the OP, he can get into a GS today(vs saving up for a Z06) and then add the supercharger later(after saving up the money while driving his GS in the meantime).
The ls7 valve guide occurance is less then one half of one percent.
Most aftermarket testing of valve guide issues was done incorrectly which incorrectly showed the heads needed a refresh benefiting the company to sell refreshed heads,
There were so many heads that were refreshed that didn't need them that it actually makes the c 6 z06 an impressive preowned vehicle to purchase.
The false testing procedures as well as the interweb negative concerns makes the c6 z06 the one to buy...as long as you don't mind not being able to take the roof.
Since I love taking the roof off...I don't have a c6 z06. For me it's really become a large part of enjoyment of owning a corvette. I keep the roof off all summer and a good part of the spring and fall.
As I get older the more I enjoy the roof off driving experience...
But if I didn't...no question the c6 z06 is the sports car I'd buy. I also wouldn't worry about mileage...I'd go higher mileage and lower price. I like to use my cars
2016 C2 of Year
I have had 3 C6's in the last 5 years, Started with a base, then a GS, now my current Z06......should have just done the Z06 from the start.
