Advice in Idaho
7th Gear
Advice in Idaho
Hey there. As a new 2000 Corvette C5 Roadster Convertible owner, I'm looking for some direction for some preferred local places (I live in Troy, work in Moscow near Pullman) for the following items to be addressed:
- 10 disc changer isn't working (Touch screen just says "Eject") but all other audio components work fine.
- Touch up paint work to the nose of the car
- A good place to store it. (Not a fan of the place in Pullman I currently have it. Is it that detrimental to say "Screw it!" and keep it outdoors at home?)
- Any general tips/things I should be aware of owning such an amazing car!
Thanks in advance!
Thanks in advance!
I'm sure I'm in the minority with this opinion ... It can survive being outside. Try not to get too fixated on keeping it as pristine as you can, otherwise all of the little things that go wrong will start to wear thin on you . Being that it's a vert, I'd make sure the top is kept clean and covered in some protecting product for all of the rain it would see.
7th Gear
What type of protecting product? Is it something I could apply (especially during winter) or would it have to be at a dealership? And would I need to be concerned about any snow build up it may get? Thanks for the advice!
A Vette is a special car and deserves pride of ownership. I would never leave our cars outside,especially a conv. At least get one of those "sheds" or trade it in for a "ford"!!!
First, welcome to the Corvette Forum!! Great place to get all sorts of information and help. Visit the C5 General and C5 Tech sections to find all sort of answers about problems or tips and tricks.
I don't have the CD changer (actually the OEM radio in my '02 has an aftermarket unit) but there is an Audio/Electronics section where you should be able to get that question answered.
For storage, it would be best if you can store the car either inside or under cover. Given the chance of occasional heavy snow in the Palouse, it may not be a good idea to keep a convertible outside. There are some good car covers that work for outside storage where the car is in a shed.
I would definitely recommend storing the car where there is electrical power available. A good battery maintainer like a Deltran Battery Tender or CTEK unit will keep the battery fully charged. Otherwise, it would help to disconnect the battery and even remove it from the car and store the battery inside. Keep the gas tank full to avoid any buildup of condensation. Adding a bottle of Tecron with a fill-up helps too especially to keep the gas gauge working.
For paint work, you may have to find area specialty paint shops and ask to see some of their work. What color is the car??
If you have to store it outside, get a good 3-4 layer Car Cover, it'll protect the paint and protect it from scratches.....Keep one on mine in the garage just to protect it from the kids...
Also check your battery for fluid level twice a year, add distilled water when need be. Winters are tough on batteries.
7th Gear
Cd changer
For what it is worth, my 02 vert has a changer in the well in the trunk. It has stopped working twice for reasons im not able to give you. I have decided to let it be, the cd player in dash works fine. If you arent **** about it working id leave it non-working. I think maybe it is effected by the harshness of the ride in the well of the trunk? Of course this is only my opinion. Good luck with your new ride , whatever you decide to do. Al Figliola
7th Gear
This is a Corvette we are talking about!!! Where we live we seldom have snow and I am sure the weather is better here!
go to these guys for advice on product if you end up parking it outdoors! they will steer you right. I've not owned a vert before so I would not be able to advise there. http://www.autogeek.net/contopcleanp.html
