Exotics @ RTC 4/18/15
Do you check the fluid levels every 6 months and refill with distilled water when needed. (assuming its a normal lead cell unit)
My original battery finally lost a cell (11yrs old!) just replaced it with a Gel Odyssey Battery that Sears sells.....Being Gel no refilling and it can never leak onto the ECU below....
Phil, wth? It was mega full again, only took a few pics all still on the camera. 2 C7Z's, 2 new Rolls, a La Ferrari, and everything else.....
These little things can be had on Ebay for about $25 and come with two sets of leads. One to hook up to the battery and another with clips if you want to use it sparingly. My original better is 9 years ld and still works just fine. Not sure how much longer it will hold up, but so far so good.
That reminds me now that I think about it. Can you push start a manual transmission Corvette without harm to the electrical system?
Bummed I did not make it out to E@RTC. Was up until Midnight Friday troubleshooting the VATS system. Ended up having to build a new resistor and place it inline between the ignition cylinder and VATS module to convince the car it hadn't been stolen.
The upsides:
The upsides:
- I now know a 6'1" person can contort and repair under dash wiring of a C4 without too much pain
- I'm an expert in the understanding of the late C4 VATS system
