LS Powered 1998 BMW M3
1998 BMW M3
NASA ST1/ST2/ST3
(DEPENDING ON RESTRICTOR SIZE)
(APPROX. 400 RWHP WITHOUT RESTRICTOR)
CAR AND ALMOST EVERY COMPONENT HAS APPROXIMATELY 30 HOURS
WEIGHT – 2550 LBS (DRY)
ENGINE: LS6 BLOCK WITH STOCK CRANK/RODS WITH ARP ROD AND HEAD BOLTS
SPEED PRO COATED PISTONS
LS1 PORTED AND POLISHED HEADS BY THOMPSON RACING
GM TORQUER CAM (204/218 WITH .550 LIFT @ .050 – 112 LSA
SMITH CHROMEMOLY RESTRICTED PUSHRODS
STOCK ROCKERS WITH COMP CAMS TRUNION KIT
11:1 COMPRESSION RATIO
FAST 92 INTAKE MANIFOLD
FAST BIG MOUTH 92MM THROTTLE BODY
LS3 INJECTORS
LS7 MAF
F BODY OIL PAN
STOCK GM ECU
(TUNED BY FORMER GM ENGINEER)
AUTOMETER GAUGES
OMP WHEEL
MOMO “LESMO” HALO SEAT
TILTON DUAL MASTER BRAKE CYLINDERS/BIAS
BRAKE PRESSURE GAUGES
ALUMINUM FLYWHEEL AND PERFORMANCE CLUTCH
FUEL SAFE 22 GAL. FUEL CELL
10 LB. “FIRE SENSE” FIRE SYSTEM
COIL OVERS - KONI DOUBLE ADJUST FRONT AND SINGLE ADJUSTABLE REAR SHOCKS
SPRINGS – 750LB FRONT/800 LB. REAR
GROUND CONTROL CAMBER PLATES AND SWAY BARS
VORSHLAG LS CONVERSION KIT
POWER STEERING COOLER
ENGINE COOLER
3 QT. ACCUSUMP
TURN ONE POWER STEERING PUMP
COATED HEADERS (INSIDE AND OUT)
BORLA STAINLESS RACE MUFFLERS
T56 MAGNUM TRANSMISSION TUET-11009
(2.66/1.78/1.30/1.00/0.80/0.63)
CUSTOM STEEL DRIVESHAFT
3.73 LSD DIFF – 60% LOCKUP
DIFF COOLER
GRIFFIN ALUMINUM RADIATOR
BRAILLE LIGHTWEIGHT BATTERY
ALCON 15 IN FRONT BRAKE CALIPERS
PORSCHE BOXSTER S 13 IN. REAR BRAKE CALIPERS
SLOTTED/DRILLED ROTORS
FISKE 18 X 11 WHEELS
PIRELLI DH SLICKS 285 X 645 X 18
CARBON REAR WING
$38,500
NASA ST1/ST2/ST3
LS3 INJECTORS
LS7 MAF
F BODY OIL PAN
STOCK GM ECU
AUTOMETER GAUGES
OMP WHEEL
ENGINE COOLER
3 QT. ACCUSUMP
DIFF COOLER
CARBON REAR WING
$38,500
As of present my best times have been about 2-3 seconds off of the Corvette ST2 track records. Part of that is that I run used Pirelli slicks that are throw aways from World Challenge cars.. I think with a few more set up tweaks and some newer tires (A7's ?) I can get close to the Corvette's times. But we did win the ST2 Regional Championships last year with the BMW. The M3 is a lot easier to work on and a blast to drive but I am getting too busy on other projects.
