FS: 2006 Jeep Rubicon Rock Crawler
For Sale. $75k. Over $125k spent to make it go. Not interested in trades. Already have the replacement. It is time for me to build another masterpiece.
Clean Kansas title in hand.
Located in Wichita, KS. 67210
You can contact me at Andy@trailworthyfab.com
Build thread:
http://www.pirate4x4.com/forum/jeep-...s-revenge.html
PM me if you want to talk. Walk if you want to low ball.
2006 JEEP WRANGLER RUBICON
DRIVE TRAIN
2008 L92 6.2L(403 hp and 415 lb·ft) from Cadillac Escalade(13k miles when pulled. 15, 500k current)
Custom Griffin Dual Pass Radiator and mount with high CFM fan
Matching 6L80e transmission with steering wheel tap shift tuned by Jim at Zero Gravity
Winters Shifter
Atlas 2 Speed 3.8 Transfer case
High Angle Drive Line drive shafts. Front and rear shafts can be swapped so you only need 1 spare.
Custom Motobilt Fuel Cell with Aeromotive Phantom 340 stealth fuel pump
Custom Trail Worthy Fab Fuel Cell Mounts with custom powder coat
Custom Fuel Cell enclosure
Custom Exhaust
XSPower AGM Deep Cycle Battery
FRONT AXLE
Torq Axle 14 Bolt drop-out with Torq Axle custom housing. (Everything 100% Brand new when built)
Torq 14 bolt drop out
Wide Open Design custom truss
Reid Inner C’s(Dana 70 forgings)
Solid GM Dana 60 Knuckles
Artec High steer arms keyed to solid knuckles
Reid Solid Bronze king pin bushings
5.38 Gears with solid pinion spacer. Sierra Gears
High Angle Drive Line 1410 Pinion flange
ARB Air Locker
4340 Chromoly Inner axle shaft
Yukon Super Joints
4340 Chromoly Outer axle shaft
TWF Dana 60 Drive flanges
Yukon Hardcore Dana 60 Lock outs
Off Road Gear Dana 60 Brake Caliper brackets
Wilwood 6 Piston Calipers
Wilwood 14” Street Rotors
PSC Full Hydraulic Steering with custom tie rods. Linked to Artec high steer arms in double sheer.
REAR AXLE
Torq Axle 14 Bolt drop-out with custom Torq Axle Housing(Everything 100% brand new when built)
5.38 Gears with solid pinion spacers. Sierra Gears
High Angle Driveline 1410 Pinion Flange
ARB Air Locker
4340 Chromoly Axle shafts
Off Road Gear Custom brake caliper brackets
Wilwood 4 Piston calipers
13” GM Rotors
SUSPENSION
Custom 4 link front and rear
EMF 1.25 Rod Ends with ¾” through bolt
Radflo 14” Tuned Coilovers
Radflo hydraulic bump stops
Rear Currie Anti Rock
WHEELS AND TIRES
20x10 ATX Slab Bead locks
42x15-20 Pit Bull Rockers (1 wheelin trip)
BODY AND ARMOR
Less than 30k miles on Tub/Frame
Trail Worthy Fab Rear Back Half kit
AEV High line hood
Rokmen High line fenders
PSC Front bumper with custom powder coat
PSC Ricochet Rockers with custom powder coat
PSC Comp Cut rear corners – Aluminum with custom powder
Warn Zeon 8s Winch – Factor 55 Pro Link
Custom 3M Vinyl Wrap – Matte silver. Can be pulled easily if you prefer custom paint.
Motobilt LED light bar brackets
50” Trail Worthy Fab 4D Light bar
TruckLite LED head lights
American Superlite LED turn signals front and rear
PSC Laser cut roll cage with extra tubing
Mastercraft Baja RS seats mounted to the cage. Full recline, lumbar, sliders
5 Point harness for both seats
Autometer Gauges
Full CB radio with external speaker
Garmin JEEP branded GPS on dash
Full Doors - New soft top
Trail Rated Badge
Mall Rated 4x4 Badge of Honor
Roots Vibrosonic Loud Horns
Grant Quick Disconnect steering wheel
Twist Machine Shrifter tap shifter to control 6L80e (With rev match)
STEREO
Kenwood head unit – USB, Bluetooth
Rockford Fosgate 4 Channel amplifier to control mids
Rockford Fosgate Class D amplifier to control subs with bass ****
Front 4x6 Polk Audio Components
Rear 6.5” Polk Audio Coax in CrawlTunes cans
2 – 12” Polk Audio Subwoofers
I have had quite the response from my for sale threads. It hasn't gone yet but I expect it will. Not everyone wants a POS Jeep. I am flexible with my price tag. But I'm not after the $15k some chick told me I'd get if I tried to trade it in.
Where else can you find a Jeep with tons, LS3, and paddle shifters??
Posted on Hardline yet?
This is a serious rig!!! It will just take the right person. Wranglers are gold and not everyone wants a JK. I have a built TJ myself and to me your jeep is the ultimate build. Amazing is a understatement. At $75 your losing $50k thats enough to make someone sick!!!! Im going to say this and i mean it. Baddest TJ jeep ive ever !!!! Well done sir!!! Because of your jeep i just ordered a 52" cree light bar and now thinking of other mods.
