No Front License Plates in WA state may happen with your help!
I looked at several front license plate brackets, and finally found this one. It is exceptional in that it is truly easy to put on and remove (once the bracket is installed) and absolutely does not touch the fender or grill in any way. You can walk up to the car and just pull the plate off. You can also line it up and push it back on. Once in place, it does not come off. I bought a competitor that was highly recommended and returned it because it rested on the grill and would bounce up and down when you went over a bump. This one is very secure, and cheaper than most of the others I've seen.
Here's a link to West Coast Corvette's website where you can order it. And no, I have NO financial interest in this at all.
http://www.westcoastcorvette.com/p-1...nvertible.aspx
