ForSale Superformance Cobra 533 big block power
1965 AC Cobra MKIII for sale $64,500
Of course, I would consider C1 and C2 Corvette trades.
Superformance Chassis #1299 (Imported 4/09/2002 to Dynamic Motorsports, Ross, OH.)
Titanium Silver with Black Stripes, Black Interior, less than 6,500 miles on car.
They always say bigger is better, and there is no substitute for cubic inches, this Cobra is not for the timid or faint of heart, it is an absolute beast with horsepower and torque beyond your imagination!!
Engine Specifications:
533 cubic inch stroker, peak dyno 623HP @ 5500 RPM and 638 Torque @ 4300 RPM
Engine uses a 460 Ford block, 4.44” bore, 4.30” stroke, JE pistons, 6.8” 4340 forged H beam rods
Edelbrock Aluminum heads & intake, aluminum roller rockers, Cobra script valve covers
Demon 850 cfm carburetor with Shelby script air cleaner
Comp Cam 34-338-5 hydraulic lifter cam, .610 lift, 260 duration, 110 lobe separation
Canton Oil Pan, Melling high volume oil pump
Center force clutch, blow proof bellhousing
MDS 6 ignition with rev limiter and MSD pro billet aluminum distributor
March aluminum pulleys, black coated headers and pipes
Upgraded hand brake, black tonneau cover, black soft top
Shelby Cobra 15” aluminum real pin drive knock-off wheels with BFG Radial T/A tires
Tremec TKO 5-speed overdrive transmission
